L298 how to connect ...
- Skovholm
25 Dec 2015 07:54 #67310
by Skovholm
L298 how to connect ... was created by Skovholm
Hi
I am new to LinuxCNC ..
Did install and run the first test and now i want to put some small steppers on with a little board with L298 on.
www.ebay.com/itm/Dual-H-Bridge-Stepper-M...d:g:PKIAAOSwyZ5UoNkS
I have been searching the internet for 2 days now for a schematic how to connect and how to set up hal ...
can anyone help ?
Hjalmar
can anyone help ?
Hjalmar
- Thank you received: 7450
26 Dec 2015 01:23 - 26 Dec 2015 01:26 #67330
Replied by tommylight on topic L298 how to connect ...
That driver does not have current limiting so be careful using it. You will need to work with 5V or it will burn, depending on the motor attached to it.
As for using it, serch for tommylight on this forum, i did an how to build the cheapest drivers possible for use with Linuxcnc, and there you have the configs ready made, they do work with the driver you have.
Ok here it is
forum.linuxcnc.org/forum/27-driver-board...r-drives-for-diy-ers
You also have info on doing current limiting that you have to use with your drive to protect them.
Just noticed, the files are missing on that post, will upload them now if i can find them.
Regards,
Tom
Ok here it is
Regards,
Tom
Last edit: 26 Dec 2015 01:26 by tommylight. Reason: attached files
- Skovholm
27 Dec 2015 19:52 #67381
by Skovholm
Replied by Skovholm on topic L298 how to connect ...
HI
Thanks ....you did make my day ...now working ...will make a post so others can learn from that also ..
Hjalmar
Hjalmar
28 Dec 2015 01:00 #67385
Glad you made it work.
Tom
Tom
Time to create page: 0.099 seconds
