7i76 using a spindle encoder input for index axis0
- finemeca
- Visitor
I have Delta ASDA-B2 drivers.
I command in step / dir
www.delta.com.tw/product/em/motion/motio...B2_M_EN_20130906.pdf
I would use HOME USE_INDEX for axis.0 on a card 5i25 and 7i76.
I have a spindle encoder for connection with phase A and Z (not currently connected).
in the doc
ENCODER INTERFACE
The 7I76 provide a one channel encoder interface with index. This is intended as
a spindle encoder but can be used for other purposes. The encoder input can be
programmed for differential or single ended encoders. The encoder interface also provides
short circuit protected 5V power to the encoder. When used with single ended encoders,
the ENCA+, ENCB+ and IDX+ signals are wired to the encoder and the ENCA-,ENCB-,
and IDX- terminal left unconnected.
Can I connect this
net x-index-enable hm2_5i25.0.7i76.0.0.encoder.01.index-enable <=> axis.1.index-enableusing the input : ENCB+
Best regards
Pierre
- Thank you received: 5328
1. Use the 7I76 ENCA+ input
2. Set the encoder to up/down mode (this uses the "A" input for count and the "B" input for direction)
A "A"+ index encoder can be used for threading but not rigid tapping
- finemeca
- Visitor
Do you think it works well ?
This is a latte with spindle encoder and the index on drive axis.0
I make two encoders :
For spindle : encoder.00
For axis.0 : encoder.01
For the encoder spindle thread enc:
ENCA+ phase A
IDX + index
For the encoder HOME USE_INDEX axis.0 :
ENCB+ index-enabl
Can I connect this :
net spindle-velocity hm2_5i25.0.encoder.00.velocity => motion.spindle-speed-in
net spindle-index-enable hm2_5i25.0.encoder.00.index-enable <=> motion.spindle-index-enable
forum.linuxcnc.org/forum/49-basic-config...-in-hal?limitstart=0
- finemeca
- Visitor
On this lathe, I need an encoder on the spindle to the thread.
For the HOME USE_INDEX axis.0 how ?
I also have a 7i84 to connect buttons on a panel.
and jog wheels
Are you saying you have a additional motion axis that needs an index input?
Are you trying to orient your spindle?
- finemeca
- Visitor
Homing is done with a switch.
To improve the precision, I want to use :
HOME USE_INDEX = YES
Normally step/dir systems dont have encoders or indexes
- finemeca
- Visitor
Normally step / dir systems do not-have encoders or indexes
Yes but I also an encoder output
www.deltaww.com/Products/CategoryListT1....ame=ASDA-B2%20Series
but you would require 2 full (A,B,Z) encoder inputs for X and Z
The Hostmot2 hardware has the ability to latch the step count on index,
but this feature has no driver support currently
