Mesa RS422 max cable length?
03 Jun 2016 07:08 - 03 Jun 2016 07:09 #75388 by terkaa
Mesa RS422 max cable length? was created by terkaa
I am wiring user panel with 7i84 cards. My question: Is 7 meters(25 ft) CAT5 cable too long between Mesa 7I84 and 7I74 cards? Cable will route in energy chain along with other wires that may cause some noise(110Vac for ATC solenoids). Or is it better to keep 7i84's near 7i74 and wire panel buttons & light with 7 meter cables(about 50 wires)?
Tero
Last edit: 03 Jun 2016 07:09 by terkaa.
03 Jun 2016 17:18 #75446 by PCW
Replied by PCW on topic Mesa RS422 max cable length?
If the 7I84 cable is routed near switched 120VAC lines I would use shielded Cat5
Up to about 30 M is OK but the longer the parallel runs with noisy signals
the greater the chance of data errors
03 Jun 2016 17:41 #75450 by terkaa
Replied by terkaa on topic Mesa RS422 max cable length?
Ok, so I am good with 25ft shielded CAT6 cables?
03 Jun 2016 18:13 #75454 by PCW
Should be fine
Cat5E and CAT6 have the advantage of using 24 gauge wire so have lower voltage drops than CAT5
Moderators: PCWjmelson
Time to create page: 0.090 seconds
