Encoder Wiring question Is GND Needed
- alan_3301
- Thank you received: 33
19 Sep 2014 19:39 #51342
by alan_3301
Encoder Wiring question Is GND Needed was created by alan_3301
I'm having trouble getting linuxcnc to read me servo driver simulated encoder output.
I have wired A /A B /B Z /Z to the 7i77 encoder terminals, but not getting any counts.
+5 and GND are disconnected.
Does encoder GND need to be connected to the drive at all?
I thought being differential outputs, the A /A are referenced to each other?
I have tried checking with a voltmeter between the A /A pins on the drive, while spinning the motor (slowly), but getting nothing.
I have an oscilloscope I will try to get hooked up this weeked to check for sure.
My feeling is I have a problem in the driver settings or the driver itself, just wondering if someone says Yes, the GND must be connected somewhere.
thanks.
thanks.
- dracozny
20 Sep 2014 04:35 - 20 Sep 2014 04:39 #51369
by dracozny
Replied by dracozny on topic Encoder Wiring question Is GND Needed
I hope I read you correctly, if so then the +5v supply and ground must be connected from the encoder to the 7i77 or your encoder is not getting any power as a result. The drive should be inconsequential in this matter.
1 QA0 TO 7I77
2 /QA0 TO 7I77
3 GND FROM 7I77 <---GROUND
4 QB0 TO 7I77
5 /QB0 TO 7I77
6 +5V FROM 7I77 <--- +5
7 IDX0 TO 7I77
8 /IDX0 TO 7I77
1 QA0 TO 7I77
2 /QA0 TO 7I77
4 QB0 TO 7I77
5 /QB0 TO 7I77
7 IDX0 TO 7I77
8 /IDX0 TO 7I77
Last edit: 20 Sep 2014 04:39 by dracozny.
- alan_3301
20 Sep 2014 06:28 #51370
by alan_3301
Replied by alan_3301 on topic Encoder Wiring question Is GND Needed
Thanks.. I guess I should have given more info.
The encoder is powered by the servo drive and uses serial communication.
The drive then has a "simulated" quadrature encoder output.
It has the usual A /A B /B Z /Z and an extra OCZ (open collector output)
I think I know the answer, that is my drive is messed up, or I am overlooking some setting.
I'll keep messing with it and hopefully it will work, otherwise I'll have to sell this 7i77 and get a 7i76
Oh well..
Oh well..
- alan_3301
20 Sep 2014 07:07 #51371
by alan_3301
Ugh... many hours wasted because of a bad cable, I wired up another one and I am getting results now..
Thanks for the help
Thanks for the help
Time to create page: 0.114 seconds
