5i25 + 7i77 Plug n Go PROBLEM!
07 Nov 2015 08:09 #64939 by PCW
Replied by PCW on topic 5i25 + 7i77 Plug n Go PROBLEM!
Well the firmware looks correct, hmm
CR15 and CR16 are both illuminated
This should never be (red and green at once) unless the card is jumpered for setup mode
did you move the setup/operate mode jumpers?
The following user(s) said Thank You: Sousanator
07 Nov 2015 08:20 #64941 by Sousanator
Replied by Sousanator on topic 5i25 + 7i77 Plug n Go PROBLEM!
Yes for some reason I thought that would be necessary. Well, that issue is gone, but now I'm getting the same error about "scale.spindle.gain". Sadly I don't have any time to look into it as I must go to work!
07 Nov 2015 09:03 #64945 by PCW
Well that's a hal file error of some type, not related to hardware
Moderators: PCWjmelson
Time to create page: 0.303 seconds
