integrating sensoray pci card with linuxcnc
19 May 2015 10:29 #58850 by fit2cnc
Hi guys,
Sorry if my english is off the standard as it is not my first language.
I am building a laser printer using galvo
The two component that I am currently using are as below:
- an class 0 galvo that take in +-10V analog voltage
- sensoray 826 PCI interface card
The idea of having the interface card is to allowed output of +- 10V analog voltage as a position control signal for the galvo and also modulation for the laser.
The problem that I could not get my head around are as below:
1) Is there a way to translate the xy coordinate to a signal value that can be sent/read/wire to an PCI interface card so the interface card know what analog voltage to sent to the galvo.
2) and would I need a hal driver so that linuxcnc know how to pass this value to the PCI interface card?
I had install the given driver from sensoray website. When I run 'lsmod' in terminal I could see the module is running but I am not sure how to make linuxcnc talk or sent a signal to the PCI interface card.
Please advise.
19 May 2015 21:44 #58861 by andypugh
Replied by andypugh on topic integrating sensoray pci card with linuxcnc
I had install the given driver from sensoray website. When I run 'lsmod' in terminal I could see the module is running but I am not sure how to make linuxcnc talk or sent a signal to the PCI interface card..
I would be surprised if the supplied driver was a LinuxCNC realtime driver, though it is not impossible.
Do you absolutely have to use the Sensoray card? There are other options for +/- 10V output that already work.
Do you have any documentation for the card or the driver? It can often be surprisingly easy to write a new HAL driver.
20 May 2015 12:46 #58883 by fit2cnc
Replied by fit2cnc on topic integrating sensoray pci card with linuxcnc
Not limited to that card, since I got this card with me, I want to try what I can before moving to alternative as I am aware there are alternative out there.
I know that this would be a challenging task but I am willing to face it, but at the moment I can't seem to progress any further cos I am not sure how to get linuxcnc to sent signal back and forth with this card.
Here's a S826 card Technical Manual can be found on this link: www.sensoray.com/downloads/man_826_hw_3.0.5.pdf
I was worried that it would be difficult task to write a HAL driver.
Where do I start looking into writing HAL driver for this card? :pinch:
20 May 2015 16:15 #58888 by andypugh
The manual you just posted looks like a good start.
The documentation for the hal component generator is here:
linuxcnc.org/docs/html/hal/comp.html
It might be called halcompile on your system, we changed the name.
A HAL driver written in .comp might look a bit like this.
component senso826 "A driver fo the Sensoray 826 board";
description "Only does analog out at the moment";
pin in float analogout-#[8] ;
option extra_setup yes;
option extra_cleanup yes;
function _;
license "GPL";
// This might need the explicit path to the file
#include 826api.h
FUNCTION(_){
int i;
int ret;
u16 v; /
for (i =0 ; i <8 ; i++){
    v = (analogout(i) + 10) *3276.8
    ret =  S826_DacDataWrite(0, i, v, 0);
EXTRA_SETUP(){
    S826_SystemOpen();
EXTRA_CLEANUP(){
   S826_SystemClose();
This is very minimalist, and probably won't work, but shows the basics and might be a basis for elaboration (value checking, more setup, add the DIO, support for boards other than board 0, handle error returns, etc etc.
It is probably worth a try just to see what happens.
21 May 2015 20:09 #58916 by fit2cnc
Thanks andy, that's a good starting point. I am wondering does the linuxcnc dev version matter when I complied the driver and use it in older version of linuxcnc? and does installing linuxcnc-dev in terminal overlap the current linuxcnc I have my pc?
Thanks for the heads up. I know what I need to work on for now. Thanks andy!
27 Jan 2016 20:08 #69165 by TechnoGuru
Replied by TechnoGuru on topic integrating sensoray pci card with linuxcnc
A register map is available for the 826 board here: www.sensoray.com/downloads/man_826_register_map.pdf
A quick review of the their Linux SDK sources indicates they have paid close attention to real-time issues, so I would expect porting to be straightforward. Between the register map, manual and SDK (includes driver and middleware source) there should be sufficient information to port it.
Moderators: PCWjmelson
Time to create page: 0.132 seconds
