7i77 "Software data process modes"
- alan_3301
- Thank you received: 33
16 Sep 2014 03:01 #51203
by alan_3301
7i77 "Software data process modes" was created by alan_3301
Hi, I am interested in using mode 1 to have torque analog input from my servos drives.
The idea is to have a visual meter for servo load.
I haven't really researched how to implement this yet, but It got me wondering.
What is the purpose of mode 2 which includes "field analog voltage" in?
And, is there any reason to not run mode 3 for all situations, except that you lose the digital inputs 0-3 and 16-19?
I may have MPG's in the future, so I want to leave that option open.
Thanks.
Thanks.
- Zahnrad Kopf
16 Sep 2014 05:51 #51211
by Zahnrad Kopf
Replied by Zahnrad Kopf on topic 7i77 "Software data process modes"
Is that how it works, or are those meters just measurements of Amperage Load? I always thought the latter....
- alan_3301
16 Sep 2014 06:22 #51215
by alan_3301
Replied by alan_3301 on topic 7i77 "Software data process modes"
I think the torque and amperage are directly proportional. (not sure)
I was going for a display on the linuxcnc screen with pyvcp, I would guess the physical meters are just ammeters.
- Thank you received: 5255
16 Sep 2014 07:42 #51218
Replied by PCW on topic 7i77 "Software data process modes"
There's no reason not to run mode 3 always if you are not pushing the
maximum update rates (there's a time overhead for every data item transferred )
For normal 1KHz servo loops this is a non-issue
if you want a 4 or more KHz servo thread it may start to matter
you dont lose the digital inputs in any mode (well unless you connect analog inputs or MPGs)
- alan_3301
16 Sep 2014 08:30 #51221
by alan_3301
Thanks.
Do I need to worry about what "field analog voltage" input is for?
I'm guessing no, but was just curious.
16 Sep 2014 09:29 #51223
thats just the field voltage so if you have 24V field voltage you would expect to read 24V there
(and if its dropped to 18V or you have a lot of ripple, you can tell)
Time to create page: 0.065 seconds
