Hardware for a 6 axis Puma robot
27 Feb 2015 22:46 #56334 by emcPT
Replied by emcPT on topic Hardware for a 6 axis Puma robot
Ok, now is clear.
The 7i54 would be very "on spot" for your project if you are able to sacrifice a bit of speed.
Maybe PCW jumps in (or ask him directly) and he can inform if you can expect a bit more from the 7i54.
28 Feb 2015 05:03 #56348 by robottom
Replied by robottom on topic Hardware for a 6 axis Puma robot
I could not find the 7i54 on the MESA webstore. How much does this cost? Is this still available?
I did not find any guidance on how to setup the HBridge to adjust the amp part to the servo motor.
I know for the Gecko or the UHU Servo that there is a detailed procedure on how to finetune the settings to work best with the servo motor. Is this not needed for the 7i54?
Many thanks, Thomas
28 Feb 2015 05:06 - 28 Feb 2015 05:09 #56350 by emcPT
www.mesanet.com/pdf/motion/7i54man.pdf
But I also do not know if they are still available.
Last edit: 28 Feb 2015 05:09 by emcPT.
01 Mar 2015 04:34 - 01 Mar 2015 04:39 #56363 by PCW
Replied by PCW on topic Hardware for a 6 axis Puma robot
The 7I54 should be available soon but is quite a bit too small for the Puma
if using analog drives, these are probably pretty close:
www.ebay.com/itm/Advanced-Motion-Control...&hash=item2a374f23ee
Last edit: 01 Mar 2015 04:39 by PCW.
02 Mar 2015 03:22 #56382 by robottom
sounds interesting.
Do you also know what the 7i54 would cost when it is available?
Moderators: PCWjmelson
Time to create page: 0.108 seconds
