Mod advice 5i25 with cnc step zero3 controller
- Ozcnc
03 Jan 2015 19:26 #54521
by Ozcnc
Mod advice 5i25 with cnc step zero3 controller was created by Ozcnc
I needs some advice in selecting additional driver boards for modifications or workarounds.
I am currently using Mach3 but would like to move to linuxcnc for various reasons.
I have a 5i25 card that I want to used for hardware step gen.
I would like to integrate encoders for following error to stop the program if this happens.
The Zero3 controller as far as I can tell doesn't have inputs for encoders and I would like to know if there is another way of reading encoders.
If possible the option to not do anything to the zero3 controller.
- emcPT
- Thank you received: 139
03 Jan 2015 20:43 - 03 Jan 2015 20:43 #54522
by emcPT
Replied by emcPT on topic Mod advice 5i25 with cnc step zero3 controller
What is exactly the Zero3 controller? What hardware it is?
________________
www.eusurplus,com
________________
www.eusurplus,com
Last edit: 03 Jan 2015 20:43 by emcPT.
- Ozcnc
03 Jan 2015 22:59 #54524
by Ozcnc
Replied by Ozcnc on topic Mod advice 5i25 with cnc step zero3 controller
A Zero3 Controller is sold by CNC-Step.de with there machines.
The controller is almost exactly the same as this one.
www.benezan-electronics.de/manuals/breakout4-en.pdf
Let me know if you need more specifics.
- Thank you received: 5193
04 Jan 2015 00:45 - 04 Jan 2015 00:58 #54525
Replied by PCW on topic Mod advice 5i25 with cnc step zero3 controller
There are already pinouts that match the Benezan breakout board, but you would likely have
to use the second 5I25 I/O connector (header P2) for the encoder interface.
Depending on encoder type and resolution, a standard parallel port breakout
or a fancier encoder breakout board could be used (say a 7I85).
Last edit: 04 Jan 2015 00:58 by PCW. Reason: Use actual punctuation
- Ozcnc
04 Jan 2015 04:18 #54527
by Ozcnc
I like the 7I85.
Would it be better getting the s version.
The encoders that I am looking at are CUI AMT102-V Encoder KIT from Automation Technologies.
