Mesa 5i25 + 2x7i77 +2x7i84
- REEEN
07 Feb 2015 17:20 #55770
by REEEN
Mesa 5i25 + 2x7i77 +2x7i84 was created by REEEN
Hello Community,
for a bigger milling center, I want to use one 5i25 with two 7i77 one on p3 and the other one on P2 oft the 5i25.
Then two 7i84 connected to the RS 422 ports of each 7i77cards.
My problem is, that one of the 7i84 will not be detected,
I can't find the card connected to the 7i77 on port 2.
Do I need a special config string or something ?
Thank you very much !
- Thank you received: 5217
07 Feb 2015 22:15 #55781
Replied by PCW on topic Mesa 5i25 + 2x7i77 +2x7i84
For this to work you need:
1. 5V to both 7I77s
2. Field power to both 7I84's
3. The correct firmware in the 5I25 (7I77x2)
4. A config string that enables all 6 channels
for example sserial_port_0=000000xxxx or sserial_port_0=302302xxxx
1. 5V to both 7I77s
- REEEN
07 Feb 2015 23:14 #55787
by REEEN
Replied by REEEN on topic Mesa 5i25 + 2x7i77 +2x7i84
Hello; thanks for the fast answer!
I have connected 5V to both cards an jumpered them exact.
Field power is there
I used the PNC conf to set it up with 7i77x2
And I enabled the channels right
If I plug the undetected 7i84 in the other 7i77 it can be found.
Do I have the wrong firmware on the 5i25 ?
How can I change this ?
07 Feb 2015 23:24 - 07 Feb 2015 23:25 #55788
what is your hm2_pci config string? can you post it here?
you can read the firmware pinout with mesaflash and verify that its correct
to read your firmwares pinout you run mesaflash
sudo mesaflash --device 5i25 --readhmid
or to save the output into a file
sudo mesaflash --device 5i25 --readhmid > config.txt
you should be able to post config.txt here
to reprogram the 5i25 you use mesaflash with the -- write option:
sudo mesaflash --device 5i25 -- write 5i25_7i77x2.bit
You may have to power cycle the PC to get the new firmware to load
but if the old firmware was new enough you can use the reload option
sudo mesaflash --device 5i25 --reload
Last edit: 07 Feb 2015 23:25 by PCW.
- REEEN
12 Feb 2015 00:40 #55899
by REEEN
Sorry for the late answer, I was very busy at this time.
here is the config string:
The next thing we are going to do is checking if we have to flash the 5i25.
I will post it here.
Greets Rene
loadrt hm2_pci config=" num_encoders=12 num_pwmgens=0 num_3pwmgens=0 num_stepgens=0 sserial_port_0=00000000 "
Greets Rene
- Thank you received: 4968
12 Feb 2015 21:09 #55915
Replied by andypugh on topic Mesa 5i25 + 2x7i77 +2x7i84
something that might be instructive. With LinuxCNC _not_ running open a terminal.Then copy and paste the output here.
halrun
loadrt hostmot2
loadrt hm2_pci
show all
exit
- REEEN
16 Feb 2015 02:30 #55992
by REEEN
Hello, here is the output of some terminal commands, I tested with mesaflash.
16 Feb 2015 06:52 #55997
Not sure whats going on but perhaps a bad cable (serial or parallel) or bad 7I77
(assuming you dont get a green blinky light on the second 7I84 if you start linuxcnc and you have
a sserial_port_0=000000 token in the hm2_pci config line)
- REEEN
20 Feb 2015 14:23 #56139
by REEEN
Hello,
now we did the following :
-swapped the two 7i77 => same error, 7i84 is missing
-swapped the two 7i84 => same error, 7i84 is missing
-changed out the 5i25 with another one => same error, 7i84 is missing
Then we tried different cables (all of them are tested!)
-Cable 1 => same error, 7i84 is missing
-Cable 2 => another error 7i84 is there and 7i77 is missing
-Cable 3 => all cards are here but if we start the config we get error 13 connection timed out to serial port 3 but green light is still blinking
I don't know what's going on, we checked every cable and all of them are the same and all of them are good and the cable that works best is the longest cable!
EMV can't be a problem either we used the same hardware on the first 7i77 and 7i84 and we never get a problem with them.
I hope someone from Mesa can help us.
Greets and thank you all !
20 Feb 2015 21:26 #56149
Are you powering the 7I77s from the FPGA card?
One possibility is that you have too much 5V drop
So need to power the 7I77s from an external 5V supply
(this requires moving jumpers on both the 7I77 and 5I25 cards)
Time to create page: 0.065 seconds
