What Mesa card can translate sinwaves in TTL?
- aike
- Thank you received: 4
03 May 2014 09:51 - 03 May 2014 16:22 #46548
by aike
What Mesa card can translate sinwaves in TTL? was created by aike
Hi!
I have old liner optical encoder. Its output is sinwave +-10Volt.
Mesa 5i20 accept TTL input signal level.
The question:
Which Mesa card can input sinwaves encoder signal and output TTL encoder signal for 5i20 or similar card?
The optoisolation not needing.
The question:
Last edit: 03 May 2014 16:22 by aike.
- Thank you received: 5255
03 May 2014 20:22 #46555
Replied by PCW on topic What Mesa card can translate sinwaves in TTL?
Normally this require a interpolater
(we have a interpolater coming out , the 3I23, but its not available yet)
also are you sure the scale has +-10V outputs?
(+-1V and +-11 uA are common)
If you just want to square the sine/cosine outputs (and lose resolution)
you feed the sine/cosine signals into a differential encoder input with a
say 1K series resistor
- aike
03 May 2014 22:48 - 03 May 2014 22:49 #46556
by aike
Replied by aike on topic What Mesa card can translate sinwaves in TTL?
I will measure the encoder signal tomorrow and let you know.
The encoder signal comes from CCM and I can not lost any resolution.
In this case I need interpolator, from analog to square signal.
Last edit: 03 May 2014 22:49 by aike.
- Thank you received: 2160
04 May 2014 03:19 - 04 May 2014 03:20 #46559
Replied by cmorley on topic What Mesa card can translate sinwaves in TTL?
heidenhain makes interpolaters.
IBV are for 1vp, such as:
www.ebay.com/itm/Heidenhain-Sine-Encoder...&hash=item3a8fa8ccf0
or EXE for 11uA:
www.ebay.com/itm/Heidenhain-EXE-602-E-D8...&hash=item51b403c147
These are available with many different interpolating multiples.
5x in typical IIRC.
There are other makes as well.
Chris M
or EXE for 11uA:
5x in typical IIRC.
Chris M
Last edit: 04 May 2014 03:20 by cmorley.
- aike
05 May 2014 00:20 #46584
by aike
I tested the signal on osciloscope.
3 mV. This is signal stright from the encoder. Sinwaves.
- jmelson
- Thank you received: 159
05 May 2014 06:12 #46594
by jmelson
the peak to peak signal value. if it is a current output encoder, then
you have to load it with a known resistance to determine the P-P
current value.
While you are set up to do this, you can also determine the native
resolution of the encoder. Determine how far it is between peaks
on one of the signals, and divide by 4 to get the quadrature resolution.
Or, crank it a known distance, like 1 mm, and count the peaks.
Multiply by 4 to get the quadrature counts/mm. This would be the
NATIVE resolution of the encoder grating, interpolation would
mutliply that value.
Jon
Jon
Replied by jmelson on topic What Mesa card can translate sinwaves in TTL?
You have to move the encoder from max to min and subtract to determineI tested the signal on osciloscope.
current value.
Jon
Jon
- aike
05 May 2014 20:31 #46628
by aike
Dear Jon!
It is analog signal and I measured the loaded curcis amplitude. (600 or 1 KOm).
According to resolution, I will count the number of picks.
But I need to interpolate the analog to digital TTL.
All counting and processing will be done with digital signal, not from analog.
The best way analog input 3mV -> Black box -> TTL 5V.
That is all.
That is all.
- jmelson
05 May 2014 22:46 #46632
by jmelson
native resolution of the scale. That has nothing to do with the conversion
of analog to digital, although it obviously is only possible with analog output
from the scale. Well, since you say this is for a CMM, then interpolation
is most likely needed. Just check with the maker of the interpolator box
to make sure it is compatible with your specific scale model.
Jon
Interpolation refers to the increase of linear reasolution by subdividing theDear Jon!
Jon
- Thank you received: 4988
06 May 2014 06:46 #46647
Another option is the ICHaus chips. They produce a development board which is intended for OEMs to try out their products on, but I know a chap who is using them as-bought to control his lathe to sub-micron positions.
www.ichaus.de/upload/pdf/NQ6D_evalmanual_A3en.pdf
Is the datasheet for what I think he is using.
Replied by andypugh on topic What Mesa card can translate sinwaves in TTL?
- uli12us
08 May 2014 15:48 #46713
by uli12us
Replied by uli12us on topic What Mesa card can translate sinwaves in TTL?
That with the 3i23 sounds interesting. I have a 5 axis mill, I want to upgrade with Mesa. The machine uses 11µA optical
Encoders with I think 20µm resolution. Because the old control want TTL input as well, it have 5 Exes but with your interpolator I think I can reach a higher resolution.
Time to create page: 0.093 seconds
