Mesa Cards and Inductive Proximity Switches
12 years 2 months ago #50579
There are "shielded" and "unshielded" types. if the threaded sleeve extends all the way to the end then the prox is "shielded" and these are a lot easier to work with in a machine tool.
I have a few of them embedded in actual slideways in places that never see any swarf using a hole drilled in the mating part as a target.
picasaweb.google.com/lh/photo/PtEG4xP6Ic...pFm0?feat=directlink shows a couple in my milling machine prior to being wired up.
Replied by andypugh on topic Mesa Cards and Inductive Proximity Switches
Skippy1 wrote: Had the sensor hanging as far out of the tool holder as I could, as the instructions said that if it was adjacent to, or shrouded by metal, it reduces the sensitivity
11 years 8 months ago #56064
by Skippy1
Replied by Skippy1 on topic Mesa Cards and Inductive Proximity Switches
Thanks for the tip Andy - that's a top idea.
I purchased a pair of the Omron M5 threaded tube PNP shielded type, (E2E-X1B1) and tested them. They have a really crisp on/off point on the approach and retract, repeatable to about a thou'.
As suggested, I plan to bury them in the carriage cross-slide dovetail in drilled and tapped passages. Once I conform the travel limits, I'll drill corresponding 5mm divots in the mating part.
Cheers, Steve
Cheers, Steve
9 years 11 months ago - 9 years 11 months ago #83258
Damn, I have a 7i76e and I've been collecting NPN proximity switches. Can someone tell me what external components are required and where they should be connected on a 24 volt NPN proximity switch? I'm guessing a pullup resistor or something is required. What value resistor?
Replied by rodw on topic Mesa Cards and Inductive Proximity Switches
PCW wrote: for 7I76 (and 7I77,7I70,7I66,7I84) inputs,
PNP type proximity switches are the best
(no external components)
Last edit: 9 years 11 months ago by rodw.
9 years 11 months ago #83261
Reading the manual, it sounds like the inputs on the expansion connectors are 5V logic with pull-up (whereas the GPIO is 32V inputs with pull-down) so it might make sense to interface the proximity switches to the expansion connector rather than the terminal blocks.
But see what PCW says about this, it might be a terrible idea.
9 years 11 months ago - 9 years 11 months ago #83277
Replied by PCW on topic Mesa Cards and Inductive Proximity Switches
Using the expansion connector pins directly will work with NPN proximity switches
(the expansion port pins have pull-ups to 5V)
_BUT_ if you make a wiring mistake (connecting to >7V or < -0.5V) even for a microsecond
or you have a EMI issue and large voltage spikes on the wiring, you will damage the FPGA
Safer to use the field inputs with a 2K 1 W pullup to 24V
Last edit: 9 years 11 months ago by PCW.
Time to create page: 0.052 seconds
