mesa 5I20 + 7i48 (WARNING: velocity computation)
- umerov
- Thank you received: 8
23 May 2015 11:50 - 23 May 2015 11:51 #58948
by umerov
mesa 5I20 + 7i48 (WARNING: velocity computation) was created by umerov
Hi
My setup is 5i20 with
1x 7I48 on P2
7i37 on P3
i have config as
loadrt hm2_pci config="firmware=hm2/5i20/SV12IM_2X7I48_72.BIT num_encoders=6 num_pwmgens=6 num_3pwmgens=0 num_stepgens=0
Linuxcnc 2.6.8
to use the 6 encoder inputs & 6 analogs out
dmesg
[ 53.174898] hm2: loading Mesa HostMot2 driver version 0.15
[ 53.180780] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 53.180838] hm2_pci: discovered 5i20 at 0000:03:00.0
[ 53.180951] hm2_5i20.0: firmware: requesting hm2/5i20/SV12IM_2X7I48_72.BIT
[ 53.446232] hm2/hm2_5i20.0: WARNING: this firmware has Muxed Encoder v2!
[ 53.446243] hm2/hm2_5i20.0: WARNING: velocity computation will be incorrect!
[ 53.446249] hm2/hm2_5i20.0: WARNING: upgrade your firmware!
[ 53.462366] hm2/hm2_5i20.0: 72 I/O Pins used:
dpkg --status hostmot2-firmware-5i20 | grep Version
Version: 0.8.21.g5be856c
Servos are works, but I do not like this warning, how to fix it?
1x 7I48 on P2
7i37 on P3
i have config as
Linuxcnc 2.6.8
dmesg
Last edit: 23 May 2015 11:51 by umerov.
- Thank you received: 5217
23 May 2015 21:09 #58955
Replied by PCW on topic mesa 5I20 + 7i48 (WARNING: velocity computation)
Thats a several year old bit file
Try
freeby.mesanet.com/5I20_SV12IM_7I48.zip
Try
- umerov
02 Jun 2015 12:09 #59327
by umerov
Replied by umerov on topic mesa 5I20 + 7i48 (WARNING: velocity computation)
everything works well, thanks
Time to create page: 0.045 seconds
