6i25 + 7i76 hm2/hm2_5i25: unregistered
- bkt
- Thank you received: 114
04 Jan 2016 16:51 #67850
by bkt
6i25 + 7i76 hm2/hm2_5i25: unregistered was created by bkt
my dmesg.....
somethings is wrong ..... I need some driver for starting with my 6i25 card?? These pc is for test and yesterday I have installed an 5i25 fgpa .... I need to make some type of file cleaning??
Regards
Giorgio
Warning: Spoiler!
[ 8.328190] CPU1 attaching NULL sched-domain.
[ 8.328191] CPU2 attaching NULL sched-domain.
[ 8.328193] CPU3 attaching NULL sched-domain.
[ 8.352162] CPU0 attaching sched-domain:
[ 8.352165] domain 0: span 0,2 level SIBLING
[ 8.352167] groups: 0 (cpu_power = 589) 2 (cpu_power = 589)
[ 8.352172] domain 1: span 0-3 level MC
[ 8.352174] groups: 0,2 (cpu_power = 1178) 1,3 (cpu_power = 1178)
[ 8.352179] CPU1 attaching sched-domain:
[ 8.352181] domain 0: span 1,3 level SIBLING
[ 8.352183] groups: 1 (cpu_power = 589) 3 (cpu_power = 589)
[ 8.352186] domain 1: span 0-3 level MC
[ 8.352188] groups: 1,3 (cpu_power = 1178) 0,2 (cpu_power = 1178)
[ 8.352193] CPU2 attaching sched-domain:
[ 8.352194] domain 0: span 0,2 level SIBLING
[ 8.352195] groups: 2 (cpu_power = 589) 0 (cpu_power = 589)
[ 8.352199] domain 1: span 0-3 level MC
[ 8.352201] groups: 0,2 (cpu_power = 1178) 1,3 (cpu_power = 1178)
[ 8.352205] CPU3 attaching sched-domain:
[ 8.352207] domain 0: span 1,3 level SIBLING
[ 8.352208] groups: 3 (cpu_power = 589) 1 (cpu_power = 589)
[ 8.352212] domain 1: span 0-3 level MC
[ 8.352214] groups: 1,3 (cpu_power = 1178) 0,2 (cpu_power = 1178)
[ 2022.547151] I-pipe: Domain RTAI registered.
[ 2022.547155] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 2022.547157] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 2022.547200] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 2022.547202] PIPELINE layers:
[ 2022.547203] f82b2e20 9ac15d93 RTAI 200
[ 2022.547205] c085cb20 0 Linux 100
[ 2022.555751] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 2022.555844] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 2022.555846] RTAI[sched]: hard timer type/freq = APIC/6235530(Hz); default timing: periodic; linear timed lists.
[ 2022.555848] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591649000 hz.
[ 2022.555849] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 2022.555879] RTAI[usi]: enabled.
[ 2022.568601] RTAI[math]: loaded.
[ 2022.620837] hm2: loading Mesa HostMot2 driver version 0.15
[ 2022.622549] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 2022.622572] hm2_pci 0000:06:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 2022.622574] hm2_pci: discovered 5i25 at 0000:06:00.0
[ 2022.622911] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 2022.678088] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 2022.678090] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 2022.678091] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 2022.678092] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 2022.678093] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 2022.678094] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 2022.678095] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 2022.678096] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 2022.678097] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 2022.678099] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 2022.678100] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 2022.678102] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 2022.678103] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 2022.678104] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 2022.678105] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 2022.678106] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 2022.678107] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 2022.678108] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 2022.678109] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 2022.678110] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 2022.678111] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 2022.678112] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 2022.678113] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 2022.678114] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 2022.678115] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 2022.678116] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 2022.678117] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 2022.678118] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 2022.678119] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 2022.678120] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 2022.678121] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 2022.678122] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 2022.678123] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 2022.678124] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 2022.678125] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 2022.678154] hm2/hm2_5i25.0: registered
[ 2022.678155] hm2_5i25.0: initialized AnyIO board at 0000:06:00.0
[ 2022.787625] hm2_5i25.0: dropping AnyIO board at 0000:06:00.0
[ 2022.787627] hm2/hm2_5i25.0: unregistered
[ 2022.787638] hm2_pci 0000:06:00.0: PCI INT A disabled
[ 2022.787647] hm2_pci: driver unloaded
[ 2022.788681] hm2: unloading
[ 2024.850506] RTAI[math]: unloaded.
[ 2024.858482] SCHED releases registered named ALIEN RTGLBH
[ 2024.923255] RTAI[malloc]: unloaded.
[ 2025.023101] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 2025.024030] I-pipe: Domain RTAI unregistered.
[ 2025.024087] RTAI[hal]: unmounted.
[ 3425.852792] I-pipe: Domain RTAI registered.
[ 3425.852795] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 3425.852797] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 3425.852841] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3425.852842] PIPELINE layers:
[ 3425.852843] f88e0e20 9ac15d93 RTAI 200
[ 3425.852844] c085cb20 0 Linux 100
[ 3425.860329] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3425.860437] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 3425.860439] RTAI[sched]: hard timer type/freq = APIC/6235530(Hz); default timing: periodic; linear timed lists.
[ 3425.860441] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591649000 hz.
[ 3425.860442] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 3425.860553] RTAI[usi]: enabled.
[ 3425.872000] RTAI[math]: loaded.
[ 3425.915291] hm2: loading Mesa HostMot2 driver version 0.15
[ 3425.916373] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 3425.916396] hm2_pci 0000:06:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 3425.916399] hm2_pci: discovered 5i25 at 0000:06:00.0
[ 3425.916780] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 3425.971832] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 3425.971833] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 3425.971835] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 3425.971836] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 3425.971837] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 3425.971838] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 3425.971839] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 3425.971840] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 3425.971841] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 3425.971843] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 3425.971844] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 3425.971845] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 3425.971847] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 3425.971848] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 3425.971849] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 3425.971850] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 3425.971851] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 3425.971852] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 3425.971853] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 3425.971854] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 3425.971855] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 3425.971856] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 3425.971857] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 3425.971858] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 3425.971859] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 3425.971860] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 3425.971861] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 3425.971862] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 3425.971863] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 3425.971864] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 3425.971865] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 3425.971866] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 3425.971867] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 3425.971868] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 3425.971869] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 3425.971898] hm2/hm2_5i25.0: registered
[ 3425.971899] hm2_5i25.0: initialized AnyIO board at 0000:06:00.0
[ 3426.077260] hm2_5i25.0: dropping AnyIO board at 0000:06:00.0
[ 3426.077263] hm2/hm2_5i25.0: unregistered
[ 3426.077278] hm2_pci 0000:06:00.0: PCI INT A disabled
[ 3426.077290] hm2_pci: driver unloaded
[ 3426.078346] hm2: unloading
[ 3428.137043] RTAI[math]: unloaded.
[ 3428.142221] SCHED releases registered named ALIEN RTGLBH
[ 3428.207225] RTAI[malloc]: unloaded.
[ 3428.303092] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3428.304048] I-pipe: Domain RTAI unregistered.
[ 3428.304104] RTAI[hal]: unmounted.
[ 3511.215476] I-pipe: Domain RTAI registered.
[ 3511.215479] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 3511.215480] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 3511.215528] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3511.215529] PIPELINE layers:
[ 3511.215531] f8f75e20 9ac15d93 RTAI 200
[ 3511.215532] c085cb20 0 Linux 100
[ 3511.222748] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3511.222941] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 3511.222944] RTAI[sched]: hard timer type/freq = APIC/6235530(Hz); default timing: periodic; linear timed lists.
[ 3511.222945] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591649000 hz.
[ 3511.222946] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 3511.222977] RTAI[usi]: enabled.
[ 3511.237577] RTAI[math]: loaded.
[ 3511.281322] hm2: loading Mesa HostMot2 driver version 0.15
[ 3511.282489] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 3511.282510] hm2_pci 0000:06:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 3511.282511] hm2_pci: discovered 5i25 at 0000:06:00.0
[ 3511.282884] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 3511.338028] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 3511.338029] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 3511.338030] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 3511.338032] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 3511.338033] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 3511.338034] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 3511.338035] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 3511.338036] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 3511.338037] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 3511.338039] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 3511.338040] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 3511.338042] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 3511.338043] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 3511.338044] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 3511.338045] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 3511.338046] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 3511.338047] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 3511.338048] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 3511.338049] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 3511.338050] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 3511.338051] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 3511.338052] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 3511.338053] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 3511.338054] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 3511.338055] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 3511.338056] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 3511.338057] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 3511.338058] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 3511.338059] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 3511.338060] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 3511.338061] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 3511.338062] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 3511.338063] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 3511.338064] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 3511.338065] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 3511.338094] hm2/hm2_5i25.0: registered
[ 3511.338095] hm2_5i25.0: initialized AnyIO board at 0000:06:00.0
[ 3511.438978] hm2_5i25.0: dropping AnyIO board at 0000:06:00.0
[ 3511.438981] hm2/hm2_5i25.0: unregistered
[ 3511.438992] hm2_pci 0000:06:00.0: PCI INT A disabled
[ 3511.439002] hm2_pci: driver unloaded
[ 3511.439918] hm2: unloading
[ 3513.498743] RTAI[math]: unloaded.
[ 3513.507098] SCHED releases registered named ALIEN RTGLBH
[ 3513.572067] RTAI[malloc]: unloaded.
[ 3513.670929] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3513.671902] I-pipe: Domain RTAI unregistered.
[ 3513.671959] RTAI[hal]: unmounted.
[ 3541.091918] I-pipe: Domain RTAI registered.
[ 3541.091921] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 3541.091922] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 3541.091970] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3541.091971] PIPELINE layers:
[ 3541.091972] f960ee20 9ac15d93 RTAI 200
[ 3541.091973] c085cb20 0 Linux 100
[ 3541.099487] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3541.099582] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 3541.099584] RTAI[sched]: hard timer type/freq = APIC/6235530(Hz); default timing: periodic; linear timed lists.
[ 3541.099586] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591649000 hz.
[ 3541.099587] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 3541.099617] RTAI[usi]: enabled.
[ 3541.113743] RTAI[math]: loaded.
[ 3541.157054] hm2: loading Mesa HostMot2 driver version 0.15
[ 3541.158235] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 3541.158256] hm2_pci 0000:06:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 3541.158257] hm2_pci: discovered 5i25 at 0000:06:00.0
[ 3541.158629] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 3541.213767] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 3541.213769] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 3541.213770] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 3541.213771] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 3541.213772] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 3541.213773] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 3541.213774] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 3541.213775] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 3541.213777] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 3541.213778] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 3541.213780] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 3541.213781] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 3541.213782] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 3541.213783] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 3541.213784] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 3541.213785] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 3541.213786] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 3541.213787] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 3541.213788] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 3541.213789] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 3541.213790] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 3541.213791] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 3541.213792] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 3541.213794] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 3541.213795] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 3541.213796] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 3541.213797] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 3541.213798] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 3541.213799] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 3541.213800] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 3541.213801] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 3541.213802] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 3541.213803] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 3541.213804] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 3541.213805] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 3541.213834] hm2/hm2_5i25.0: registered
[ 3541.213835] hm2_5i25.0: initialized AnyIO board at 0000:06:00.0
[ 3541.319758] hm2_5i25.0: dropping AnyIO board at 0000:06:00.0
[ 3541.319761] hm2/hm2_5i25.0: unregistered
[ 3541.319773] hm2_pci 0000:06:00.0: PCI INT A disabled
[ 3541.319782] hm2_pci: driver unloaded
[ 3541.320710] hm2: unloading
[ 3543.379920] RTAI[math]: unloaded.
[ 3543.386060] SCHED releases registered named ALIEN RTGLBH
[ 3543.449537] RTAI[malloc]: unloaded.
[ 3543.547845] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3543.548813] I-pipe: Domain RTAI unregistered.
[ 3543.548872] RTAI[hal]: unmounted.
[ 3565.770720] I-pipe: Domain RTAI registered.
[ 3565.770723] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 3565.770724] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 3565.770772] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3565.770773] PIPELINE layers:
[ 3565.770775] f9cb7e20 9ac15d93 RTAI 200
[ 3565.770776] c085cb20 0 Linux 100
[ 3565.778127] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3565.778249] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 3565.778252] RTAI[sched]: hard timer type/freq = APIC/6235530(Hz); default timing: periodic; linear timed lists.
[ 3565.778254] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591649000 hz.
[ 3565.778255] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 3565.778312] RTAI[usi]: enabled.
[ 3565.791141] RTAI[math]: loaded.
[ 3565.835113] hm2: loading Mesa HostMot2 driver version 0.15
[ 3565.836192] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 3565.836212] hm2_pci 0000:06:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 3565.836214] hm2_pci: discovered 5i25 at 0000:06:00.0
[ 3565.836718] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 3565.891869] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 3565.891871] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 3565.891872] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 3565.891873] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 3565.891874] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 3565.891875] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 3565.891876] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 3565.891877] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 3565.891878] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 3565.891880] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 3565.891881] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 3565.891883] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 3565.891884] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 3565.891885] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 3565.891886] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 3565.891887] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 3565.891888] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 3565.891889] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 3565.891890] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 3565.891891] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 3565.891892] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 3565.891893] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 3565.891894] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 3565.891895] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 3565.891896] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 3565.891897] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 3565.891898] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 3565.891899] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 3565.891900] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 3565.891901] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 3565.891902] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 3565.891903] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 3565.891904] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 3565.891905] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 3565.891906] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 3565.891935] hm2/hm2_5i25.0: registered
[ 3565.891936] hm2_5i25.0: initialized AnyIO board at 0000:06:00.0
[ 3565.991347] hm2_5i25.0: dropping AnyIO board at 0000:06:00.0
[ 3565.991349] hm2/hm2_5i25.0: unregistered
[ 3565.991361] hm2_pci 0000:06:00.0: PCI INT A disabled
[ 3565.991370] hm2_pci: driver unloaded
[ 3565.992322] hm2: unloading
[ 3568.051487] RTAI[math]: unloaded.
[ 3568.060467] SCHED releases registered named ALIEN RTGLBH
[ 3568.124344] RTAI[malloc]: unloaded.
[ 3568.222694] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3568.223627] I-pipe: Domain RTAI unregistered.
[ 3568.223684] RTAI[hal]: unmounted.
[ 3713.178282] usb 2-1.3: USB disconnect, address 3
[ 3713.440938] usb 2-1.3: new low speed USB device using ehci_hcd and address 5
[ 3713.538315] usb 2-1.3: configuration #1 chosen from 1 choice
[ 3713.541125] input: Logitech USB-PS/2 Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.0/input/input7
[ 3713.541187] generic-usb 0003:046D:C03E.0004: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:1d.0-1.3/input0
[ 3713.541407] usb 2-1.4: USB disconnect, address 4
[ 3713.804812] usb 2-1.4: new low speed USB device using ehci_hcd and address 6
[ 3713.902455] usb 2-1.4: configuration #1 chosen from 1 choice
[ 3713.905284] input: SIGMACHIP USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4:1.0/input/input8
[ 3713.905352] generic-usb 0003:1C4F:0002.0005: input,hidraw1: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-0000:00:1d.0-1.4/input0
[ 3713.908945] input: SIGMACHIP USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4:1.1/input/input9
[ 3713.908999] generic-usb 0003:1C4F:0002.0006: input,hidraw2: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-0000:00:1d.0-1.4/input1
[ 3749.005352] usb 2-1.3: USB disconnect, address 5
[ 3749.267633] usb 2-1.3: new low speed USB device using ehci_hcd and address 7
[ 3749.365264] usb 2-1.3: configuration #1 chosen from 1 choice
[ 3749.368456] input: Logitech USB-PS/2 Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.0/input/input10
[ 3749.368526] generic-usb 0003:046D:C03E.0007: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:1d.0-1.3/input0
[ 4247.648035] I-pipe: Domain RTAI registered.
[ 4247.648039] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 4247.648041] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 4247.648086] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4247.648088] PIPELINE layers:
[ 4247.648089] fa3cce20 9ac15d93 RTAI 200
[ 4247.648091] c085cb20 0 Linux 100
[ 4247.655323] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4247.655525] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 4247.655527] RTAI[sched]: hard timer type/freq = APIC/6235530(Hz); default timing: periodic; linear timed lists.
[ 4247.655529] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591649000 hz.
[ 4247.655530] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 4247.655561] RTAI[usi]: enabled.
[ 4247.669251] RTAI[math]: loaded.
[ 4247.712570] hm2: loading Mesa HostMot2 driver version 0.15
[ 4247.713756] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 4247.713775] hm2_pci 0000:06:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 4247.713777] hm2_pci: discovered 5i25 at 0000:06:00.0
[ 4247.714113] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 4247.769144] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 4247.769146] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 4247.769147] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 4247.769148] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 4247.769149] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 4247.769150] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 4247.769151] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 4247.769152] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 4247.769154] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 4247.769155] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 4247.769156] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 4247.769158] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 4247.769159] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 4247.769160] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 4247.769161] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 4247.769162] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 4247.769163] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 4247.769164] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 4247.769165] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 4247.769166] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 4247.769167] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 4247.769168] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 4247.769169] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 4247.769170] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 4247.769171] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 4247.769172] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 4247.769173] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 4247.769174] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 4247.769175] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 4247.769176] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 4247.769177] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 4247.769178] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 4247.769179] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 4247.769180] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 4247.769181] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 4247.769210] hm2/hm2_5i25.0: registered
[ 4247.769211] hm2_5i25.0: initialized AnyIO board at 0000:06:00.0
[ 4247.869980] hm2_5i25.0: dropping AnyIO board at 0000:06:00.0
[ 4247.869983] hm2/hm2_5i25.0: unregistered
[ 4247.869995] hm2_pci 0000:06:00.0: PCI INT A disabled
[ 4247.870005] hm2_pci: driver unloaded
[ 4247.870837] hm2: unloading
[ 4249.930843] RTAI[math]: unloaded.
[ 4249.939077] SCHED releases registered named ALIEN RTGLBH
[ 4249.997906] RTAI[malloc]: unloaded.
[ 4250.097770] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4250.098781] I-pipe: Domain RTAI unregistered.
[ 4250.098833] RTAI[hal]: unmounted.
Regards
Giorgio
- Thank you received: 5295
04 Jan 2016 17:01 #67852
Replied by PCW on topic 6i25 + 7i76 hm2/hm2_5i25: unregistered
The driver and hardware seem OK (card is found and registered)
Looks like maybe a HAL/INI file error
running LinuxCNC from the command line and looking at any error messages there may help
The following user(s) said Thank You: bkt
- cncbasher
- Thank you received: 202
04 Jan 2016 17:28 #67858
by cncbasher
Replied by cncbasher on topic 6i25 + 7i76 hm2/hm2_5i25: unregistered
post your config as an archive , the driver is loading fine
- bkt
04 Jan 2016 19:36 #67865
by bkt
Replied by bkt on topic 6i25 + 7i76 hm2/hm2_5i25: unregistered
Sorry at this moment haven't access to .hal file ... but the errors are not recognise 5i25.7i76.0.0.12-in ..... if i comment the line (#) the error compare at successive 5i25......in pin.....
04 Jan 2016 19:43 #67866
Looks to me like you do not have 7I76 firmware installed on the 5I25/6I25 so no I/O is likely to work
- bkt
04 Jan 2016 19:58 #67867
by bkt
@pcw I suspect something like these..... I install 5i25 firmware or some other??
Tanks
Regards
Giorgio
Tanks
Regards
Giorgio
04 Jan 2016 20:14 #67870
Yes, use 5i25 firmware , probably 5i25_7i76x2.bit
- bkt
05 Jan 2016 07:28 #67907
by bkt
You are in right .... no 7i76 bitfile in 6i25 board .....When I update her error disappear ...
giorgio
giorgio
