First Steps with Mesa 5i25/7i77
  • Sparky961
  • Sparky961's Avatar Topic Author
  • Elite Member
  • Elite Member
25 Feb 2016 02:30 #70594 by Sparky961
First Steps with Mesa 5i25/7i77 was created by Sparky961
Ok, steps might be a bit strong. Maybe more like stumbling along...
I'm working at seeing some life from the cards that recently arrived. I've tried to load a sample configuration but received an error when using the "Config Picker".
HAL:  ERROR: function 'hm2_5i25.0.pet_watchdog' not found
./hm2-servo7i77.hal:64: addf failed
I searched online for a bit to see how I might resolve this and stubled upon a thread here that also referenced the "pet watchdog" function/command.
forum.linuxcnc.org/forum/24-hal-componen...-schematic-for-servo
This is the first reference I had seen to using the command line to test the card and was excited, but alas when I got to the "pet watchdog" line I received a similar error.
halcmd: addf hm2_5i25.0.pet-watchdog thread1
HAL: ERROR: function 'hm2_5i25.0.pet-watchdog' not found
Interesting to note that the spelling is different in either case (dash vs. underscore), though I have tried both and neither seems to work.
So it would seem I'm missing something or somehow not correctly configured. This is a fresh install of LinuxCNC-2.7-wheezy. I'm using example files that I've collected from various sources (mostly posted as attachments on this forum) because I'm not entirely sure which ones are the "master" example files and where I get them from.
25 Feb 2016 12:25 #70609 by andypugh
Replied by andypugh on topic First Steps with Mesa 5i25/7i77
The watchdogs are now self-petting. Just delete those lines.
Moderators: PCWjmelson
Time to create page: 0.365 seconds
