Input/Output Miscalculation Problem
- Zahnrad Kopf
- Thank you received: 3
14 Aug 2014 01:21 #49828
by Zahnrad Kopf
Ahhaaaaa... just went and looked up Matrix Wiring. Okay. Thanks.
Replied by Zahnrad Kopf on topic Input/Output Miscalculation Problem
Thanks, Andy. Good to know. Are you referring to the membrane type, or the PC board with actual push buttons? .
"Matrix" is a wiring method. Membrane keypads and ordinary keyboards are matrix-wired, but anything else can be too. The switches don't even have to be physically arranged in a matrix to be wired that way.
As it happens I don't have enough buttons for it to be worth the effort, I use (and like) the "Touchy" GUI.
- DaBit
- Thank you received: 35
16 Aug 2014 05:01 - 16 Aug 2014 05:02 #49907
by DaBit
Replied by DaBit on topic Input/Output Miscalculation Problem
I didn't look into it, but I suppose you can do that with 7i77 outputs, inputs and some HAL wizardry too. 6 outputs and 6 inputs would give you the ability to interface 36 pushbuttons.
Last edit: 16 Aug 2014 05:02 by DaBit.
- Thank you received: 4966
16 Aug 2014 06:57 #49910
There isn't much HAL wizardry involved, that is one mode of the matrix_kb HAL component:
www.linuxcnc.org/docs/html/man/man9/matrix_kb.9.html
Replied by andypugh on topic Input/Output Miscalculation Problem
- Zahnrad Kopf
16 Aug 2014 08:31 #49911
by Zahnrad Kopf
That's pretty interesting, Andy. Thanks for pointing it out.
Sure is a lot to learn these days. Simple old Toolbreaker such as myself isn't always up to it as much it seems...
Still, Dave gave me a good smacking and I did re-do my planning of the pendant's hard buttons. Reduced things by half. Down to about 16 momentary switches now. Gonna let up on my unease/mistrust and let soft buttons do the rest.
Thanks.
Thanks.
Time to create page: 0.127 seconds
