how to make my own 2 axis hard ware
- raman00084
05 Aug 2014 00:19 #49496
by raman00084
how to make my own 2 axis hard ware was created by raman00084
how to make two axis hardware in step and direction mode to run lathe x and z axis
kindly send some hardware circuit links
kalyan
kalyan
- Thank you received: 4988
05 Aug 2014 16:43 #49516
Replied by andypugh on topic how to make my own 2 axis hard ware
- raman00084
05 Aug 2014 22:04 #49527
by raman00084
Replied by raman00084 on topic how to make my own 2 axis hard ware
i need a parallel port break out board shematic with limit switches and step and direction pulses
can i get pwm pulses in parallel port when running any program ?
05 Aug 2014 22:07 #49528
It's actually cheaper to buy ready-made.i need a parallel port break out board shematic with limit switches and step and direction pulses
Yes, LinuxCNC has a PWM generator (and encoder counter)can i get pwm pulses in parallel port when running any program ?
The following user(s) said Thank You: raman00084
- raman00084
12 Aug 2014 00:27 #49710
by raman00084
in parallel port how to identify which pin pwm pulses are coming, and where to connect the limit switches for x any z limit any diagram please send, i am planning to make a 2 axis lathe machine using Linux cnc
12 Aug 2014 00:35 #49712
The PWM pulses will come out of whichever pin you have connected the PWM generator to in HAL.
www.linuxcnc.org/docs/html/hal/parallel_port.html
and
www.linuxcnc.org/docs/html/man/man9/pwmgen.9.html
but mainly
www.linuxcnc.org/docs/html/hal/basic_hal.html
and
but mainly
