7i76e FPGA questions
- jCandlish
- Thank you received: 4
05 Dec 2014 17:05 #53709
by jCandlish
7i76e FPGA questions was created by jCandlish
What FPGA is used in this board?
Would I be correct to assume that the I/O on the pluggable screw terminals has no SSLBP overhead?
What toolchain is used to compile firmware for this board?
Where can I find a repository with example firmware sourcecode?
_jC
_jC
- Thank you received: 5218
05 Dec 2014 20:35 #53716
Replied by PCW on topic 7i76e FPGA questions
XC6SLX16-FBGA256
Field I/O is accessed over a serial interface so limited to servo thread rates
Xilinx weppack is used for compiling the firmware
The 7i80.zip support file has the firmware sources (linuxcncs hm2-buildbot may have them as well but is not as up-to-date)
Time to create page: 0.045 seconds
