Cheap (economical) Stepper Driver Boards
- jjharley
10 Jan 2015 00:31 #54826
by jjharley
Replied by jjharley on topic Cheap (economical) Stepper Driver Boards
Yes they do go bang, burnt one already on the trail of CNC discovery.
- jjharley
10 Jan 2015 00:34 #54827
by jjharley
Thanks,
I am trying to get away from the 6560 since they are so picky, and I like the fact that the 6600's have the auto reduction to the motor on rest.
- xylotex
- Thank you received: 3
10 Jan 2015 01:23 #54831
by xylotex
Replied by xylotex on topic Cheap (economical) Stepper Driver Boards
The TB6600 have current reduction input pin. As far as I know they do not have *auto* power reduction. You need external circuitry to cause the current reduction line to change. The circuitry can be built in to the drive board though. A simple timing circuit that monitors the STEP line, or, a small processor that can handle several step input lines and activate the appropriate current reduction line for the given axis.
Jeff
Jeff
- Carniflex
19 Jan 2015 16:01 #55159
by Carniflex
Replied by Carniflex on topic Cheap (economical) Stepper Driver Boards
Has anyone used a "new" TB6600 board that is floating around the ebay and aliexpress. It is somewhat smaller PCB than the previous versions and heatsink seems to be connected more properly.
It seems this one does not have the idle current reduction circuitry that was causing problems on the previous versions and TB 6560 boards? Plus it seems to have just a pot resistor for current selection. So if anyone has encountered one in person I would love to hear any comments about it.
http://www.cnczone.com/forums/attachment.php?attachmentid=264896
www.ebay.com/itm/4-5A-TB6600-Axis-CNC-co...&hash=item3cf0bf5802
- pippin88
- Thank you received: 48
07 Feb 2015 20:25 #55776
by pippin88
Replied by pippin88 on topic Cheap (economical) Stepper Driver Boards
I'm *very* impressed with the Leadshine DM556. It's super quiet. Available on aliexpress for ~60USD shipped.
- ArcEye
- Thank you received: 758
07 Feb 2015 20:58 #55778
by ArcEye
I agree, I use nothing but Leadshine drivers, never had any problem with them, you just connect and forget them.
Replied by ArcEye on topic Cheap (economical) Stepper Driver Boards
Time to create page: 0.103 seconds
