Help with old stepper drives - DynaMechtronics
- jj89074
05 Apr 2016 21:57 #72813
by jj89074
Help with old stepper drives - DynaMechtronics was created by jj89074
Hello,
I'm beginning work on my Dyna Mechtronics DM3000H lathe. I'd like to use the old stepper drives (for now), but I'm having trouble figuring out one of the pin-outs. Seven of eight are straight-forward (2 PWR, 2 GND, +5VDC, Step, Direction), but the last one is labeled HERE. I would guess it's either an enable pin or common return. It's probably an acronym, but it's a puzzle to me. Attached is the diagram.
Thoughts?
Thoughts?
- cncbasher
- Thank you received: 202
06 Apr 2016 10:34 #72837
by cncbasher
Replied by cncbasher on topic Help with old stepper drives - DynaMechtronics
i'd go with an enable
- jj89074
06 Apr 2016 23:57 #72881
by jj89074
Replied by jj89074 on topic Help with old stepper drives - DynaMechtronics
cncbasher - Thanks, I think you're right. The drives work fine with the HERE line NOT connected.
I guess they are enabled until grounded?
Now I need to play around with tuning. I haven't found a thing on the WEB.
Time to create page: 0.301 seconds
