7i80-DB mesaflash --set ip
- Nick
- Thank you received: 15
08 Nov 2014 02:15 - 08 Nov 2014 02:33 #52910
by Nick
7i80-DB mesaflash --set ip was created by Nick
Hi!
I'm tring to change my 7i80db ip adderss using mesaflash (I\ve got 192.168.1.* inside my local network)
So I'm trying to do
sudo ./mesaflash --device 7i80 --addr 192.168.1.121 --set ip=10.10.10.10
and get the following
./mesaflash: unrecognized option '--set'
dispite that --set option is in the mesaflash --help
What am I doing wrong?
PS the board is found at 192.168.1.121 and even more - it's found by hm2_eth on same ip.
PSS Are there any firmwares like prob_rfx2 or svst for 7i80db?
So I'm trying to do
Last edit: 08 Nov 2014 02:33 by Nick.
- Thank you received: 5291
08 Nov 2014 02:33 - 08 Nov 2014 02:35 #52911
Replied by PCW on topic 7i80-DB mesaflash
Do you have the latest mesaflash? Your command (well slightly modified) works for me:
should work to install on newer linuxcnc distributions
There are not a lot of generic BOB bitfiles for the Ethernet cards yet, I will make a few new ones up today
do you have any specific requests?
pcw@pcw-G41M-Combo:~$ mesaflash --device 7i76e --addr 10.10.10.10 --set ip=10.10.10.8
Board IP updated successfully.
You must power cycle board to load updated eeprom settings.
sudo apt-get install mesaflash
Last edit: 08 Nov 2014 02:35 by PCW.
The following user(s) said Thank You: Nick
- Nick
08 Nov 2014 02:38 #52912
by Nick
Replied by Nick on topic 7i80-DB mesaflash --set ip
I'm using mesaflash from the SUPPORT SOFTWARE of the 7i80 from mesanet.com.
Will try to install it from repo.
I'm not sure right now, some thing usual like Xsteppers Xencoders Xpwmgens will be enough for the first time.
By the way, what are limits on amounts of steppers/encoders/pwm for this card?
The best options are:
whole steppers
half steppers half encoders (+one pwm)
half encoders half pwm
There are not a lot of generic BOB bitfile for the Ethernet cards yet, I will make a few new one up today
whole steppers
- Nick
08 Nov 2014 02:43 #52913
by Nick
I've tried mesaflash that have been installed in the system and it worked!
- PKM
- Thank you received: 3
08 Nov 2014 02:52 #52914
by PKM
Replied by PKM on topic 7i80-DB mesaflash --set ip
Pages 18-19 in the manual?By the way, what are limits on amounts of steppers/encoders/pwm for this card?
08 Nov 2014 02:54 - 08 Nov 2014 02:59 #52915
Replied by PCW on topic 7i80-DB mesaflash --set ip
The xc6slx16 FPGA is pretty large so its not too likely you will run into limitations unless
you have say more than 20 or so stepgens (stepgens are the largest item in your list)
I will make some configs for generic BOBS and some generic stepgen/encoder/PWM configs
Last edit: 08 Nov 2014 02:59 by PCW.
Time to create page: 0.107 seconds
