Mesa 7i76E - Is It Supported by PnCConf ?
10 years 4 months ago - 10 years 4 months ago #76537 by Skippy1
Guys,
I'm currently using the Mesa 5i25/7i76 cards for a CNC router. Thanks to the work people have put into the LinuxCNC program, and the support on this site, I found it relatively easy to configure using the PnCConf wizard in version 2.5 of LinuxCNC.
I'm looking at the Mesa control options for a CNC lathe I'm working on, and wondered if the Mesa 7i76E (Ethernet) card is as well supported in the current version of the LinuxCNC software? Is it as simple as connecting it to the USB port on the motherboard, and then wiring/configuring with the PnCConf wizard just like the 5i25/7i76 setup?
Cheers, Steve
Last edit: 10 years 4 months ago by Skippy1. Reason: Typos
10 years 4 months ago - 10 years 4 months ago #76754 by BigJohnT
You do have to configure the motherboard lan port to a fixed address usually 10.10.10.1. In addition to that you need to be running the Rt Preempt kernel with LinuxCNC Uspace. mesaus.com/index.php?route=product/produ...ath=68&product_id=72
I don't see a 7i76e option in pncconf but it should be pretty straight forward to convert a 5i25/7i76 configuration by changing the names.
www.mesaus.com/info/7i76e.txt
Edit: so much for trusting your memory...
JT
Last edit: 10 years 4 months ago by BigJohnT.
10 years 4 months ago #76758 by PCW
A minor correction:
The 7I76E default EEPROM IP address is 10.10.10.10 so the motherboard port would be set to 10.10.10.1
10 years 4 months ago #76770 by Skippy1
Thanks guys, That board opens up options to use a compact all-in-one touchscreen PC I was looking at. I loaded Debian and the RT kernel and had a play with it. All good, so I'll get that board instead of the 5i25/7i76.
8 years 1 month ago #118245 by skitter_ranch
I have a 5i25_7i76, and I can't get the I/O to work.
I am considering an Ethernet option as well.
I am hoping for the 7i96 to work in Debian.
Do you have any suggestions or info on how to get the I/O to work on the 7i76. Then I don't need to buy something else.
By the way: How did the 7i76E work out?
thanks
8 years 1 month ago #118247 by PCW
What problem do you have with the 7I76 I/O?
Moderators: PCW, jmelson
Time to create page: 0.435 seconds
