TB6600 4 axis setup info?
12 Apr 2015 22:52 #57724 by cwebs
TB6600 4 axis setup info? was created by cwebs
I have a new TB6600 4 axis board and would like some info on setup. Is there a usable setup in the driver list that comes with Linuxcnc to start with. Or just use Stepper Config and play with the numbers? Thanks for any help. Carl
12 Apr 2015 23:20 #57726 by ArcEye
Replied by ArcEye on topic TB6600 4 axis setup info?
There isn't too much to know, there is no special config I am aware of, just use a generic parport one
www.linuxcnc.org/index.php/english/forum...3-configuring-tb6600
Note the warnings, they do not like excess voltage or current
13 Apr 2015 00:59 #57728 by cwebs
Replied by cwebs on topic TB6600 4 axis setup info?
Thank you for the info. I have read everyware that they can go bang very easily. I never run anything at max. not even my boat. I am sneaking up on this board and will be using it on a table top machine I made from stuff under the work bench. Nema 17's at 1 1/2 amps 24 volts. Right now it is running GRBL 4 axes. Thanks, Carl
Moderators: PCWjmelson
Time to create page: 0.053 seconds
