7i77 -> Huanyang
10 years 1 month ago #80779 by cmtunnel
Replied by cmtunnel on topic 7i77 -> Huanyang
I made those changes. Now I'm getting 24v on FOR at the vfd at all times even if linuxcnc is closed....it goes to 0 when I push the cw button in axis...is this correct??
I'm getting control voltage reading in hal config but nothing at the 7i77 yet.
10 years 1 month ago #80780 by PCW
Replied by PCW on topic 7i77 -> Huanyang
I would check this with a Ohmmeter across ENA5+ and ENA5- before ANY wiring is done
If ENA5+ to ENA5- in on (non infinite reading on Ohmmeter) when linuxCNC is not running
you have a damaged OPTO
10 years 1 month ago #80781 by PCW
Sorry I forgot the VFD inpuis are active low inputs with a pullup to 24V so yes thats correct (24V means off at the VFD)
10 years 1 month ago #80785 by cmtunnel
ok thanks. so it looks like its working except I'm not getting my signal out of the 7i77 yet
10 years 1 month ago #80796 by cmtunnel
keep trying things but I'm getting more confused. do you need to see the hal file again??
10 years 1 month ago #80797 by PCW
Sure, post your current HAL and INI files
Moderators: PCW, jmelson
Time to create page: 0.358 seconds
