Galil 2183
10 years 4 months ago #76492 by jeffgold@comcast.net
Does anyone have or know of a driver to support a Galil 2183 controller?
Regards,
Jeff
10 years 4 months ago #76493 by andypugh
Replied by andypugh on topic Galil 2183
I don't think so.
LinuxCNC is itself a motion controller, if it is asked to control another motion controller (like Galil) then things get confusing pretty quickly.
10 years 4 months ago - 10 years 4 months ago #76495 by jeffgold@comcast.net
Replied by jeffgold@comcast.net on topic Galil 2183
Won't that be the same case with using Mach 3 which I have working with a Galil driver?
Last edit: 10 years 4 months ago by jeffgold@comcast.net.
10 years 4 months ago #76499 by PCW
Replied by PCW on topic Galil 2183
No, Mach 3/4 offloads its motion operations to buffered external devices
(the only exceptions to this are the parallel port versions of Mach)
LinuxCNC does these operations internally and then communicates to non buffered
external devices in real time (typically 1000 time a second) so requires different kinds
of hardware interface devices than Mach
10 years 4 months ago #76589 by jeffgold@comcast.net
So what is the recommendation for hardware?
My machine is a Well Index 833 CNC version, Electro-craft servo motors (5 axis) the original Sherona servo drive.
Thanks,
Jeff
10 years 4 months ago #76590 by andypugh
jeffgold@comcast.net wrote: So what is the recommendation for hardware?
What is wrong with the original controller?
If you have the Galil cards and they still work it might make sense to keep them and simply use something other than LinuxCNC.
I don't know what the options are there, but I see that there is a Mach3 plugin and that might actually be the sensible choice in this situation.
Moderators: PCW, jmelson
Time to create page: 0.344 seconds
