Anyone tested thinkerforge ... the Stepper Brick
  • FlyingJack
  • FlyingJack's Avatar Topic Author
  • New Member
  • New Member
29 Jan 2016 18:14 #69247 by FlyingJack
found that while searching cheap basis for self learning guys like me www.tinkerforge.com/en
there is that Stepper Brick www.tinkerforge.com/en/doc/Hardware/Bricks/Stepper_Brick.html
The software was easy to install under debian and run ... as "Brick Viewer"
worth to test it or better go away with it?
Thanks for that nice forum and the work in linuxcnc B)
30 Jan 2016 07:00 #69263 by cmorley
If you mean to use it with linuxcnc then no - USB is not supported as a motor controller link in linuxcnc.
Chris M
  • FlyingJack
  • New Member
  • New Member
30 Jan 2016 23:51 #69296 by FlyingJack
Replied by FlyingJack on topic Anyone tested thinkerforge ... the Stepper Brick
Meanwhile I got contact to a guy who used them for his project.
... and he said ... don't use.
Moving one axis a time worked but simple curves don't work ... thinkerforge would change something with the api ... but over time nothing happened ... and that guy use still winblond so I can't try a test.
R.E.
Moderators: PCWjmelson
