mesa card for cw5045 drivers
24 May 2015 18:10 #58966 by vre
mesa card for cw5045 drivers was created by vre
I have 3 cw4045 drivers connected to parallel port and iam getting full rapids 5m/min with
10 microstepping but with 10 microstepping steppers are noisy.
If i get a mesa card and set 256 microstepping noise with be less and i will get less vbrations ?
Is a mesa card solution for this ?
24 May 2015 22:08 #58971 by PCW
Replied by PCW on topic mesa card for cw5045 drivers
You could try the parallel port implementation at low speeds to see
how much noise reduction is possible with higher ustep ratios.
In my experience ustep ratios above about 32 usteps/full step do not
show much improvement in lowering noise/vibration.
A hardware stepgen will be smoother in general than the
software stepgen because of the higher base frequency of the hardware stepgen
(between 33 and 100 MHz on mesa cards).
The software stepgen has a highest base frequency of perhaps 100 KHz
(with say 30 KHz to 50 KHz being more typical values) This means that at
high step rates the output step waveform will have a significant energies at beat
frequencies between the step rate and the base frequency. These beats
add to the noise and vibration issues.
The following user(s) said Thank You: vre
25 May 2015 07:52 #58984 by vre
Replied by vre on topic mesa card for cw5045 drivers
I think a 5i25/5i24 will do the job.
Just one more question ..
Is 5i25 db25 compatible with this bob ?
www.ebay.com/itm/5-axis-CNC-Breakout-Boa...-MACH3-/321565835927
it has hc245 for outputs and 5 pc817 optoisolated inputs.
25 May 2015 09:44 - 25 May 2015 09:45 #58986 by PCW
Yes, though it may take a custom config to use all 5 axis for step/dir.
Last edit: 25 May 2015 09:45 by PCW.
Moderators: PCWjmelson
Time to create page: 0.048 seconds
