THC CAD FOR PLASMA CUTTING
- CNCLINUXSREE
26 Apr 2016 12:09 #73894
by CNCLINUXSREE
THC CAD FOR PLASMA CUTTING was created by CNCLINUXSREE
Hii,
I have designed a CNC Plasma cutting machine with Linux EMC2 as the CNC software. I hae purchased the Mesa cards, 5i25 and 7i77 boards. My question here is shule I also buy the THCCAD boards for the Torch height control.
I have an ESAB Cutmaster 100 series Plasma cutter with an automation kit included. Meaning that the divided torch voltage will be available fro this pre installed board from Esab. This divided voltage would be in the range of anolog 0- 10 volts.
In such a scenario can i input this voltage to the relevant pin in the 7i77 and use this to control the torch height. Please let me have your suggestion, because I want to finish this project asap and do not have the time to order and buy the THC CAD card from Mesa.
Kindly explain if this is possible
- BigJohnT
- Thank you received: 994
26 Apr 2016 12:19 - 26 Apr 2016 12:21 #73895
by BigJohnT
Replied by BigJohnT on topic THC CAD FOR PLASMA CUTTING
Last edit: 26 Apr 2016 12:21 by BigJohnT.
- Thank you received: 4648
26 Apr 2016 13:51 #73904
In theory, yes. The 7i77 has analogue voltage measurement on the inputs, but they may not be accurate enough:
From the manual:
"ANALOG INPUTS
All field input pins are capable of reading the input voltage. These are not highly
accurate or high resolution but can be useful for things like potentiometer inputs. Input
resolution is 8 bits and input full scale value is 36.3V. Accuracy is +-5%"
So, you will gave an analogue voltage that gives 70 discrete values between 0V and 10V. That might well be enough for THC, I am not sure how strong a function of torch height the voltage is.
If you need better resolution then the THCAD10 is probably the cheapest solution, and may add a useful degree of isolation.
Replied by andypugh on topic THC CAD FOR PLASMA CUTTING
From the manual:
"ANALOG INPUTS
- BigJohnT
26 Apr 2016 14:17 #73909
by BigJohnT
That would only give you a 4.3v resolution which is much too coarse (tip voltage 0-300v). You need to control the tip voltage to +- 1~2v to have quality cuts. He would be better off just setting the cut height and cut away like I did for quite some time until PCW invented the THCAD.
JT
JT
- CNCLINUXSREE
26 Apr 2016 18:08 #73927
by CNCLINUXSREE
Replied by CNCLINUXSREE on topic THC CAD FOR PLASMA CUTTING
Thanks for the quick answer. It was not the cost of the THC CAD which was a concern. It was the time that Mesa electronics takes to ship out this board to India. This is the problem. However when you say that it would give me better results, I shall order 1 THC CAD 10 immediately. But can you let me know if any other company could deliver faster. I could order bthe same on line.
Thanks a lot
SREEDHAR R
Thanks a lot
SREEDHAR R
- BigJohnT
26 Apr 2016 21:26 - 26 Apr 2016 21:27 #73937
by BigJohnT
I don't know of any. Orders placed before 8am Central time ship that same day and by ship the packages are on their way to the USPS distribution center. For orders that qualify, International First Class arrives the same time as Priority...
JT
JT
Last edit: 26 Apr 2016 21:27 by BigJohnT.
- CNCLINUXSREE
27 Apr 2016 14:27 #73954
by CNCLINUXSREE
HII,
As suggested I have ordered a Mesa THCAD 10. Can you suggest how this is connected to 7i77.
The other end of this is of course connected to the Esab Plasma head. I shall come back with more details and question.
- BigJohnT
27 Apr 2016 22:02 #73969
by BigJohnT
I don't see any orders for THCAD cards, you must have ordered from someone else.
JT
JT
- CNCLINUXSREE
28 Apr 2016 07:35 #73989
by CNCLINUXSREE
Dear John,
I ordered the THCAD on Mesa Electronics stores.
Can I order this with you also. I didnt know his. Please let me know if this is possible.
- BigJohnT
28 Apr 2016 21:37 #74020
by BigJohnT
Time to create page: 0.829 seconds
