DDMMV2 work with Linuxcnc?
- estes53
19 May 2016 14:43 - 19 May 2016 15:22 #74847
by estes53
DDMMV2 work with Linuxcnc? was created by estes53
Here is the manual-
www.soonwell.com/ebay_file/user_manual/DDMMV2.pdf
I am new to this and have gotten the impression that if it works for Mach3 it will also work for Linuxcnc.
Please correct me if I am wrong.
Thanx, Alan
Thanx, Alan
Last edit: 19 May 2016 15:22 by estes53. Reason: fixed the link
- Thank you received: 4648
19 May 2016 15:16 #74849
Replied by andypugh on topic DDMMV2 work with Linuxcnc?
The link you gave does not work, but I think I managed to find it.
The stepper control via the Parallel port should work, but you will not get any of the USB-based IO with a LinuxCNC system.
- estes53
19 May 2016 15:20 - 19 May 2016 15:23 #74850
by estes53
Replied by estes53 on topic DDMMV2 work with Linuxcnc?
I wasn't planning on using USB for control and in fact thought the connection was for power only.
The link has been fixed.
Last edit: 19 May 2016 15:23 by estes53.
- estes53
19 May 2016 15:27 #74851
by estes53
OK, now something else is confusing me.
Page 10 of the manual shows a driver board between the controller and the motor.
I thought a controller was also a driver.
- estes53
19 May 2016 15:34 #74852
by estes53
This is what I was planning on buying-
us.stepperonline.com/4-axis-19nm269ozin-...river-kit-p-298.html
Until I found this-
www.ebay.com/itm/USB-LPT-Mach3-CNC-6-Axi...a7-&autorefresh=true
Until I found this-
19 May 2016 15:39 #74853
I think that the device in question is just an opto-isolation board, not a stepper driver.
- estes53
19 May 2016 16:04 #74854
by estes53
In that case, I probably should stick with my original plan.
20 May 2016 02:23 #74868
Probably, it contains motors and drivers, and looks a lot more conventional.
Time to create page: 0.396 seconds
