LinuxCNC with Realtime Ethernet controller
- shengyifine
04 Nov 2015 17:57 #64740
by shengyifine
LinuxCNC with Realtime Ethernet controller was created by shengyifine
Hi all,
I recently saw linuxCNC controller video on youtube。
Anyone who has used this LinxuCNC control cards?
Tks!
Tks!
- ArcEye
- Thank you received: 240
04 Nov 2015 18:09 #64741
by ArcEye
Replied by ArcEye on topic LinuxCNC with Realtime Ethernet controller
The video was only posted a week ago, so I suspect the only person who has used it, is the person who made it.
No info on youtube to guess who that was, so hopefully they will make themselves known
04 Nov 2015 19:45 #64742
Replied by andypugh on topic LinuxCNC with Realtime Ethernet controller
I would hazard a guess at Yishin Li from www.araisrobo.com
- axk
05 Nov 2015 05:39 - 05 Nov 2015 05:40 #64776
by axk
Replied by axk on topic LinuxCNC with Realtime Ethernet controller
edit --- nevermind (my flash is disabled on this machine
Last edit: 05 Nov 2015 05:40 by axk.
- Thank you received: 7501
05 Nov 2015 09:20 #64785
Replied by tommylight on topic LinuxCNC with Realtime Ethernet controller
I would like to give it a try, chances are it is very usable since a lot of data can be moved over a network.
Where can i get one ( or 10
Tom
Tom
- phillc54
- Thank you received: 2100
05 Nov 2015 12:11 - 05 Nov 2015 12:11 #64788
by phillc54
Replied by phillc54 on topic LinuxCNC with Realtime Ethernet controller
Last edit: 05 Nov 2015 12:11 by phillc54.
- shengyifine
05 Nov 2015 15:25 #64795
by shengyifine
Replied by shengyifine on topic LinuxCNC with Realtime Ethernet controller
Hi phillc54,
Thank you for your information,I'd like to try。
BR!
BR!
- zhivko
20 Nov 2015 09:51 #65563
by zhivko
Replied by zhivko on topic LinuxCNC with Realtime Ethernet controller
Have you tried it? How it went? I am also thinking about this...
I think servo with encoder and ethernet should be enough - does such motors exist at all?
23 Nov 2015 23:32 #65721
Yes they do, i have seen and serviced a new Italian manufactured 5 axis machine that used TCP (transmission control protocol - it is what internet works on as communication) on all drives and spindle control. I am very capable in electronic and other stuff, but that machine was a good example of "using really good part to make a bad machine" although the machine works, it messed up after 4 months of light use and needed a 4500 euro parts, but it is by for all intents and purposes unserviceable.
Regards,
Tom
P.S.
Zivko, pa di si kuco stara ???
Regards,
Tom
P.S.
The following user(s) said Thank You: zhivko
- zhivko
26 Nov 2015 08:01 #65813
by zhivko
Can you please describe system - what was the controller, has it supported ethercat?
Do you maybe have some schema of this 5 axis system that you can publish? If not can you just disclose what were the component used?
Time to create page: 0.256 seconds
