Amplifier compatible with AC Motor -Sanyo P5
10 Apr 2014 21:00 #45794 by greeder88
I have 4 Sanyo P5 ac servo motors 200v 3-phase (750w) with incremental encoders I need amplifiers for. Probably buy from E-bay.
I believe they require a specific type of amplifier. Sinusoidal Commutation?
Copley XSL-230-36 came up in my search however is this my best bet or will others work?
I have both Mesa 5i25, 7i77 boards and Pico Universal PWM Controller boards and can use either one and I can add stuff on the end of the motor shaft if needed since these are hollow shafted.
Motor model: P50C08075HXS21
11 Apr 2014 00:21 #45802 by PCW
do the motors have encoders installed?
11 Apr 2014 00:44 #45803 by greeder88
Replied by greeder88 on topic Amplifier compatible with AC Motor -Sanyo P5
Yes they are installed but if something else is better no trouble putting them on the back end. Unless they are cost prohibitive.
Thanks.
George
11 Apr 2014 00:55 #45805 by emcPT
www.eusurplus.com/
Argon product.
11 Apr 2014 01:12 #45807 by greeder88
The Argons look good however I have 5 or 6 machines I would like to convert if I can get something working good. Looking to keep costs down and not likely to find these used.
11 Apr 2014 01:28 #45810 by emcPT
Still not expensive.
If you have several machines then the work that you do on one machine will be reproduced to the others. If you are looking for used drives, most likely you will find them all different, and that will give you more expenses at the end.
I have stock of the Argon. For price vs quantity please contact the store, that I will reply.
Moderators: PCWjmelson
