7i76E + THCad 10V
17 Sep 2016 11:47 #80520
Replied by andypugh on topic 7i76E + THCad 10V
Would a G53 move to the top of travel be a way to find a known-state?
- Rick G
- Thank you received: 114
17 Sep 2016 13:21 - 17 Sep 2016 13:31 #80525
by Rick G
Maybe not, But that would allow for the longest possible move up and the best chance of getting rid of the offset in one move.
Possibly that may also cause a limit switch to be triggered?
Rick G
Replied by Rick G on topic 7i76E + THCad 10V
Rick G
Last edit: 17 Sep 2016 13:31 by Rick G. Reason: second thought
- BigJohnT
- Thank you received: 994
17 Sep 2016 20:13 #80536
by BigJohnT
Replied by BigJohnT on topic 7i76E + THCad 10V
Once an axis is homed a G53 move on a properly configured axis will not go out of soft limits. Add in the thc component and it's still not likely to happen positive offsets are removed at once and negative offsets are removed by the distance of the offset IIRC. I'm not near a computer so painfully using my android phone. In practical terms if the material has a .250 warp then at .250 Z move will remove the offset
JT
JT
The following user(s) said Thank You: Rick G
- OPS
17 Sep 2016 20:48 - 17 Sep 2016 20:49 #80540
by OPS
Replied by OPS on topic 7i76E + THCad 10V
In my situation homing did not help - the value remains inadequate. I should close application, clear stepper var files and last-position file, and only after restart application homing will reset to adequate value. I still have no clue what lead to the accumulatio of the error.. I have about 450 pierces on single sheet, and normaly I got error saying that next instruction will exceed z axis limit (in my case from -5 to +45 mm) after 50-100 cuts. I also noticed that when the thc is on from UI panel z axis does slight shift. From the thc comp code I didn't find anything what could make this happen.. magic..
Last edit: 17 Sep 2016 20:49 by OPS.
- Rick G
17 Sep 2016 20:50 #80541
by Rick G
Have you tried adding the extra Z move(s)?
Rick G
Rick G
- Rick G
17 Sep 2016 20:57 #80542
by Rick G
By the way the THC works great for me.
Rick G
That was my understanding, I just wondered if the Z axis had very limited movement and the correction was greater than the available movement. But in that case it seems an error code is more likely than a limit switch.it's still not likely to happen positive offsets are removed at once
Rick G
- BigJohnT
18 Sep 2016 00:50 #80549
by BigJohnT
Good point Rick, if Z is already at the maximum height then you don't have enough room to zero the offset.
JT
JT
- OPS
26 Sep 2016 20:05 #80949
by OPS
Yes, it seems everythign works fine now. I have increased move by z for 10 mm and reduced maximum speed for the z axis twice.
- Rick G
27 Sep 2016 05:32 #80967
by Rick G
Great!
Rick G
Rick G
Time to create page: 0.508 seconds
