Mesa 7I52 with 3x20/7I68
23 May 2014 08:36 #47218 by redbase
Mesa 7I52 with 3x20/7I68 was created by redbase
Hi All
Have the hardware 3x20 - 6i68 and 7i52 to prove up a machine, 6 encoder, 6 step/dir.
Located PIN_SVST6_6_7i52S_48 which looks suitable.
Are BIT file's available for this configuration if suitable or will this require the file to be built?
Thanks!
23 May 2014 10:09 #47223 by PCW
Replied by PCW on topic Mesa 7I52 with 3x20/7I68
If you have a 7I52S, the PIN_SVST6_6_7i52S_48.vhd file can be used (with a little hacking to make it into PIN_SVST6_6_7i52S_144.vhd) to compile a proper bit file
I can do this sometime tomorrow if you can wait
23 May 2014 10:24 #47224 by redbase
Replied by redbase on topic Mesa 7I52 with 3x20/7I68
Confirm 7I52S.
Thanks!
24 May 2014 03:10 - 24 May 2014 04:00 #47266 by PCW
freeby.mesanet.com/3x20_1M_svst24_24_7i52s.bit
should be right for a 1M 3X20 with 1x to 4x 7I52S's
(this config has 24 stepgens and 24 encoders possible, seemed silly to just have 6 max on a 3X20)
Last edit: 24 May 2014 04:00 by PCW.
26 May 2014 07:34 #47327 by redbase
Thanks Peter agreed on the config.
Could PNCConf be used to setup the 7I52?
26 May 2014 21:16 #47349 by PCW
I dont think pncconf has a step/dir +encoder feedback configuration option
I can make up a simple one on Tuesday as an example (today is a holiday in the US)
28 May 2014 02:10 #47417 by PCW
freeby.mesanet.com/3x20encstep.zip
has example hal and ini files for a simple 3 axis
closed loop stepgen system with encoder feedback
(basically the standard hm2-stepper example config hacked for encoder feedback)
Notes
1. I renamed the bit file to svst24_24.bit since long bitfile names sometimes cause troubles
2. the files assume 10000 counts per inch and 10000 steps per inch
28 May 2014 09:45 #47434 by redbase
Thanks Peter will give it a try asap, having some minor issues.
03 Jun 2014 16:44 #47649 by redbase
Loaded the files for the 3x20 and have configured a setup using PNCConf.
When the configuration is run the debug shows:
Debug file information:
insmod: error inserting '/usr/realtime-3.4.55-rtai-2/modules/linuxcnc/hm2_pci.ko': -1 No such device
filament_winder.hal:9: exit value: 1
filament_winder.hal:9: insmod failed, returned -1
Offending line from the .hal file: setp hm2_5i23.0.watchdog.timeout_ns 10000000
Have changed a number of config settings such as num of encoders and step gen to no avail, can you advise what may need to be checked?
File Name: LinuxCNC_debug.txt
File Size:6 KB
File Name: filament_winder.hal
File Size:10 KB
03 Jun 2014 21:40 #47661 by PCW
Looks like you are using a 5i23 example file
To launch the example file I posted you would have to select
"3x20encstep" from the chooser (assuming you unzipped the
3x20encstep zip file in ~/linuxcnc/configs/somesubdir)
or launch linuxcnc from the command line:
linuxcnc 3x20encstep.ini
Moderators: PCWjmelson
Time to create page: 0.173 seconds
