Mesa 5i25 & 7i77 Problem
- ChrisB
04 Dec 2015 19:58 #66407
by ChrisB
Mesa 5i25 & 7i77 Problem was created by ChrisB
Hi
i bought a 5i25 and 7i77 pci card.
The led´s on the 5i25 are blinking for one very short time on startup and then they are off.
I tryed to figure out the problem, but no chance for me.
Just one hardware information.
My mesacard is on the second pci slot because the heatsink of the pcie grapiccard is very high.
For me it looks lite the mesacard is not found.
Here are the linuxcnc debuginformations and the lspci-v
Maybe anybody can tell me the problem.
Thank you very much
lspci-v
Thank you very much
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.0
Machine configuration directory is '/home/cnc/linuxcnc/configs/test'
Machine configuration file is 'test.ini'
INIFILE=/home/cnc/linuxcnc/configs/test/test.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./test.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=3858
Debug file information:
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hm2_pci.ko: No such device
./test.hal:8: exit value: 1
./test.hal:8: insmod for hm2_pci failed, returned -1
See the output of 'dmesg' for more information.
3858
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000003fff0000 (usable)
[ 0.000000] BIOS-e820: 000000003fff0000 - 000000003fff3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000003fff3000 - 0000000040000000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: System manufacturer System Product Name/A8N-SLI, BIOS ASUS A8N-SLI ACPI BIOS Revision 1604 06/06/2006
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x3fff0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C7FFF write-protect
[ 0.000000] C8000-FFFFF uncachable
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0000000000 mask FFC0000000 write-back
[ 0.000000] 1 disabled
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 3652c000 - 3728e000
[ 0.000000] ACPI: RSDP 000f78a0 00014 (v00 Nvidia)
[ 0.000000] ACPI: RSDT 3fff3040 0002C (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: FACP 3fff30c0 00074 (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: DSDT 3fff3180 066BF (v01 NVIDIA AWRDACPI 00001000 MSFT 0100000E)
[ 0.000000] ACPI: FACS 3fff0000 00040
[ 0.000000] ACPI: MCFG 3fff9940 0003C (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] 135MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0003fff0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0003fff0
[ 0.000000] On node 0 totalpages: 262015
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f5d2c200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 272 pages used for memmap
[ 0.000000] HighMem zone: 34530 pages, LIFO batch:7
[ 0.000000] Using APIC driver default
[ 0.000000] Nvidia board detected. Ignoring ACPI timer override.
[ 0.000000] If you got timer trouble try acpi_use_timer_override
[ 0.000000] ACPI: PM-Timer IO Port: 0x4008
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Found and enabled local APIC!
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 40000000 (gap: 40000000:a0000000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77e5000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259967
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=52ffd0f1-7192-47ff-ae51-f8ee2d49581c ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 2096896 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0003fff0)
[ 0.000000] Memory: 1017356k/1048512k available (3495k kernel code, 30704k reserved, 1237k data, 416k init, 139208k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:256 16
[ 0.000000] CPU 0 irqstacks, hard=f5806000 soft=f5808000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1608.150 MHz processor.
[ 0.008002] Calibrating delay loop (skipped), value calculated using timer frequency.. 3216.30 BogoMIPS (lpj=6432600)
[ 0.008009] pid_max: default: 32768 minimum: 301
[ 0.008069] Security Framework initialized
[ 0.008076] AppArmor: AppArmor disabled by boot time parameter
[ 0.008098] Mount-cache hash table entries: 512
[ 0.008347] Initializing cgroup subsys cpuacct
[ 0.008351] Initializing cgroup subsys memory
[ 0.008361] Initializing cgroup subsys devices
[ 0.008365] Initializing cgroup subsys freezer
[ 0.008368] Initializing cgroup subsys net_cls
[ 0.008371] Initializing cgroup subsys blkio
[ 0.008379] Initializing cgroup subsys perf_event
[ 0.008411] mce: CPU supports 5 MCE banks
[ 0.008476] SMP alternatives: switching to UP code
[ 0.012979] Freeing SMP alternatives: 16k freed
[ 0.012989] ACPI: Core revision 20120320
[ 0.017401] ACPI: setting ELCR to 0200 (from 14b8)
[ 0.018825] weird, boot CPU (#0) not listed by the BIOS.
[ 0.018828] SMP motherboard not detected.
[ 0.018833] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.020001] SMP disabled
[ 0.020001] Performance Events: AMD PMU driver.
[ 0.020001] ... version: 0
[ 0.020001] ... bit width: 48
[ 0.020001] ... generic registers: 4
[ 0.020001] ... value mask: 0000ffffffffffff
[ 0.020001] ... max period: 00007fffffffffff
[ 0.020001] ... fixed-purpose events: 0
[ 0.020001] ... event mask: 000000000000000f
[ 0.028028] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.028068] Brought up 1 CPUs
[ 0.028072] Total of 1 processors activated (3216.30 BogoMIPS).
[ 0.028249] devtmpfs: initialized
[ 0.028538] PM: Registering ACPI NVS region [mem 0x3fff0000-0x3fff2fff] (12288 bytes)
[ 0.028663] dummy:
[ 0.028735] NET: Registered protocol family 16
[ 0.028862] node 0 link 0: io port [1000, fffff]
[ 0.028867] TOM: 0000000040000000 aka 1024M
[ 0.028872] node 0 link 0: mmio [e0000000, efffffff]
[ 0.028877] node 0 link 0: mmio [feb00000, fec0ffff]
[ 0.028882] node 0 link 0: mmio [a0000, bffff]
[ 0.028886] node 0 link 0: mmio [40000000, fed3ffff]
[ 0.028891] bus: [00, ff] on node 0 link 0
[ 0.028895] bus: 00 index 0 [io 0x0000-0xffff]
[ 0.028898] bus: 00 index 1 [mem 0x40000000-0xffffffff]
[ 0.028902] bus: 00 index 2 [mem 0xfeb00000-0xfec0ffff]
[ 0.028905] bus: 00 index 3 [mem 0x000a0000-0x000bffff]
[ 0.028945] ACPI: bus type pci registered
[ 0.029025] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.029030] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.029033] PCI: Using MMCONFIG for extended config space
[ 0.029036] PCI: Using configuration type 1 for base access
[ 0.029894] bio: create slab <bio-0> at 0
[ 0.030009] ACPI: Added _OSI(Module Device)
[ 0.030013] ACPI: Added _OSI(Processor Device)
[ 0.030017] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.030020] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.032242] ACPI: EC: Look up EC in DSDT
[ 0.040605] ACPI: Interpreter enabled
[ 0.040617] ACPI: (supports S0 S1 S4 S5)
[ 0.040648] ACPI: Using PIC for interrupt routing
[ 0.049482] ACPI: No dock devices found.
[ 0.049490] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.049567] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.049668] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.049673] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.049677] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.049682] pci_root PNP0A08:00: host bridge window [mem 0x000c0000-0x000dffff] (ignored)
[ 0.049686] pci_root PNP0A08:00: host bridge window [mem 0x40000000-0xfebfffff] (ignored)
[ 0.049690] PCI: root bus 00: hardware-probed resources
[ 0.049740] PCI host bridge to bus 0000:00
[ 0.049744] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.049748] pci_bus 0000:00: root bus resource [mem 0x40000000-0xffffffff]
[ 0.049752] pci_bus 0000:00: root bus resource [mem 0xfeb00000-0xfec0ffff]
[ 0.049756] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.049775] pci 0000:00:00.0: [10de:005e] type 00 class 0x058000
[ 0.049855] pci 0000:00:01.0: [10de:0050] type 00 class 0x060100
[ 0.049886] HPET not enabled in BIOS. You might try hpet=force boot option
[ 0.049901] pci 0000:00:01.1: [10de:0052] type 00 class 0x0c0500
[ 0.049912] pci 0000:00:01.1: reg 10: [io 0xd800-0xd81f]
[ 0.049930] pci 0000:00:01.1: reg 20: [io 0x4c00-0x4c3f]
[ 0.049938] pci 0000:00:01.1: reg 24: [io 0x4c40-0x4c7f]
[ 0.049954] pci 0000:00:01.1: PME# supported from D3hot D3cold
[ 0.049976] pci 0000:00:02.0: [10de:005a] type 00 class 0x0c0310
[ 0.049988] pci 0000:00:02.0: reg 10: [mem 0xd2002000-0xd2002fff]
[ 0.050021] pci 0000:00:02.0: supports D1 D2
[ 0.050024] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.050041] pci 0000:00:02.1: [10de:005b] type 00 class 0x0c0320
[ 0.050053] pci 0000:00:02.1: reg 10: [mem 0xfeb00000-0xfeb000ff]
[ 0.050091] pci 0000:00:02.1: supports D1 D2
[ 0.050094] pci 0000:00:02.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.050120] pci 0000:00:06.0: [10de:0053] type 00 class 0x01018a
[ 0.050144] pci 0000:00:06.0: reg 20: [io 0xf000-0xf00f]
[ 0.050175] pci 0000:00:08.0: [10de:0055] type 00 class 0x010185
[ 0.050186] pci 0000:00:08.0: reg 10: [io 0x09e0-0x09e7]
[ 0.050193] pci 0000:00:08.0: reg 14: [io 0x0be0-0x0be3]
[ 0.050201] pci 0000:00:08.0: reg 18: [io 0x0960-0x0967]
[ 0.050208] pci 0000:00:08.0: reg 1c: [io 0x0b60-0x0b63]
[ 0.050215] pci 0000:00:08.0: reg 20: [io 0xd400-0xd40f]
[ 0.050222] pci 0000:00:08.0: reg 24: [mem 0xd2001000-0xd2001fff]
[ 0.050247] pci 0000:00:09.0: [10de:005c] type 01 class 0x060401
[ 0.050274] pci 0000:00:0a.0: [10de:0057] type 00 class 0x068000
[ 0.050285] pci 0000:00:0a.0: reg 10: [mem 0xd2000000-0xd2000fff]
[ 0.050293] pci 0000:00:0a.0: reg 14: [io 0xc000-0xc007]
[ 0.050322] pci 0000:00:0a.0: supports D1 D2
[ 0.050326] pci 0000:00:0a.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.050345] pci 0000:00:0b.0: [10de:005d] type 01 class 0x060400
[ 0.050379] pci 0000:00:0b.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.050401] pci 0000:00:0c.0: [10de:005d] type 01 class 0x060400
[ 0.050434] pci 0000:00:0c.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.050455] pci 0000:00:0d.0: [10de:005d] type 01 class 0x060400
[ 0.050488] pci 0000:00:0d.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.050509] pci 0000:00:0e.0: [10de:005d] type 01 class 0x060400
[ 0.050541] pci 0000:00:0e.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.050567] pci 0000:00:18.0: [1022:1100] type 00 class 0x060000
[ 0.050598] pci 0000:00:18.1: [1022:1101] type 00 class 0x060000
[ 0.050624] pci 0000:00:18.2: [1022:1102] type 00 class 0x060000
[ 0.050650] pci 0000:00:18.3: [1022:1103] type 00 class 0x060000
[ 0.050701] pci 0000:05:07.0: [0048:0000] type 00 class 0x000000
[ 0.050713] pci 0000:05:07.0: reg 10: [mem 0x00000040-0x0000007f pref]
[ 0.050723] pci 0000:05:07.0: reg 14: [mem 0x00000040-0x0000007f pref]
[ 0.050732] pci 0000:05:07.0: reg 18: [mem 0x00000040-0x0000007f pref]
[ 0.050742] pci 0000:05:07.0: reg 1c: [mem 0x00000040-0x0000007f pref]
[ 0.050752] pci 0000:05:07.0: reg 20: [mem 0x00000040-0x0000007f pref]
[ 0.050761] pci 0000:05:07.0: reg 24: [mem 0x00000040-0x0000007f pref]
[ 0.050799] pci 0000:00:09.0: PCI bridge to [bus 05-05] (subtractive decode)
[ 0.050807] pci 0000:00:09.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.050811] pci 0000:00:09.0: bridge window [mem 0x40000000-0xffffffff] (subtractive decode)
[ 0.050816] pci 0000:00:09.0: bridge window [mem 0xfeb00000-0xfec0ffff] (subtractive decode)
[ 0.050820] pci 0000:00:09.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.050850] pci 0000:00:0b.0: PCI bridge to [bus 04-04]
[ 0.050896] pci 0000:03:00.0: [1002:94c3] type 00 class 0x030000
[ 0.050915] pci 0000:03:00.0: reg 10: [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.050931] pci 0000:03:00.0: reg 18: [mem 0xd1000000-0xd100ffff 64bit]
[ 0.050942] pci 0000:03:00.0: reg 20: [io 0xb000-0xb0ff]
[ 0.050959] pci 0000:03:00.0: reg 30: [mem 0xd0000000-0xd001ffff pref]
[ 0.050984] pci 0000:03:00.0: supports D1 D2
[ 0.051012] pci 0000:03:00.1: [1002:aa10] type 00 class 0x040300
[ 0.051031] pci 0000:03:00.1: reg 10: [mem 0xd1010000-0xd1013fff 64bit]
[ 0.051090] pci 0000:03:00.1: supports D1 D2
[ 0.056017] pci 0000:00:0c.0: PCI bridge to [bus 03-03]
[ 0.056023] pci 0000:00:0c.0: bridge window [io 0xb000-0xbfff]
[ 0.056028] pci 0000:00:0c.0: bridge window [mem 0xd0000000-0xd1ffffff]
[ 0.056034] pci 0000:00:0c.0: bridge window [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.056063] pci 0000:00:0d.0: PCI bridge to [bus 02-02]
[ 0.056098] pci 0000:00:0e.0: PCI bridge to [bus 01-01]
[ 0.056116] pci_bus 0000:00: on NUMA node 0
[ 0.056121] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.056455] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
[ 0.056745] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.104812] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 7 9 *10 11 12 14 15)
[ 0.104891] ACPI: PCI Interrupt Link [LNK2] (IRQs 3 4 5 7 9 10 11 *12 14 15)
[ 0.104963] ACPI: PCI Interrupt Link [LNK3] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.105037] ACPI: PCI Interrupt Link [LNK4] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.105110] ACPI: PCI Interrupt Link [LNK5] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.105185] ACPI: PCI Interrupt Link [LUBA] (IRQs 3 4 5 *7 9 10 11 12 14 15)
[ 0.105257] ACPI: PCI Interrupt Link [LUBB] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.105335] ACPI: PCI Interrupt Link [LMAC] (IRQs *3 4 5 7 9 10 11 12 14 15)
[ 0.105407] ACPI: PCI Interrupt Link [LACI] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.105480] ACPI: PCI Interrupt Link [LMCI] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.105555] ACPI: PCI Interrupt Link [LSMB] (IRQs 3 *4 5 7 9 10 11 12 14 15)
[ 0.105629] ACPI: PCI Interrupt Link [LUB2] (IRQs *3 4 5 7 9 10 11 12 14 15)
[ 0.105701] ACPI: PCI Interrupt Link [LIDE] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.105782] ACPI: PCI Interrupt Link [LSID] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.105864] ACPI: PCI Interrupt Link [LFID] (IRQs 3 4 *5 7 9 10 11 12 14 15)
[ 0.105943] ACPI: PCI Interrupt Link [LPCA] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
[ 0.106045] ACPI: PCI Interrupt Link [APC1] (IRQs 16) *0, disabled.
[ 0.106139] ACPI: PCI Interrupt Link [APC2] (IRQs 17) *0, disabled.
[ 0.106232] ACPI: PCI Interrupt Link [APC3] (IRQs 18) *0, disabled.
[ 0.106325] ACPI: PCI Interrupt Link [APC4] (IRQs 19) *0, disabled.
[ 0.106372] ACPI: PCI Interrupt Link [APC5] (IRQs *16), disabled.
[ 0.106474] ACPI: PCI Interrupt Link [APCF] (IRQs 20 21 22 23) *0, disabled.
[ 0.106579] ACPI: PCI Interrupt Link [APCG] (IRQs 20 21 22 23) *0, disabled.
[ 0.106683] ACPI: PCI Interrupt Link [APCH] (IRQs 20 21 22 23) *0, disabled.
[ 0.106787] ACPI: PCI Interrupt Link [APCJ] (IRQs 20 21 22 23) *0, disabled.
[ 0.106891] ACPI: PCI Interrupt Link [APCK] (IRQs 20 21 22 23) *0, disabled.
[ 0.106995] ACPI: PCI Interrupt Link [APCS] (IRQs 20 21 22 23) *0, disabled.
[ 0.107099] ACPI: PCI Interrupt Link [APCL] (IRQs 20 21 22 23) *0, disabled.
[ 0.107202] ACPI: PCI Interrupt Link [APCZ] (IRQs 20 21 22 23) *0, disabled.
[ 0.107316] ACPI: PCI Interrupt Link [APSI] (IRQs 20 21 22 23) *0, disabled.
[ 0.107429] ACPI: PCI Interrupt Link [APSJ] (IRQs 20 21 22 23) *0, disabled.
[ 0.107541] ACPI: PCI Interrupt Link [APCP] (IRQs 20 21 22 23) *0, disabled.
[ 0.107659] vgaarb: device added: PCI:0000:03:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.107664] vgaarb: loaded
[ 0.107667] vgaarb: bridge control possible 0000:03:00.0
[ 0.107715] PCI: Using ACPI for IRQ routing
[ 0.113733] PCI: pci_cache_line_size set to 64 bytes
[ 0.113749] pci 0000:00:02.1: address space collision: [mem 0xfeb00000-0xfeb000ff] conflicts with PCI Bus #00 [mem 0xfeb00000-0xfec0ffff]
[ 0.113801] pci 0000:05:07.0: no compatible bridge window for [mem 0x00000040-0x0000007f pref]
[ 0.113806] pci 0000:05:07.0: no compatible bridge window for [mem 0x00000040-0x0000007f pref]
[ 0.113810] pci 0000:05:07.0: no compatible bridge window for [mem 0x00000040-0x0000007f pref]
[ 0.113815] pci 0000:05:07.0: no compatible bridge window for [mem 0x00000040-0x0000007f pref]
[ 0.113819] pci 0000:05:07.0: no compatible bridge window for [mem 0x00000040-0x0000007f pref]
[ 0.113824] pci 0000:05:07.0: no compatible bridge window for [mem 0x00000040-0x0000007f pref]
[ 0.113833] Expanded resource reserved due to conflict with PCI Bus #00
[ 0.113837] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[ 0.113841] reserve RAM buffer: 000000003fff0000 - 000000003fffffff
[ 0.114121] pnp: PnP ACPI init
[ 0.114139] ACPI: bus type pnp registered
[ 0.114232] pnp 00:00: [bus 00-ff]
[ 0.114236] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.114240] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.114244] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.114248] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.114252] pnp 00:00: [mem 0x000c0000-0x000dffff window]
[ 0.114256] pnp 00:00: [mem 0x40000000-0xfebfffff window]
[ 0.114325] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.114390] pnp 00:01: [io 0x4000-0x407f]
[ 0.114393] pnp 00:01: [io 0x4080-0x40ff]
[ 0.114397] pnp 00:01: [io 0x4400-0x447f]
[ 0.114401] pnp 00:01: [io 0x4480-0x44ff]
[ 0.114404] pnp 00:01: [io 0x4800-0x487f]
[ 0.114408] pnp 00:01: [io 0x4880-0x48ff]
[ 0.114412] pnp 00:01: [mem 0xa0000000-0x9fffffff disabled]
[ 0.114472] system 00:01: [io 0x4000-0x407f] has been reserved
[ 0.114476] system 00:01: [io 0x4080-0x40ff] has been reserved
[ 0.114481] system 00:01: [io 0x4400-0x447f] has been reserved
[ 0.114486] system 00:01: [io 0x4480-0x44ff] has been reserved
[ 0.114490] system 00:01: [io 0x4800-0x487f] has been reserved
[ 0.114495] system 00:01: [io 0x4880-0x48ff] has been reserved
[ 0.114500] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.115308] pnp 00:02: [io 0x0010-0x001f]
[ 0.115312] pnp 00:02: [io 0x0022-0x003f]
[ 0.115316] pnp 00:02: [io 0x0044-0x005f]
[ 0.115319] pnp 00:02: [io 0x0062-0x0063]
[ 0.115323] pnp 00:02: [io 0x0065-0x006f]
[ 0.115326] pnp 00:02: [io 0x0074-0x007f]
[ 0.115330] pnp 00:02: [io 0x0091-0x0093]
[ 0.115333] pnp 00:02: [io 0x00a2-0x00bf]
[ 0.115337] pnp 00:02: [io 0x00e0-0x00ef]
[ 0.115340] pnp 00:02: [io 0x04d0-0x04d1]
[ 0.115344] pnp 00:02: [io 0x0800-0x087f]
[ 0.115347] pnp 00:02: [io 0x0290-0x0297]
[ 0.115438] system 00:02: [io 0x04d0-0x04d1] has been reserved
[ 0.115443] system 00:02: [io 0x0800-0x087f] has been reserved
[ 0.115447] system 00:02: [io 0x0290-0x0297] has been reserved
[ 0.115452] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.115474] pnp 00:03: [dma 4]
[ 0.115478] pnp 00:03: [io 0x0000-0x000f]
[ 0.115482] pnp 00:03: [io 0x0080-0x0090]
[ 0.115485] pnp 00:03: [io 0x0094-0x009f]
[ 0.115489] pnp 00:03: [io 0x00c0-0x00df]
[ 0.115553] pnp 00:03: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.115572] pnp 00:04: [io 0x0070-0x0073]
[ 0.115577] pnp 00:04: [irq 8]
[ 0.115635] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.115649] pnp 00:05: [io 0x0061]
[ 0.115708] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.115724] pnp 00:06: [io 0x00f0-0x00ff]
[ 0.115728] pnp 00:06: [irq 13]
[ 0.115786] pnp 00:06: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.115984] pnp 00:07: [io 0x03f0-0x03f5]
[ 0.115988] pnp 00:07: [io 0x03f7]
[ 0.115992] pnp 00:07: [irq 6]
[ 0.115995] pnp 00:07: [dma 2]
[ 0.116081] pnp 00:07: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.116599] pnp 00:08: [io 0x0060]
[ 0.116603] pnp 00:08: [io 0x0064]
[ 0.116606] pnp 00:08: [irq 1]
[ 0.116678] pnp 00:08: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.116934] pnp 00:09: [mem 0xe0000000-0xefffffff]
[ 0.117015] system 00:09: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.117020] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.117189] pnp 00:0a: [mem 0x000d1800-0x000d3fff]
[ 0.117193] pnp 00:0a: [mem 0x000f0000-0x000f7fff]
[ 0.117197] pnp 00:0a: [mem 0x000f8000-0x000fbfff]
[ 0.117201] pnp 00:0a: [mem 0x000fc000-0x000fffff]
[ 0.117204] pnp 00:0a: [mem 0x3fff0000-0x3fffffff]
[ 0.117208] pnp 00:0a: [mem 0xffff0000-0xffffffff]
[ 0.117212] pnp 00:0a: [mem 0x00000000-0x0009ffff]
[ 0.117216] pnp 00:0a: [mem 0x00100000-0x3ffeffff]
[ 0.117220] pnp 00:0a: [mem 0xfec00000-0xfec00fff]
[ 0.117224] pnp 00:0a: [mem 0xfee00000-0xfeefffff]
[ 0.117227] pnp 00:0a: [mem 0xfefff000-0xfeffffff]
[ 0.117231] pnp 00:0a: [mem 0xfff80000-0xfff80fff]
[ 0.117235] pnp 00:0a: [mem 0xfff90000-0xfffbffff]
[ 0.117239] pnp 00:0a: [mem 0xfffed000-0xfffeffff]
[ 0.117331] system 00:0a: [mem 0x000d1800-0x000d3fff] has been reserved
[ 0.117336] system 00:0a: [mem 0x000f0000-0x000f7fff] could not be reserved
[ 0.117341] system 00:0a: [mem 0x000f8000-0x000fbfff] could not be reserved
[ 0.117346] system 00:0a: [mem 0x000fc000-0x000fffff] could not be reserved
[ 0.117351] system 00:0a: [mem 0x3fff0000-0x3fffffff] could not be reserved
[ 0.117355] system 00:0a: [mem 0xffff0000-0xffffffff] has been reserved
[ 0.117360] system 00:0a: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.117365] system 00:0a: [mem 0x00100000-0x3ffeffff] could not be reserved
[ 0.117370] system 00:0a: [mem 0xfec00000-0xfec00fff] has been reserved
[ 0.117374] system 00:0a: [mem 0xfee00000-0xfeefffff] has been reserved
[ 0.117379] system 00:0a: [mem 0xfefff000-0xfeffffff] has been reserved
[ 0.117384] system 00:0a: [mem 0xfff80000-0xfff80fff] has been reserved
[ 0.117388] system 00:0a: [mem 0xfff90000-0xfffbffff] has been reserved
[ 0.117393] system 00:0a: [mem 0xfffed000-0xfffeffff] has been reserved
[ 0.117398] system 00:0a: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.117414] pnp: PnP ACPI: found 11 devices
[ 0.117416] ACPI: ACPI bus type pnp unregistered
[ 0.117420] PnPBIOS: Disabled by ACPI PNP
[ 0.154237] Switching to clocksource acpi_pm
[ 0.154289] pci 0000:00:09.0: BAR 15: assigned [mem 0x40000000-0x400fffff pref]
[ 0.154295] pci 0000:00:02.1: BAR 0: assigned [mem 0x40100000-0x401000ff]
[ 0.154301] pci 0000:00:09.0: PCI bridge to [bus 05-05]
[ 0.154308] pci 0000:00:09.0: bridge window [mem 0x40000000-0x400fffff pref]
[ 0.154314] pci 0000:00:0b.0: PCI bridge to [bus 04-04]
[ 0.154322] pci 0000:00:0c.0: PCI bridge to [bus 03-03]
[ 0.154326] pci 0000:00:0c.0: bridge window [io 0xb000-0xbfff]
[ 0.154331] pci 0000:00:0c.0: bridge window [mem 0xd0000000-0xd1ffffff]
[ 0.154337] pci 0000:00:0c.0: bridge window [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.154342] pci 0000:00:0d.0: PCI bridge to [bus 02-02]
[ 0.154350] pci 0000:00:0e.0: PCI bridge to [bus 01-01]
[ 0.154364] pci 0000:00:09.0: setting latency timer to 64
[ 0.154381] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.154385] pci_bus 0000:00: resource 5 [mem 0x40000000-0xffffffff]
[ 0.154389] pci_bus 0000:00: resource 6 [mem 0xfeb00000-0xfec0ffff]
[ 0.154393] pci_bus 0000:00: resource 7 [mem 0x000a0000-0x000bffff]
[ 0.154398] pci_bus 0000:05: resource 2 [mem 0x40000000-0x400fffff pref]
[ 0.154402] pci_bus 0000:05: resource 4 [io 0x0000-0xffff]
[ 0.154406] pci_bus 0000:05: resource 5 [mem 0x40000000-0xffffffff]
[ 0.154410] pci_bus 0000:05: resource 6 [mem 0xfeb00000-0xfec0ffff]
[ 0.154414] pci_bus 0000:05: resource 7 [mem 0x000a0000-0x000bffff]
[ 0.154418] pci_bus 0000:03: resource 0 [io 0xb000-0xbfff]
[ 0.154422] pci_bus 0000:03: resource 1 [mem 0xd0000000-0xd1ffffff]
[ 0.154427] pci_bus 0000:03: resource 2 [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.154508] NET: Registered protocol family 2
[ 0.154586] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.154886] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.155862] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.155862] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.155862] TCP: reno registered
[ 0.155862] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.155862] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.155862] NET: Registered protocol family 1
[ 0.155862] ACPI: PCI Interrupt Link [LUBA] enabled at IRQ 7
[ 0.155862] PCI: setting IRQ 7 as level-triggered
[ 0.155862] ACPI: PCI Interrupt Link [LUB2] enabled at IRQ 3
[ 0.155862] PCI: setting IRQ 3 as level-triggered
[ 0.155862] pci 0000:00:0b.0: Linking AER extended capability
[ 0.155862] pci 0000:00:0c.0: Linking AER extended capability
[ 0.155862] pci 0000:00:0d.0: Linking AER extended capability
[ 0.155862] pci 0000:00:0e.0: Linking AER extended capability
[ 0.155862] PCI: CLS mismatch (32 != 288), using 64 bytes
[ 0.155862] pci 0000:03:00.0: Boot video device
[ 0.155862] Unpacking initramfs...
[ 0.607230] Freeing initrd memory: 13704k freed
[ 0.620715] audit: initializing netlink socket (disabled)
[ 0.620734] type=2000 audit(1449266863.620:1): initialized
[ 0.639084] highmem bounce pool size: 64 pages
[ 0.639091] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.639266] VFS: Disk quotas dquot_6.5.2
[ 0.639299] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.639394] msgmni has been set to 1741
[ 0.639592] alg: No test for stdrng (krng)
[ 0.639624] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.639629] io scheduler noop registered
[ 0.639632] io scheduler deadline registered
[ 0.639650] io scheduler cfq registered (default)
[ 0.639947] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.639979] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.639982] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.640761] GHES: HEST is not enabled!
[ 0.640777] isapnp: Scanning for PnP cards...
[ 0.993525] isapnp: No Plug & Play device found
[ 0.993581] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.994075] Linux agpgart interface v0.103
[ 0.994449] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 0.994452] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 0.995425] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.995547] mousedev: PS/2 mouse device common for all mice
[ 0.995612] rtc_cmos 00:04: RTC can wake from S4
[ 0.995740] rtc_cmos 00:04: rtc core: registered rtc_cmos as rtc0
[ 0.995760] rtc0: alarms up to one year, y3k, 242 bytes nvram
[ 0.995906] TCP: cubic registered
[ 0.995962] NET: Registered protocol family 10
[ 0.996256] Mobile IPv6
[ 0.996260] NET: Registered protocol family 17
[ 0.996266] Registering the dns_resolver key type
[ 0.996320] Using IPI No-Shortcut mode
[ 0.996423] PM: Hibernation image not present or could not be loaded.
[ 0.996440] registered taskstats version 1
[ 0.996753] rtc_cmos 00:04: setting system clock to 2015-12-04 22:07:44 UTC (1449266864)
[ 0.996861] Freeing unused kernel memory: 416k freed
[ 0.997257] Write protecting the kernel text: 3496k
[ 0.997286] Write protecting the kernel read-only data: 984k
[ 1.014816] udevd[45]: starting version 175
[ 1.017842] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.098051] usbcore: registered new interface driver usbfs
[ 1.098092] usbcore: registered new interface driver hub
[ 1.115464] usbcore: registered new device driver usb
[ 1.130364] Floppy drive(s): fd0 is 1.44M
[ 1.131776] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.131844] ehci_hcd 0000:00:02.1: setting latency timer to 64
[ 1.131849] ehci_hcd 0000:00:02.1: EHCI Host Controller
[ 1.131884] ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 1
[ 1.131918] ehci_hcd 0000:00:02.1: debug port 1
[ 1.131926] ehci_hcd 0000:00:02.1: cache line size of 64 is not supported
[ 1.131936] ehci_hcd 0000:00:02.1: irq 3, io mem 0x40100000
[ 1.132199] SCSI subsystem initialized
[ 1.135767] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.140060] ehci_hcd 0000:00:02.1: USB 2.0 started, EHCI 1.00
[ 1.140123] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.140128] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.140132] usb usb1: Product: EHCI Host Controller
[ 1.140135] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.140139] usb usb1: SerialNumber: 0000:00:02.1
[ 1.140314] hub 1-0:1.0: USB hub found
[ 1.140322] hub 1-0:1.0: 10 ports detected
[ 1.140813] forcedeth: Reverse Engineered nForce ethernet driver. Version 0.64.
[ 1.140986] ACPI: PCI Interrupt Link [LMAC] enabled at IRQ 3
[ 1.140996] forcedeth 0000:00:0a.0: setting latency timer to 64
[ 1.147644] FDC 0 is a post-1991 82077
[ 1.151891] libata version 3.00 loaded.
[ 1.191279] ACPI: Fan [FAN] (on)
[ 1.225302] microcode: AMD CPU family 0xf not supported
[ 1.628032] Refined TSC clocksource calibration: 1608.241 MHz.
[ 1.628041] Switching to clocksource tsc
[ 1.664426] forcedeth 0000:00:0a.0: ifname eth0, PHY OUI 0x5043 @ 9, addr 00:15:f2:09:05:08
[ 1.664432] forcedeth 0000:00:0a.0: highdma csum gbit lnktim desc-v3
[ 1.664694] ohci_hcd 0000:00:02.0: setting latency timer to 64
[ 1.664699] ohci_hcd 0000:00:02.0: OHCI Host Controller
[ 1.664719] ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 2
[ 1.664739] ohci_hcd 0000:00:02.0: irq 7, io mem 0xd2002000
[ 1.722034] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.722039] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.722043] usb usb2: Product: OHCI Host Controller
[ 1.722046] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ohci_hcd
[ 1.722049] usb usb2: SerialNumber: 0000:00:02.0
[ 1.722275] hub 2-0:1.0: USB hub found
[ 1.722286] hub 2-0:1.0: 10 ports detected
[ 1.722397] pata_amd 0000:00:06.0: version 0.4.1
[ 1.722456] pata_amd 0000:00:06.0: setting latency timer to 64
[ 1.725857] scsi0 : pata_amd
[ 1.726092] scsi1 : pata_amd
[ 1.726767] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xf000 irq 14
[ 1.726772] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xf008 irq 15
[ 1.726809] ata1: port disabled--ignoring
[ 1.726943] sata_nv 0000:00:08.0: version 3.5
[ 1.727087] ACPI: PCI Interrupt Link [LFID] enabled at IRQ 5
[ 1.727091] PCI: setting IRQ 5 as level-triggered
[ 1.727170] sata_nv 0000:00:08.0: setting latency timer to 64
[ 1.727796] ata2: port disabled--ignoring
[ 1.727813] scsi2 : sata_nv
[ 1.727956] scsi3 : sata_nv
[ 1.728183] ata3: SATA max UDMA/133 cmd 0x9e0 ctl 0xbe0 bmdma 0xd400 irq 5
[ 1.728187] ata4: SATA max UDMA/133 cmd 0x960 ctl 0xb60 bmdma 0xd408 irq 5
[ 2.096016] usb 2-1: new low-speed USB device number 2 using ohci_hcd
[ 2.196020] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.204101] ata3.00: ATA-8: Hitachi HTS542525K9SA00, BBFOC32P, max UDMA/100
[ 2.204107] ata3.00: 488397168 sectors, multi 1: LBA48
[ 2.220094] ata3.00: configured for UDMA/100
[ 2.220223] scsi 2:0:0:0: Direct-Access ATA Hitachi HTS54252 BBFO PQ: 0 ANSI: 5
[ 2.310028] usb 2-1: New USB device found, idVendor=0458, idProduct=000e
[ 2.310032] usb 2-1: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 2.310036] usb 2-1: Product: Genius USB Wheel Mouse
[ 2.310040] usb 2-1: Manufacturer: KYE
[ 2.532018] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.542548] sd 2:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[ 2.542618] sd 2:0:0:0: [sda] Write Protect is off
[ 2.542623] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.542654] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.545620] input: KYE Genius USB Wheel Mouse as /devices/pci0000:00/0000:00:02.0/usb2/2-1/2-1:1.0/input/input1
[ 2.545792] generic-usb 0003:0458:000E.0001: input,hidraw0: USB HID v1.00 Mouse [KYE Genius USB Wheel Mouse] on usb-0000:00:02.0-1/input0
[ 2.545856] usbcore: registered new interface driver usbhid
[ 2.545859] usbhid: USB HID core driver
[ 2.593317] sda: sda1 sda2 < sda5 >
[ 2.593678] sd 2:0:0:0: [sda] Attached SCSI disk
[ 2.601603] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 7.942304] microcode: AMD CPU family 0xf not supported
[ 7.957383] PM: Starting manual resume from disk
[ 7.957389] PM: Hibernation image partition 8:5 present
[ 7.957391] PM: Looking for hibernation image.
[ 7.957600] PM: Image not found (code -22)
[ 7.957603] PM: Hibernation image not present or could not be loaded.
[ 8.048253] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 10.248104] udevd[349]: starting version 175
[ 10.552469] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 10.552479] ACPI: Power Button [PWRB]
[ 10.552591] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 10.552597] ACPI: Power Button [PWRF]
[ 10.616801] i2c i2c-0: nForce2 SMBus adapter at 0x4c00
[ 10.616833] i2c i2c-1: nForce2 SMBus adapter at 0x4c40
[ 10.760798] microcode: AMD CPU family 0xf not supported
[ 11.354193] ACPI: PCI Interrupt Link [LNK2] enabled at IRQ 12
[ 11.354199] PCI: setting IRQ 12 as level-triggered
[ 11.412361] [drm] Initialized drm 1.1.0 20060810
[ 11.595221] [drm] radeon kernel modesetting enabled.
[ 11.610990] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:0c.0/0000:03:00.1/sound/card0/input4
[ 11.616189] ACPI: PCI Interrupt Link [LNK1] enabled at IRQ 10
[ 11.616194] PCI: setting IRQ 10 as level-triggered
[ 11.616524] [drm] initializing kernel modesetting (RV610 0x1002:0x94C3 0x1462:0x1103).
[ 11.616552] [drm] register mmio base: 0xD1000000
[ 11.616555] [drm] register mmio size: 65536
[ 11.617289] ATOM BIOS: 113
[ 11.617327] radeon 0000:03:00.0: VRAM: 256M 0x0000000000000000 - 0x000000000FFFFFFF (256M used)
[ 11.617333] radeon 0000:03:00.0: GTT: 512M 0x0000000010000000 - 0x000000002FFFFFFF
[ 11.620745] [drm] Detected VRAM RAM=256M, BAR=256M
[ 11.620750] [drm] RAM width 64bits DDR
[ 11.620810] [TTM] Zone kernel: Available graphics memory: 446142 kiB
[ 11.620814] [TTM] Zone highmem: Available graphics memory: 515746 kiB
[ 11.620817] [TTM] Initializing pool allocator
[ 11.620846] [drm] radeon: 256M of VRAM memory ready
[ 11.620850] [drm] radeon: 512M of GTT memory ready.
[ 11.620876] [drm] GART: num cpu pages 131072, num gpu pages 131072
[ 11.622140] [drm] radeon: ib pool ready.
[ 11.622986] [drm] Loading RV610 Microcode
[ 12.252081] [drm] PCIE GART of 512M enabled (table at 0x0000000000040000).
[ 12.252168] radeon 0000:03:00.0: WB enabled
[ 12.252173] [drm] fence driver on ring 0 use gpu addr 0x10000c00 and cpu addr 0xff93bc00
[ 12.252179] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 12.252182] [drm] Driver supports precise vblank timestamp query.
[ 12.252208] [drm] radeon: irq initialized.
[ 12.283995] [drm] ring test on 0 succeeded in 1 usecs
[ 12.284217] [drm] ib test on ring 0 succeeded in 0 usecs
[ 12.284930] [drm] Radeon Display Connectors
[ 12.284934] [drm] Connector 0:
[ 12.284937] [drm] VGA
[ 12.284941] [drm] DDC: 0x7e50 0x7e50 0x7e54 0x7e54 0x7e58 0x7e58 0x7e5c 0x7e5c
[ 12.284944] [drm] Encoders:
[ 12.284947] [drm] CRT2: INTERNAL_KLDSCP_DAC2
[ 12.284950] [drm] Connector 1:
[ 12.284952] [drm] DIN
[ 12.284954] [drm] Encoders:
[ 12.284957] [drm] TV1: INTERNAL_KLDSCP_DAC2
[ 12.284960] [drm] Connector 2:
[ 12.284962] [drm] DVI-I
[ 12.284965] [drm] HPD1
[ 12.284968] [drm] DDC: 0x7e40 0x7e40 0x7e44 0x7e44 0x7e48 0x7e48 0x7e4c 0x7e4c
[ 12.284971] [drm] Encoders:
[ 12.284974] [drm] CRT1: INTERNAL_KLDSCP_DAC1
[ 12.284977] [drm] DFP1: INTERNAL_LVTM1
[ 12.284989] [drm] Internal thermal controller with fan control
[ 12.285070] [drm] radeon: power management initialized
[ 12.321483] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 64
[ 12.321525] Raw EDID:
[ 12.321556] 00 ff ff ff ff ff ff 00 07 3f fd 02 28 05 00 00
[ 12.321591] 2a 0c 01 00 08 21 1b 96 e8 09 b0 a0 57 47 98 27
[ 12.321625] 11 50 54 af cf 00 31 40 45 40 61 40 81 40 00 00
[ 12.321660] 00 00 00 00 00 00 d5 09 80 90 20 e0 1d 10 08 60
[ 12.321694] 22 00 21 1b 00 00 00 1e a0 0f 20 00 31 58 1c 20
[ 12.321728] 28 80 14 00 21 1b 00 00 00 1e 64 19 00 40 41 00
[ 12.321762] 26 30 18 88 36 00 21 1b 00 00 00 1e 30 6a 00 98
[ 12.321797] 51 00 2a 40 30 70 13 00 21 1b 00 00 00 1e 00 73
[ 12.352616] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 68
[ 12.352657] Raw EDID:
[ 12.352688] 00 ff ff ff ff ff ff 00 07 3f fd 06 28 05 00 00
[ 12.352794] 2a 0c 01 00 08 21 1b 96 e8 09 b0 a0 57 47 98 27
[ 12.352829] 11 50 54 af cf 00 31 40 45 40 61 40 81 40 00 00
[ 12.352863] 00 00 00 00 00 00 d5 09 80 90 20 e0 1d 10 08 60
[ 12.352907] 22 00 21 1b 00 00 00 1e a0 0f 20 00 31 58 1c 20
[ 12.352951] 28 80 14 00 21 1b 00 00 00 1e 64 19 00 40 41 00
[ 12.352994] 26 30 18 88 36 00 21 1b 00 00 00 1e 30 2a 00 98
[ 12.353038] 51 00 2a 40 30 70 13 00 21 1b 00 00 40 1e 00 73
[ 12.437468] [drm] fb mappable at 0xC0142000
[ 12.437473] [drm] vram apper at 0xC0000000
[ 12.437476] [drm] size 5242880
[ 12.437479] [drm] fb depth is 24
[ 12.437481] [drm] pitch is 5120
[ 12.437639] fbcon: radeondrmfb (fb0) is primary device
[ 12.890140] Console: switching to colour frame buffer device 160x64
[ 12.923133] fb0: radeondrmfb frame buffer device
[ 12.923137] drm: registered panic notifier
[ 12.923148] [drm] Initialized radeon 2.16.0 20080528 for 0000:03:00.0 on minor 0
[ 13.996366] Adding 2095100k swap on /dev/sda5. Priority:-1 extents:1 across:2095100k
[ 14.013451] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 14.251295] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 14.468698] loop: module loaded
[ 16.066655] RPC: Registered named UNIX socket transport module.
[ 16.066660] RPC: Registered udp transport module.
[ 16.066664] RPC: Registered tcp transport module.
[ 16.066666] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 16.112297] FS-Cache: Loaded
[ 16.155362] NFS: Registering the id_resolver key type
[ 16.155399] FS-Cache: Netfs 'nfs' registered for caching
[ 16.162790] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 18.503411] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input5
[ 20.522679] Bluetooth: Core ver 2.16
[ 20.522886] NET: Registered protocol family 31
[ 20.522890] Bluetooth: HCI device and connection manager initialized
[ 20.522894] Bluetooth: HCI socket layer initialized
[ 20.522897] Bluetooth: L2CAP socket layer initialized
[ 20.522905] Bluetooth: SCO socket layer initialized
[ 20.546282] Bluetooth: RFCOMM TTY layer initialized
[ 20.546290] Bluetooth: RFCOMM socket layer initialized
[ 20.546294] Bluetooth: RFCOMM ver 1.11
[ 20.677879] lp: driver loaded but no devices found
[ 20.735738] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 20.735743] Bluetooth: BNEP filters: protocol multicast
[ 20.799962] ppdev: user-space parallel port driver
[ 22.872040] forcedeth 0000:00:0a.0: eth0: no link during initialization
[ 22.872724] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 29.838850] [drm:drm_edid_block_valid] *ERROR* EDID checksum is invalid, remainder is 192
[ 29.838857] Raw EDID:
[ 29.838861] 00 ff ff ff ff ff ff 00 07 3f fd 02 28 05 00 00
[ 29.838864] 2a 0c 01 00 08 21 1b 96 e8 09 b0 a0 57 47 98 27
[ 29.838868] 11 50 54 af cf 00 31 40 45 40 61 40 81 40 00 00
[ 29.838871] 00 00 00 00 00 00 d5 09 80 90 20 e0 1d 10 08 60
[ 29.838874] 22 00 21 1b 00 00 00 1e a0 0f 20 00 31 58 1c 20
[ 29.838877] 28 80 14 00 21 1b 00 00 40 1e 64 19 00 40 41 00
[ 29.838880] 26 30 18 88 36 00 21 1b 00 00 00 1e 30 2a 00 98
[ 29.838884] 51 00 2a 40 30 70 93 00 21 1b 00 00 00 1e 00 73
[ 72.607830] I-pipe: head domain RTAI registered.
[ 72.607839] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 72.607849] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 72.607854] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12564314, CLK_FREQ 1608150000, CPU_FREQ 1608150000
[ 72.607859] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 72.607863] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12564314, 12564314, 7573500
[ 72.682200] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 72.682254] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 72.682260] RTAI[sched]: hard timer type/freq = APIC/12564314(Hz); default timing: oneshot; linear timed lists.
[ 72.682266] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1608150000 hz.
[ 72.682269] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 72.718232] RTAI[math]: loaded.
[ 73.078812] hm2: loading Mesa HostMot2 driver version 0.15
[ 73.129319] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 73.581066] hm2: unloading
[ 75.741999] RTAI[math]: unloaded.
[ 75.744383] SCHED releases registered named ALIEN PEDV$D
[ 75.751964] RTAI[malloc]: unloaded.
[ 75.848072] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 75.850214] I-pipe: head domain RTAI unregistered.
[ 75.850228] RTAI[hal]: unmounted.
[ 6763.639403] I-pipe: head domain RTAI registered.
[ 6763.639413] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 6763.639422] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 6763.639428] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12564314, CLK_FREQ 1608150000, CPU_FREQ 1608150000
[ 6763.639432] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 6763.639437] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12564314, 12564314, 12527000
[ 6763.654392] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 6763.654446] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 6763.654452] RTAI[sched]: hard timer type/freq = APIC/12564314(Hz); default timing: oneshot; linear timed lists.
[ 6763.654457] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1608150000 hz.
[ 6763.654461] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 6763.666647] RTAI[math]: loaded.
[ 6763.849337] hm2: loading Mesa HostMot2 driver version 0.15
[ 6763.852362] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 6764.133903] hm2: unloading
[ 6766.263619] RTAI[math]: unloaded.
[ 6766.266087] SCHED releases registered named ALIEN PEDV$D
[ 6766.273538] RTAI[malloc]: unloaded.
[ 6766.372016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 6766.374155] I-pipe: head domain RTAI unregistered.
[ 6766.374170] RTAI[hal]: unmounted.
[ 7021.695957] I-pipe: head domain RTAI registered.
[ 7021.695966] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 7021.695975] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 7021.695981] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12564314, CLK_FREQ 1608150000, CPU_FREQ 1608150000
[ 7021.695986] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 7021.695991] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12564314, 12564314, 12527250
[ 7021.711017] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 7021.711073] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 7021.711079] RTAI[sched]: hard timer type/freq = APIC/12564314(Hz); default timing: oneshot; linear timed lists.
[ 7021.711085] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1608150000 hz.
[ 7021.711088] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 7021.723211] RTAI[math]: loaded.
[ 7021.906704] hm2: loading Mesa HostMot2 driver version 0.15
[ 7021.909601] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 7022.193994] hm2: unloading
[ 7024.327720] RTAI[math]: unloaded.
[ 7024.330161] SCHED releases registered named ALIEN PEDV$D
[ 7024.338255] RTAI[malloc]: unloaded.
[ 7024.436017] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 7024.438499] I-pipe: head domain RTAI unregistered.
[ 7024.438513] RTAI[hal]: unmounted.lspci-v
lspci -v
00:00.0 Memory controller: NVIDIA Corporation CK804 Memory Controller (rev a3)
Subsystem: ASUSTeK Computer Inc. A8N-E Mainboard
Flags: bus master, 66MHz, fast devsel, latency 0
Capabilities: <access denied>
00:01.0 ISA bridge: NVIDIA Corporation CK804 ISA Bridge (rev f3)
Subsystem: ASUSTeK Computer Inc. K8N4-E or A8N-E Mainboard
00:01.1 SMBus: NVIDIA Corporation CK804 SMBus (rev a2)
Flags: 66MHz, fast devsel, IRQ 4
I/O ports at d800 [size=32]
I/O ports at 4c00 [size=64]
I/O ports at 4c40 [size=64]
Kernel driver in use: nForce2_smbus
00:02.0 USB controller: NVIDIA Corporation CK804 USB Controller (rev a2) (prog-if 10 [OHCI])
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 7
Memory at d2002000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: ohci_hcd
00:02.1 USB controller: NVIDIA Corporation CK804 USB Controller (rev a3) (prog-if 20 [EHCI])
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 3
Memory at 40100000 (32-bit, non-prefetchable) [size=256]
Kernel driver in use: ehci_hcd
00:06.0 IDE interface: NVIDIA Corporation CK804 IDE (rev f2) (prog-if 8a [Master SecP PriP])
[virtual] Memory at 000001f0 (32-bit, non-prefetchable) [size=8]
[virtual] Memory at 000003f0 (type 3, non-prefetchable) [size=1]
[virtual] Memory at 00000170 (32-bit, non-prefetchable) [size=8]
[virtual] Memory at 00000370 (type 3, non-prefetchable) [size=1]
I/O ports at f000 [size=16]
Kernel driver in use: pata_amd
00:08.0 IDE interface: NVIDIA Corporation CK804 Serial ATA Controller (rev f3) (prog-if 85 [Master SecO PriO])
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 5
I/O ports at 09e0 [size=8]
I/O ports at 0be0 [size=4]
I/O ports at 0960 [size=8]
I/O ports at 0b60 [size=4]
I/O ports at d400 [size=16]
Memory at d2001000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: sata_nv
00:09.0 PCI bridge: NVIDIA Corporation CK804 PCI Bridge (rev f2) (prog-if 01 [Subtractive decode])
Bus: primary=00, secondary=05, subordinate=05, sec-latency=128
Prefetchable memory behind bridge: 40000000-400fffff
00:0a.0 Bridge: NVIDIA Corporation CK804 Ethernet Controller (rev f3)
Memory at d2000000 (32-bit, non-prefetchable) [size=4K]
I/O ports at c000 [size=8]
Kernel driver in use: forcedeth
00:0b.0 PCI bridge: NVIDIA Corporation CK804 PCIE Bridge (rev f3) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Kernel driver in use: pcieport
00:0c.0 PCI bridge: NVIDIA Corporation CK804 PCIE Bridge (rev f3) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 0000b000-0000bfff
Memory behind bridge: d0000000-d1ffffff
Prefetchable memory behind bridge: 00000000c0000000-00000000cfffffff
00:0d.0 PCI bridge: NVIDIA Corporation CK804 PCIE Bridge (rev f3) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
00:0e.0 PCI bridge: NVIDIA Corporation CK804 PCIE Bridge (rev a3) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
Flags: fast devsel
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
Flags: fast devsel
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
Flags: fast devsel
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
Flags: fast devsel
Kernel driver in use: k8temp
03:00.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI RV610 video device [Radeon HD 2400 PRO] (prog-if 00 [VGA controller])
Subsystem: Micro-Star International Co., Ltd. Device 1103
Flags: bus master, fast devsel, latency 0, IRQ 10
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at d1000000 (64-bit, non-prefetchable) [size=64K]
I/O ports at b000 [size=256]
Expansion ROM at d0000000 [disabled] [size=128K]
Kernel driver in use: radeon
03:00.1 Audio device: Advanced Micro Devices [AMD] nee ATI RV610 HDMI Audio [Radeon HD 2350/2400 Series]
Subsystem: Micro-Star International Co., Ltd. Device aa10
Flags: bus master, fast devsel, latency 0, IRQ 12
Memory at d1010000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
05:07.0 Non-VGA unclassified device: Device 0048:0000 (rev 48)
Subsystem: Device 0048:0000
Flags: fast devsel
Memory at <ignored> (32-bit, prefetchable) [disabled]
Expansion ROM at <unassigned> [disabled]Please Log in or Create an account to join the conversation.
- Thank you received: 5326
04 Dec 2015 20:41 #66413
Replied by PCW on topic Mesa 5i25 & 7i77 Problem
Looks like the card is not found, it may be a slot issue especially if this is an older motherboard
that had the slot vacant for a long time.
You can try cleaning the slot and 5I25 contact fingers and seeing if the card is recognized
easiest way I have found to clean MB slots is to find a piece of card stock, and dip it in 99% isopropyl alcohol
and slide it several times in and out of the PCI slot
- ChrisB
05 Dec 2015 15:26 - 05 Dec 2015 15:29 #66457
by ChrisB
Replied by ChrisB on topic Mesa 5i25 & 7i77 Problem
Hi
thank you for your response
today i tried another computer
i attached the depug and lspci -v
it is not the same error. But i don´t understand it.
thank your for your help
Last edit: 05 Dec 2015 15:29 by ChrisB.
05 Dec 2015 16:37 #66466
The card was found but it has the wrong firmware for a 7I77 (it looks like it has 7I76 firmware installed)
To fix, the card must be flashed with the correct firmware:
sudo mesaflash --device 5i25 --write 5i25_7i77x2.bit
sudo mesaflash --device 5i25 --reload
You may need to install mesaflash if its not already installed:
sudo apt-get install mesaflash
The following user(s) said Thank You: ChrisB
- ChrisB
05 Dec 2015 17:12 #66469
by ChrisB
You are absoluetly great.
Thank you.
Now it works.
Thank you.
Now it works.
- DeckelHead
10 Dec 2017 20:48 #102880
by DeckelHead
Replied by DeckelHead on topic Mesa 5i25 & 7i77 Problem
I'm finally getting back on track with my LinuxCNC installation. While I'm trying to figure out why the latest ISO isn't capable of being successfully written to a a USB stick with dd (separate issue), I'm working on testing my hardware using an old version of LinuxCNC. I performed the following:
After that, I can toggle CR1 and CR2 on the 5i25 board without a problem. On the 7i77 board, I have the field LED lit so I'm good there. However, when I try to toggle the output ports that power my relays, I have no luck. The power at the terminals remains 0V. I can see the TRUE/FALSE change after I execute show pins after the setp command, so I know the operation is executed (and there were no errors, of course).
What I also see, though, is no flashing on the 7i77's CR15 (activity) and CR16 (fault) is ON. Per the manual, and per logical assessment, the watchdog is tripped and the outputs are prevented from sourcing. There are two things I don't understand though. First, based on a previous post near the start of this thread, it sounds like the commands issues should pet the watchdog (causing CR15 to flash and CR16 to go out). I don't see that. The second question, is if that assumption is incorrect, how do I disable the watchdog temporarily? At this point I just want to check the I/O of the Mesa board. My amps aren't even given drive power so there is no way they can move.
Thanks,
Alan
halrun
loadrt hostmot2
loadrt hm2_pci
loadrt threads
addf hm2_5i25.0.read thread1
addf hm2_5i25.0.write thread1
startAfter that, I can toggle CR1 and CR2 on the 5i25 board without a problem. On the 7i77 board, I have the field LED lit so I'm good there. However, when I try to toggle the output ports that power my relays, I have no luck. The power at the terminals remains 0V. I can see the TRUE/FALSE change after I execute show pins after the setp command, so I know the operation is executed (and there were no errors, of course).
Thanks,
Alan
10 Dec 2017 21:19 #102882
Pretty sure you need a real hal file to test sserial I/O
- DeckelHead
10 Dec 2017 23:25 #102884
by DeckelHead
I messed up... I my reference to the earlier post was actually in a different thread:
forum.linuxcnc.org/27-driver-boards/3045...77-first-steps#70656
Anyhow, it seems like it would be a 'normal' thing to do, disabling the watchdog so one could toggle output bits, read inputs, etc. That would all be part of a new machine checkout, to me... I also am not too sure what you mean by a 'real HAL file' and if I am testing with serial I/O. Does my testing work classify as that?
Thank you for your help. I definitely appreciate it. I'm pretty sure it won't be the last set of questions, LOL.
11 Dec 2017 00:21 #102885
I think the timing of startup is pretty picky (whats the timing of the thread with halrun?)
There are 3 watchdogs involved (the host FPGA card and the 2 sserial remotes watchogs)
Its really a safety issue to have the watchdogs running so disabling them
is not something we suggest doing. If you want to toggle I/O, you can setup a minimal
hal file with watchdogs setup and toggle/check I/O with halcmd
- DeckelHead
11 Dec 2017 00:55 #102887
by DeckelHead
Hi PCW,
I can certainly understand not wanting to run without watchdogs. In this case, however, I don't even have power to the servo amplifiers. I'm really just wanting to verify that I can turn on/off the relays (which won't do anything because nothing else is power on the machine, only the CPU) and read some of the inputs. So, safety isn't a concern at all here.
Unfortunately, my knowledge of LinuxCNC is not strong enough to know how to create a minimal HAL file or use halcmd. I was just trying to follow through some of the suggested steps in the other thread as it seemed to give instructions on how one could test the I/O section(s) of the system. That uses halrun. I'll have to read up on the other HAL stuff.
Time to create page: 0.148 seconds
