7i73 keyboard firmware in 7i90
30 May 2016 02:10 #75236 by cmorley
7i73 keyboard firmware in 7i90 was created by cmorley
I am wondering on the possibility of putting the matrix keyboard decoder like the 7i73 has, on the 7i90 (as a serial device) and expanding it from 8x8 to 10x10 or I guess 12x12 would be possible on one connector. I'm not interested in the LCD driver component.
I would like a couple MPG encoders on another connector though.
I looked into the possibility of me doing this but ... wow I downloaded the software to do fpga work and that will take a long time to figure out if ever!
Could anyone help me with this request?
Chris M
30 May 2016 03:18 #75239 by PCW
Replied by PCW on topic 7i73 keyboard firmware in 7i90
You could implement the keyboard scanning in software with the matrix_kb comp and use the
standard 7I90 sserial remote config. Its probably not too hard to add a MPG option
30 May 2016 03:47 #75240 by cmorley
Replied by cmorley on topic 7i73 keyboard firmware in 7i90
Yes I guess I could.
It just makes the HAL code huge/bloated.
I wish to use the panelui component which takes 7i73 scan codes.
I can use matrix_kb to convert to scan codes but it about doubles the amount of HAL code and signal names I must make up that need to make sense.
The 7i73 just doesn't have enough I/0 for my panel.
Chris M
Moderators: PCWjmelson
