5I20 problems with firmware
28 Jun 2016 09:28 - 28 Jun 2016 09:52 #76727 by dirk61
5I20 problems with firmware was created by dirk61
hi Guys
Have a problem with a 5I20 and 7I48 with loadrt hm2_pci config="firmware=hm2/5i20/SV12IM_2X7I48_72.BIT
PID everything to zero only FF1 = 1
At 500mm / min + 5V -5V
At 250mm / min + 2.5V -7,5V
At 800mm / min + 8V -2V
Cabling is I.O
dmesg :
[ 193.908145 ] RTAI [math ] : loaded .
[ 194.055124 ] hm2 : loading Mesa HostMot2 driver version 12:15
[ 194.062562 ] hm2_pci : loading Mesa AnyIO HostMot2 driver version 0.7
[ 194.062697 ] hm2_pci : discovered 5i20 at 0000 : 04 : 00.0
[ 194.226302 ] hm2 / hm2_5i20.0 : WARNING : this firmware has Muxed Encoder v2 !
[ 194.226314 ] hm2 / hm2_5i20.0 : WARNING : velocity computation will be incorrect!
[ 194.226321 ] hm2 / hm2_5i20.0 : WARNING : upgrade your firmware !
Could this be the problem ??
If so, how do I have to update ??
Have in the packet data management all updates made ​​no success .
Last edit: 28 Jun 2016 09:52 by dirk61.
28 Jun 2016 12:22 #76732 by PCW
Replied by PCW on topic 5I20 problems with firmware
The main problem you have is most likely that the PWMGENs are not set to mode 2 (UP/DOWN mode)
The encoder velocity calculation error (which is not related to your voltage output issue) is due to using
a very old firmware file.
You would need to update the hostmot2 firmware package with the package manager to fix this
28 Jun 2016 12:29 #76733 by dirk61
Replied by dirk61 on topic 5I20 problems with firmware
Hello
I MODE 1 need set + 10V / -10V
Hi have linux 2.7 on it
have made and applied yet this message is an update .
many thanks for the support
28 Jun 2016 12:40 #76734 by PCW
Not sure what you are saying about the mode
(PWM gen mode must be set to 2 for the 7I48)
what firmware file are you using?
28 Jun 2016 12:47 #76735 by dirk61
Firmware Datei ist die SV12IM_2X7I48_72
Mit dem Mode meine ich das ich PWM -Signal +-10V brauche
28 Jun 2016 12:50 #76737 by PCW
What I mean is that until you set the PWM mode to mode 2 the +-10V analog output will be incorrect
28 Jun 2016 12:55 #76738 by dirk61
OK
ie if I need + -10V I have to go suf mode 1 or ?
Can you send me a link where it says how I can update ??
28 Jun 2016 13:15 - 28 Jun 2016 13:19 #76740 by PCW
the 7I48 _requires_ that the PWM mode be set to 2
There is no other option that will work
Also if you don't have 2 7I48s you should probably use svst6_6_7i48.bit
its more likely to have been updated
Last edit: 28 Jun 2016 13:19 by PCW.
28 Jun 2016 13:38 #76741 by dirk61
OK then probably comes here purely mode 2
setp hm2_5i20.0.pwmgen.00.output-type 1
setp hm2_5i20.0.pwmgen.00.scale [AXIS_0]OUTPUT_SCALE
But I have 2X7I37TA hang at the 5I20
28 Jun 2016 13:41 #76742 by PCW
so
must be changed to
setp hm2_5i20.0.pwmgen.00.output-type 2
for all channels
if you have 2 7I37TA, then you should use svst6_6_7i48.bit
Moderators: PCWjmelson
Time to create page: 0.205 seconds
