Any experiencies with 7i76E
- uli12us
16 Jun 2014 14:25 #48000
by uli12us
Any experiencies with 7i76E was created by uli12us
I have seen, mesa have a new Board 7i76E, which is the same like a combination of a 7I76 daughterboard and the 7i80 Lan FPGA Card.
I need for my Project this card and a 7i77 for controlling a 5 axis machine, i wonder if it runs correctly,
because the step/dir output of the card is only a asynchronous axe (toolchanger turret chain). Because the distance from the computer to the FPGA is more than 4metres through a not really big tube, I want use a lan cable instead of the 25wire parallel cabel. So the new card will be better than the method with either 5i25 or 7i80 because it needs a bit less harness.
- Thank you received: 5304
17 Jun 2014 09:38 #48021
Replied by PCW on topic Any experiencies with 7i76E
The 7I76e is supported by the experimental ubc-7i80 branch and Preemt-RT.
Preemt-RT works well enough with a decent MB to get a reliable 2 KHz servo thread
I'm currently testing with the Gigabyte J1800-D2H (which is quite nice since its fast and fanless),
Ubuntu 12.04 and preemt-rt 3.14 kernel .
The equivalent Asrock CPU should be the same but doesn't not have the BIOS issues the Gigabyte
has with linux (needs a BIOS upgrade to boot)
- Thank you received: 5018
18 Jun 2014 19:07 #48063
Don't ignore the possibility of using software stepgen on GPIO for things like a toolchanger. Your step rate will only be 1kHz (max 300rpm on the stepper) but it will work and might save on hardware.
Replied by andypugh on topic Any experiencies with 7i76E
- uli12us
19 Jun 2014 03:43 - 19 Jun 2014 03:51 #48088
by uli12us
Replied by uli12us on topic Any experiencies with 7i76E
That with the 1kHz will not be a problem. I have a servo motor with +/- 10V for the toolchain, but because the axe don't need to be synchronous to any other I will change the servo amp for a Gecko 520 iirc. The machine have a doublegrip changer, so I can search the correct tool while the machine is running, therefore a slow speed isn't an issue. With this combination I can build an separate horizontal dividing head, with this I can use long raw material in the machine. At the moment I can take only very short parts because the dividing table is vertically orientated. I think, its easier to find a step/dir driver for a stepper motor, than to search a cheap +/-10V drive with a servomotor.
I fear, thats a potential problem with the processing, because the 7i77 is the important board, but is the second in the chain.
If that its not the problem, I think its a better combination than the 7i80 with a 7i76 and 7i77. 1 Board less, some 100$ cheaper and a little less harness, not really much, only 1 cable from 26 doublerow to D-Sub.
Or is it much better, if I use a 5 or 6i25 Board in the MB. With this I have the problem to solder the 25pin connector. because I must pull the cable through a I think 2" tube, that isn't empty
Last edit: 19 Jun 2014 03:51 by uli12us.
19 Jun 2014 04:12 #48089
If you only have a single stepper and the 7I77 has enough general purpose I/O, a 7I76 is massive overkill
so maybe a 7I80DB+7I77 plus a low cost parallel port breakout for the 7I80DB--> step/dir interface
19 Jun 2014 05:17 #48091
There are step/dir servo drives that might work for you. (Gecko do one, in fact).
Alternatively, Mesa do some digitally-controlled servo drives which are pretty well priced (because they are dumb and offload everything to LinuxCNC)
What type of servo motor is it, and what power rating?
- uli12us
19 Jun 2014 15:55 - 19 Jun 2014 16:42 #48113
by uli12us
PCW; Additional to the one or two step/dir channels I need the complete I/O channels from both boards. In the machine I have two complete Input boards and 1 output board with each 32 channels. And 1 board with only 2 or 3 Inputs, that I can substitute or remove. Mainrotation recognition or similiar.
Andypugh; I want to change the working +/-10V servoamp for a Gecko 520X iirc because a second 7i77 will be 60$ more than a 7i76. And the later added step/dir Driver will be as well cheaper than a +/-10V drive
A 7i76E is 70$ cheaper than a 7i80 and a 7i76
The Servo motor is an axem MC13S 375W DC 64V 7,6A 3000rpm
Last edit: 19 Jun 2014 16:42 by uli12us.
19 Jun 2014 17:07 #48114
Or, possibly the 7i83 to control an analogue servo: store.mesanet.com/index.php?route=produc...83_88&product_id=122
Note that the 7i77 has a Smart-Serial port on board to which you can connect (for example) a 7i70 store.mesanet.com/index.php?route=produc...83_88&product_id=111PCW; Additional to the one or two step/dir channels I need the complete I/O channels from both boards. In the machine I have two complete Input boards and 1 output board with each 32 channels. And 1 board with only 2 or 3 Inputs, that I can substitute or remove. Mainrotation recognition or similiar.
There is store.mesanet.com/index.php?route=produc...83_90&product_id=147 but that would need to connect to one of the 50-pin boards (either a PCI card like the 5i23, a parallel-port card like the 7i90 or possibly the 7i80 (Ethernet connection, but I am not sure how well supported that is)The Servo motor is an axem MC13S 375W DC 64V 7,6A 3000rpm
- uli12us
19 Jun 2014 18:51 #48121
by uli12us
As I say, I need 2 step/dir or analog outputs for toolchain and later a dividing head. The machine itself needs 6 analog channels for x, y, z, b, c and spindle. additionally I need at least 64 DI and 32 DO. All of that I can make with either a 5/6i25, 7i76 and 7i77.
If I change the 5/6i25 for a 7i80 then I have only one small easy placeable cable in my machine and can use any computer I want. Not only a board with PCI(e) connectors. If I change the 7i80 with the 7i76 then I have the same but for a price 10/30$ lower then the combination with 5/6i25.
I know that I can change the 7i76 with the 7i84 but the extra 2axes step/dir will probably cost more, than the saving and I need more harnessing.
I want to change the control from my machine in the simplest, way with as few as possible parts.
Thats primarly, because I think its necessary, that I have from each part a spare part in stock.
Time to create page: 0.201 seconds
