Mesa 7i92 Ethernet Connection
- 10K
- Thank you received: 33
19 Jan 2016 19:53 - 19 Jan 2016 19:54 #68776
by 10K
Mesa 7i92 Ethernet Connection was created by 10K
I'm looking for some advice on how to hook up the 7i92 to my computer through the ethernet connection.
As I see it, here are the options.
A - I run a RJ-45 cable directly from the computer to the 7i92.
B - I connect the computer and 7i92 to a router. No other devices are connected to the router.
C - As above, but there are other devices using the switch. The switch is connected to a router that assigns addresses.
I'm still configuring/building the system. I do have it working with essentially option C and a router performing DHCP. However, I have not actually cut anything yet!
If possible, I'd like to have the computer sitting on my network, so that I can easily send it G-code files from other computers.
So, here are the questions:
1) Will option A, even work without a router somewhere? I assume both the computer and 7i92 have to have static addresses.
2) For option C, can the 7i92 be mixed in with other devices in a similar address range (192.168.1.xxx)?
3) For option C, can the 7i92 be mixed in with other devices if it uses a different address range (10.10.1.xxx)?
Thanks!
Thanks!
Last edit: 19 Jan 2016 19:54 by 10K. Reason: removed rogue smiley face
- Thank you received: 5295
19 Jan 2016 21:46 - 20 Jan 2016 16:32 #68780
Replied by PCW on topic Mesa 7i92 Ethernet Connection
Option A is the correct one for the best real time performance
Option B will at the minimum add the routers switches store&forward delays and has no advantages over "A" *
(assuming you disable all router features so it doesn't blather any unsolicited packets)
Option C can work if you use IP aliasing on the host (but not for real time)
* A switch can be used to run multiple hm2_eth cards (currently up to 4) from one port
this works fairly well if the switch has at least one GigE port connected to the host
as the short 1GigeE host packet time allows for considerable overlap of the 100BaseT traffic
Last edit: 20 Jan 2016 16:32 by PCW.
- Thank you received: 4646
20 Jan 2016 14:21 #68821
I there a space on the motherboard for a mini-PCIe WiFi card?
You can also try a USB WiFi dongle. I have one on one of my machines, and it doesn't seem to cause latency issues, though that would be a valid concern.
Replied by andypugh on topic Mesa 7i92 Ethernet Connection
The following user(s) said Thank You: 10K
20 Jan 2016 16:34 #68837
USB --> Ethernet dongles for the non-real time network connection also work well
- 10K
20 Jan 2016 18:59 #68843
by 10K
Replied by 10K on topic Mesa 7i92 Ethernet Connection
Thanks for answering the question I as going to ask!
I have one of those tiny computers, so there's no room or slots for any boards. I do have a USB to ethernet dongle. If I understand correctly, I can configure two ethernet plugs in the machine (one internal, and one a USB dongle). I would use one (the dongle) to connect to my home network, and the other (the built-in) would be for the dedicated line to the 7i92. The dedicated line would have a separate address scheme, like the 10,10,1,x.
So I'll be able to move files to and from the computer on my regular network, and will have the dedicated network for the 7i92.
PS, the computer does have built-in wi-fi, but there's not a driver for it yet in linux.
