thcad + stepper driver is possible?
  • echesortux
  • Topic Author
  • Senior Member
  • Senior Member
10 years 4 months ago #76887 by echesortux
thcad + stepper driver is possible? was created by echesortux
Hello everybody, I have a Mesa 5i25 + 7i76 + Hyperterm 65 . I am thinking of changing my thc for a thcad card from mesa. in the z axis I have a stepper motor so my doubt is if is posible using thcad with stepper motor or need a servo motor ? if is posible use with stepper motor could anyone show a digram conection so I don't realize how to hook it ups.
thanks in advance.
10 years 4 months ago #76889 by PCW
Replied by PCW on topic thcad + stepper driver is possible?
Any type of Z axis should work, the THCAD only provides the torch voltage to hal
Any drive type can be supported with the proper hal setup.
I suspect step drives are much more common for torchheight control than servo systems
The following user(s) said Thank You: echesortux
10 years 3 months ago - 10 years 3 months ago #77271 by BigJohnT
Replied by BigJohnT on topic thcad + stepper driver is possible?
The thc component is designed to support steppers for Z with the THCAD card. I have both THCAD cards in stock.
JT
Last edit: 10 years 3 months ago by BigJohnT.
  • echesortux
  • Topic Author
  • Senior Member
  • Senior Member
10 years 3 months ago #77305 by echesortux
Replied by echesortux on topic thcad + stepper driver is possible?
Thanks John. I am Leandro from indiceCNC I've ordered the THCAD last week to you (It should be coming). Today arrived the 5i25 and 7i76 kit you sent me. I will work with it next weekend.
Thanks.
Moderators: PCW, jmelson
Time to create page: 0.080 seconds
