Cables to connect MESA 5i25 + 7i77 to driver
- dinodf
- Thank you received: 9
24 Feb 2014 08:22 #44101
by dinodf
Cables to connect MESA 5i25 + 7i77 to driver was created by dinodf
sorry for my english...
I need to connect analog and encoder signals from MESA 7i77 to ISEL CVC496 .
Can I use cable UTP CAT5 E for encoders signals and also for analog signal?
A pair of twisted for A and /A, one for B and /B and one for IDX and /IDX, can I use also a twisted pair for Analog (+-10v) and GND? or it is better use a different cable?
Thank you
Best regards
Dino
Thank you
Best regards
Dino
- Thank you received: 5255
24 Feb 2014 23:20 #44130
Replied by PCW on topic Cables to connect MESA 5i25 + 7i77 to driver
CAT5 cable should be fine for encoders, (as long as its not subjected to much flexing)
I would not wire the analog signals in the same cable as the encoder signals. For
analog signals I would use a shielded pair with the shield terminated at the 7I77 end only.
But... I dont see that that drive has provisions for analog control (looks like CAN only)
The following user(s) said Thank You: dinodf
- dinodf
25 Feb 2014 06:30 #44157
by dinodf
Replied by dinodf on topic Cables to connect MESA 5i25 + 7i77 to driver
It have also analog input, but it is not documented
the driver have it and I can connect the signal on it
UVE8112
Thank you for the answer.
- emcPT
- Thank you received: 139
25 Feb 2014 07:22 #44158
by emcPT
Replied by emcPT on topic Cables to connect MESA 5i25 + 7i77 to driver
I do not recommend the use of CAT5 cable. It will brake easily.
Try IGUS cables. They will sell you almost all measures and the cable is superb. Much better than having a broken cable.
Time to create page: 0.057 seconds
