Mesa 7i77 destroyed
19 Feb 2016 07:54 #70364 by REEEN
Mesa 7i77 destroyed was created by REEEN
Obe of our colleagues just destroyed its mesa 7i77 boar. The 8 channel chips that control the outputs are melted. He is a bit to far away for me to look what was responsible for that.
Has anyobe an idea what could be the fault ?
What kind of problem will cause only theses chips to melt ?
THANK YOU
Greets Rene
19 Feb 2016 14:29 #70370 by PCW
Replied by PCW on topic Mesa 7i77 destroyed
I have seen 3 things destroy the output driver chips on a 7i76/7I77
1. Excessive field voltage even for a millisecond (>40V or so) also using a DC
supply with no filter so spikes from the line voltage get forwarded to the field voltage.
The field voltage --> logic power supply is good up to 50V but the output drivers will fail
around 40V
2. Driving inductive loads >60 mA or so with no flyback diode across the load
3. Shorting outputs to line voltage
23 Feb 2016 11:26 #70508 by REEEN
Replied by REEEN on topic Mesa 7i77 destroyed
Thank you for that information !
Moderators: PCWjmelson
Time to create page: 0.103 seconds
