Yes, the sequence you posted is what I expected to see on my system. However, this is not the case.
My setup is actually quite old, SGDM-xxDN (btw, there are no docs for DN models, they don't have a panel operator and are mechatrolink-only) drives from 2003 and JASP-NT001 (looks like an ISA (PC/104) ancestor of JAPMC-NT110). It's running Mechatrolink-I, 4Mbps. Manchester, HDLC etc is of course, the same, NOPs and SMON (30h) are the same too. There are also sync frames (address FF), that divide the communication timeline into transmission cycles. In idle state (after booting up the system) I do get NOPs and SMONs (00 and 30h). Have not looked thoroughly at captures during motion, so this is out of the question for this post.
Finally, the differences are:
1. There's a ton of what looks like garbage inside each transmission cycle. Nonexistent (reserved?) address 00h, control code values all over the place (24, 68, 4F hex etc), all 14 data bytes non-zero and appear to be random, but consistent with control code (i.e. only one data string corresponds to one code, only 2-3 bits vary independent from control code). At first I thought these are just fillers to fill empty space inside transmission cycle (HDLC allows it), my cycle is 2ms with only 6 servos, so there's plenty of time to waste. But the correlation between control codes and data bothers me. And also, why bother filling empty space with any data at all, why not with zeros...
2. There's no clear DISCONNECT -> CONNECT sequence after the master is powered on. I've done proper measurements, i.e. set up a delayed trigger source to skip just the noise present on the bus after powering everything on and then triggred on any edges on the line itself. There's not a single edge before I boot the PC up and log in (it's running Windows + IntervalZero RTX). After login the master just starts sending some nonsensical commands, starting from a random, but this time valid address each startup (e.g. 42h). After about 500 packets everything settles and NOP loop starts (I'll attach a parsed capture). Transmission cycles are also "filled" with nonsensical packets with zero address as described in p.1. 0F [disconnect] and 04h [config] commands seem to be present in the capture, but 0F is always sent to 44h only (just as 1B to 43 etc), so I think this is just a coincedence; and 04 is a part of "filler", sent to 00.
The manuals are not-so-public, official mechatrolink specifications are available for MMA members only, and while the membership is free, they simply don't reply to my emails. And for obscure pieces of gear like my ISA mechatrolink controller, that are only Mechatrolink-I-compliant, I suppose there are no docs left at all... Yaskawa's servopack manuals contain some info on mechatrolink commands, but this info is not always complete. For example, I can't find the I/O field (in SMON) bit layout, and it appears yaskawa didn't follow a reference one (like in "General command specifications for Stepper Motors", that somehow covers servos too). STATUS field bit layout I'm using appears to be partially correct, Main PSU ON bit toggles when it should, but "Zero point" and other homing/motion-related bits are just never toggled (neither after initial homing, nor after manual jog, but the software somehow knows whether homing has been successful or not). All alarm codes I've come across are vendor-specific (>80h), and I've not yet figured out whether mechatrolink alarm codes coincide with error codes, intended to be displayed on panel operator. For example, my servos always (almost) report 99h. Never seen this code in SGDM manuals (may be it means "OK" though?)...
I'm starting to think that Mechatrolink-I had some different connection mechanism.
Attachment: full initialization after power on. The start of the file demonstrates what I described in p.2, and the end of the file corresponds to p.1
