funuc axis drivers and signals
- fendrrex
01 Dec 2014 12:45 #53559
by fendrrex
funuc axis drivers and signals was created by fendrrex
Hello guys I'm new to the forums I joined because of this form.
fanuc servo drive integration
And wanted to the same for my boards listed below. So lets dive in to this!
Okay so my friend has a old funuc that he told me he is go to toss if i cant get running (iv put months in to fixing to find the controller is crap (OM)).
The axis and spindle drivers still work....
My goal
apparently i am looking for is called the NC Controller to Amplifier Interface documentation as refereed to as in the link above.
meaning
I wish to find /create domination for the funuc control boards listed below "both signals/pin configuration and voltage(logic) levels" above so ii can control the steppers the respective driver boards listed below with a beagle-bone black or other open source controller like an arduino.
board INFO
4th and 5 axis
controllers
both the same
top board A20B-1100-0330/07b
bottom A20B-1003-014/002a
1.2,3 axis
one board
top A20B-1100-0330/04B
bottom A20B-1003-0864/01a
spindle
Top A20B-0008-003/03A
middle A20B-1003-0010/158
Request
can someone with a oscilloscope map out pins or point me in the right direction to find this information?
My goal
meaning
board INFO
4th and 5 axis
controllers
both the same
1.2,3 axis
one board
spindle
Request
- fendrrex
01 Dec 2014 14:48 #53565
by fendrrex
Replied by fendrrex on topic funuc axis drivers and signals
A update "focused on those needing help"
Ok so tracing back to the first link I posted I edited the URL and it redirected me to this page that ill refer to as GE support documentation
I found this PDF by entering my board number and selecting Motion Solutions for Product Family the PDF will be attached to this post just for redundancy
Still to do "me asking for help"
I admit I'm no electrical engineer on page 72 of the linked PDF I found a table of pins and what they are for. My understanding is upsetting me and ill have a word with some of my colleagues when i can but ill have my nose deep in the PDF for a Bit
A side note
Correct me if I am wrong as I don't normally use any kind of forms;
A side note
Warning: Spoiler!
but the idea is kinda like get hub where even if only one person contributes the question solution and middle work is welcome in hope to help other members/users with the same or similar questions in the future? I ask because I wont want anyone to get mad if i proceed with this process
- Thank you received: 4968
03 Dec 2014 05:49 #53618
Which page? (ie, what is the number at the bottom of the page, rather than the page as-rendered by the viewing software)
Replied by andypugh on topic funuc axis drivers and signals
- jCandlish
04 Dec 2014 07:06 - 04 Dec 2014 07:06 #53662
by jCandlish
Replied by jCandlish on topic funuc axis drivers and signals
I am sorry to say that you are faced with a difficult task indeed. I do not think anyone has made much progress in communicating with a FANUC spindle motor. The spindle amp is more complicated than the servo amps.
Good luck!
Good luck!
Last edit: 04 Dec 2014 07:06 by jCandlish.
04 Dec 2014 07:27 #53664
Depending on the motor it might not be all that hard. I know of one person who has run a Fanuc motor with a generic AMC brushless motor drive and the parallel port.
Both Pico and Mesa have interfaces for the AA64 absolute encoders.
- jCandlish
04 Dec 2014 07:45 #53666
by jCandlish
My goal would be to run the spindle motor from the existing FANUC spindle amplifier.
04 Dec 2014 08:07 #53668
So, again I ask, what is the number at the bottom of page "72"?
I don't see a pinout on the page with "72" at the bottom.
- jmelson
- Thank you received: 158
04 Dec 2014 10:38 #53672
by jmelson
simpler encoder, it seems that it may only produce Hall signals or similar info.
The reason is that at the high spindle motor speed, the serial pulse coders would
be too far behind on the position for good commutation.
But, I have never been able to get much info at ALL on the spindle encoder signals.
Jon
Replied by jmelson on topic funuc axis drivers and signals
But, those encoders are used on AXIS motors. The SPINDLE motors seem to have a much
Jon
- jCandlish
04 Dec 2014 15:31 - 04 Dec 2014 15:53 #53679
by jCandlish
There are 3 proprietary communication protocols used in the FANUC A20B series controls.
The signal interface to the servo motor controller is pretty well understood, and is covered in this thread --> linuxcnc.org/hardy/lucid/index.php/frenc...mit=6&start=30#23687
What remains unknown are the PMC <==> Spindle amp protocol and the FANUC i/o link protocol.
Once these two protocols are reverse engineered it will be possible to replace FANUC's shitty old PMC with something modern, powerful and open while still retaining their excellent motors and amplifiers.
I have many times dreamed of a prototype board with the required honda connectors and break-out pads... Something plug compatible with the Series-18 would be a good reversing tool.
Last edit: 04 Dec 2014 15:53 by jCandlish.
Time to create page: 0.066 seconds
