Mesa 7i29 Maximum Encoder Count Rate
19 Apr 2016 19:24 #73613 by pbrubaker
Mesa 7i29 Maximum Encoder Count Rate was created by pbrubaker
Hey all,
I'm upgrading the encoders on my servo motors, and will probably go with the US Digital E6 models, but I want to make sure I don't over specify CPR for the drive/FPGA combination I'm using.
The motors are 1 2000 RPM and two 2500 RPM DC brush servos. The ball screws are of unknown pitch at this point, either 4 or 5 TPI. I'm using a 7i29 with a 6i24-25.
A 10k CPR on the 2500 RPM motor would be 1.667 million counts/sec, and on some of the other servo cards this is the theoretical maximum with filtering enabled. I'm just not sure how close I want to be to that theoretical maximum.
Cheers,
Pete
20 Apr 2016 13:08 #73643 by PCW
Replied by PCW on topic Mesa 7i29 Maximum Encoder Count Rate
With a 6I24 and encoder filtering enabled (and assuming non-muxed encoder counters) the maximum count rate
of the hosttmot2 encoder counters is 4.4 MHz. To get clean signals at that speed is going to require differential signaling
The following user(s) said Thank You: pbrubaker
20 Apr 2016 19:48 #73660 by pbrubaker
Replied by pbrubaker on topic Mesa 7i29 Maximum Encoder Count Rate
Awesome, thanks PCW. I am going with differential signaling encoders. I'm very new to this so please excuse the basic questions.
What would be a reasonable CPR for my case (older VMC?)
Moderators: PCWjmelson
Time to create page: 0.290 seconds
