Mesa Reccomendations for custom made servo drive
- Jonathan
17 Mar 2014 18:22 - 17 Mar 2014 18:31 #44915
by Jonathan
Mesa Reccomendations for custom made servo drive was created by Jonathan
I've recently almost finished designing and making my own servo motor driver. I've used a dsPIC to control the motor (permanent magnet synchronous), with position feedback currently from this
Avago 17-bit
absolute encoder although I could easily configure it to use other, e.g. quadrature, encoders. Since I have designed and programmed the drive, I can (within reason) choose whatever protocol I want for sending the position or velocity reference to control it, so my main questions are as follows:
www.microchip.com/wwwproducts/Devices.aspx?dDocName=en532302
I've used one of the SPI peripherals for the encoder and one UART for a general serial interface with computer (mainly for debugging and tuning via MATLAB or terminal), but there's still one of each spare.
Am I on the right lines thinking I could configure LinuxCNC to send out data packets to the drive containing the velocity information and receive the position data?
Thanks in advance...
- What protocol would you reccomend to send position / velocity data to drive? e.g. +-10V, RS485 etc...
- Which PCI card(s) would be most suited to the above?
Last edit: 17 Mar 2014 18:31 by Jonathan.
- Thank you received: 5255
17 Mar 2014 22:39 - 17 Mar 2014 22:43 #44922
Replied by PCW on topic Mesa Reccomendations for custom made servo drive
For interfacing with Mesa HostMot2, and if you can figure out the somewhat sketchy protocol description in the
manuals, probably the easiest is to use RS-422/ SSerial. This will make the drives process I/O variables (velocity in, say position and drive status back) automatically available as HAL pins without requiring any driver changes.
SSerial has one limitation for this type of application currently, it only transfers one packet of data each servo thread.
this means the read data is always one servo thread period late. We intend to address this limitation some time this year
by splitting the transfer requests into a RX and TX part.
One way to live with the limitation is to run the drive in PVT mode where you send position/velocity/time packets
so the drive gets good velocity information from the host plus position data for a weak PI loop to correct for minor
timebase differences etc.
Last edit: 17 Mar 2014 22:43 by PCW.
- Jonathan
20 Mar 2014 03:57 #44989
by Jonathan
Replied by Jonathan on topic Mesa Reccomendations for custom made servo drive
Thank you for the information - most helpful. It looks like I would be fine with just a 6i25, as unless I've missed something the boards to go with them don't seem helpful for my application. However, I think I'd be best off getting one with the 7i76 so I can trivially connect the existing stepper drivers on my machines. The 7I80DB is tempting so long as it wouldn't complicate matters much?
If the problem you describe is going to be addressed this year, that sounds fine to me. Adding a weak proportional controller for position to the driver code is also not a problem. However, couldn't we instead just halve the servo thread period and alternately send packets to request and read the data from the drive? That would halve the timing error, which as a temporary measure may be sufficient?
- DaBit
- Thank you received: 35
20 Mar 2014 23:54 #45016
by DaBit
Is there any sample code for the 'remote' side available? Preferrably dsPIC, which you seem to be using on a 7i76 too.
I am busy building a mill, and for that I need, besides a bunch of I/O lines, 6 analog outputs, 8 encoder inputs and two stepper channels. I recently bought a 5i25+7i76 so I might want to buy an extra 7i77 and then I am there.
The thing is: 4 encoder channels go to glass scales, and I am considering leaving them and a small dsPIC33-based controller powered 24/7 so they behave as 'absolute encoders'. I was thinking parallel port for the communication, but SSerial is a far nicer option.
Replied by DaBit on topic Mesa Reccomendations for custom made servo drive
21 Mar 2014 05:12 #45018
We dont have any C examples, the current remotes are all done in a funny macro assembler
dialect that allows similar code to run on our FPGA soft processors. We expect to move to STM32F3s
for some new remotes and may have sample C code available then. I dont think we would mind publishing
the assy code for a remote but its likely to be pretty weird for a C programmer.
- Thank you received: 4988
21 Mar 2014 19:59 #45027
I wonder what Isssy used for his home-made smart-serial remotes?
I can see many uses for an Arduino-based smart-serial remote library.
Replied by andypugh on topic Mesa Reccomendations for custom made servo drive
21 Mar 2014 23:34 #45038
Pretty sure Issy is using our custom code for his remotes
What is the maximum Arduino baud rate? (we will add this to the autobaud probe list)
We are looking at the STM32F303 parts for new sserial remote designs
These have:
32 bit Arm cortex M4 core with floating point at 72 MHz
4x 12 bit 5 MS/sec A-Ds
2x 12 bit DACs
multiple serial ports with baud rates up to 9M Baud
a couple of encoder counters
at about the same price as the DSPICs (~$3.25 in reasonable qtys)
all this and a $10.66 dev board
These have:
2x 12 bit DACs
21 Mar 2014 23:36 #45039
I have run 1Mb.
I have run 1Mb.
- DaBit
22 Mar 2014 02:50 #45057
by DaBit
You know there are C compilers for Microblaze and Picoblaze cores, right?
I can read/write assembler too, but then I basically have to start all over developing the SSLBP protocol stack, including spending 80% of the time getting the last few bugs out.
I am not in a hurry; I'll wait a while. Or I just use the parallel port; bitbanging multiple SPI channels with the clock in DDR mode so a single outb/inb is a single bit should be fast enough for the few words I want to transfer each servo period.
I have these in the visor as well, although I do like the dsPIC's a lot. Cost is low, processing power is often more than sufficient and package options go down all the way to DIP which is easy for prototyping (or a single personal product) on breadboard.
22 Mar 2014 03:11 #45062
We should have relatively portable sserial remote code for the STM32F3 sometime this year one way or the other...
The Picoblaze and Microblaze are nice but for our purposes the
Picoblaze is too slow and the Microblaze is way too big and they are
both load/store (RISC) architectures which are quite inefficient when you have
lots of direct I/O.
They are really designed around a slow memory, fast register
model that does not match small embedded FPGA processors that run out of
BlockRAM very well.
Also not sure if C makes much sense when you only have 2K of code space
lots of direct I/O.
BlockRAM very well.
Time to create page: 0.196 seconds
