best type of board drive
- Anis
13 May 2014 23:30 - 13 May 2014 23:30 #46889
by Anis
best type of board drive was created by Anis
what is the best way to connect linuxcnc to the board which drive the motor, parallel port or PCI ?
the second question : what is the best type of board driver which support PCI ?
Last edit: 13 May 2014 23:30 by Anis.
- BigJohnT
- Thank you received: 1176
14 May 2014 06:52 #46906
by BigJohnT
Replied by BigJohnT on topic best type of board drive
A PCI board is always faster than using software step generation and the parallel port. Mesa and Pico have PCI hardware and I'm sure they can fill you in with specifics.
JT
JT
- Thank you received: 5255
14 May 2014 22:51 #46930
Replied by PCW on topic best type of board drive
What kind of motor drives and what kind of machine do you have?
Interface options range from simple parallel port interfaced step drives
to multi axis servo systems with 100's of I/O points
The best hardware really depends on what you are doing
Time to create page: 0.148 seconds
