Parallel port 3.3v, any way around this?
20 May 2015 03:02 #58871 by PCW
Be _very_ careful with the 3.3V direct from the PC power supply,
it has almost unlimited current capability and will fry wires, PCB traces, connectors
and fingers that happen to be touching any of those should you make a connection mistake
  • kornphlake
  • kornphlake's Avatar Topic Author
  • Visitor
  • Visitor
20 May 2015 08:03 #58881 by kornphlake
Replied by kornphlake on topic Parallel port 3.3v, any way around this?
I think I remembered to use a current limiting resistor, but it is only 1/4 watt, I should probably addressed that as a long term solution. Thanks for the reminder.
Moderators: PCWjmelson
Time to create page: 0.062 seconds
