mesaflash gives me no output whatsoever
- rwistort
- Thank you received: 4
11 Jun 2016 20:35 #75834
by rwistort
mesaflash gives me no output whatsoever was created by rwistort
Hi:
I bought a Mesa 6i25 / 7i76 kit and I'm struggling to get it working. The current problem is that mesaflash gives no output.
I moved 1 jumper (power to the 7i76), installed the card, downloaded the software from the mesa web site, unzipped it, changed the permissions, and ...
Here is a short terminal session:You can see that the card is visible on the pci bus and that mesaflash gives no output at all.
What gives??
I am using ubuntu 12.04 LTS on a Dell xeon WS and my linuxcnc install is a branch based on v2.6.7.
I compile linuxcnc from source and my install is for 64-bit, non-RT simulation mode.
When I google for mesaflash problems, a common suggestion is to do:
sudo apt-get install mesaflash
which gives me: E: Unable to locate package mesaflash
(getting ahead of myself, google also suggests using synaptic to get the latest hostmot2, but synaptic can't find it.)
I am at a loss. Can anyone help?
~/linuxcnc-dev> cd
~> lspci | grep 5125
02:00.0 DPIO module: Device 2718:5125 (rev 01)
~>cd mesa/5i25/utils/linux
~/mesa/5i25/utils/linux> ls -l
total 524
-rwxrwxrwx 1 reid reid 188727 Apr 16 2014 mesaflash
-rwxrwxr-x 1 reid reid 194899 Mar 17 2014 mesaflash3
-rwxrwxr-x 1 reid reid 66952 Aug 7 2012 rpo
drwxrwxr-x 3 reid reid 4096 Mar 17 2014 source
-rwxrwxr-x 1 reid reid 66996 Aug 7 2012 wpo
~/mesa/5i25/utils/linux> ./mesaflash
bash: ./mesaflash: No such file or directory
~/mesa/5i25/utils/linux> sudo ./mesaflash --help
[sudo] password for reid:
~/mesa/5i25/utils/linux> What gives??
- Thank you received: 5316
11 Jun 2016 21:28 - 11 Jun 2016 22:29 #75836
Replied by PCW on topic mesaflash gives me no output whatsoever
Since you are not using a standard LinuxCNC installation (this is why apt-get install fails)
and I'm pretty sure there are no packages for a 64 bit Ubuntu Precise system, Its probably the safest to
build mesaflash from source.
This is pretty simple though it may require fetching pcilib with apt-get
On the other hand if you bought a 6I25/7I76 kit it should not require any firmware changes
so mesaflash is not really required
Last edit: 11 Jun 2016 22:29 by PCW.
- rwistort
11 Jun 2016 23:49 #75839
by rwistort
Replied by rwistort on topic mesaflash gives me no output whatsoever
Thanks!
I built mesaflash from source as you suggested and now, at least, several of the commands give me some output to ponder.
(--help, --info, --list all give credible-looking results)
As an exercise, I hoped to check whether what's already burned onto the card matches one of the supplied .bit files, and was surprised thatgives me no output (even when I mis-type a .bit file that doesn't exist).
Am I trying to hard?
Thanks,
Reid
sudo ./mesaflash --verify ~/mesa/5i25/configs/hostmot2/5i25_7i76x2.bitAm I trying to hard?
Thanks,
Reid
12 Jun 2016 00:13 #75840
that command would be:
sudo mesaflash --device 5i25 -- verify somefilename.bit
(assuming mesaflash is installed)
But note that this is not a great way to verify bitfiles as an equivalent version compiled at a different time will not match
a better way is to check the configurations pinout and module content with the readhmid option:
sudo mesaflash --device 5i25 --readhmid > mypinout.txt
Time to create page: 0.164 seconds
