convert a .BIT to .XML
- dirk61
04 Jul 2016 06:46 - 04 Jul 2016 09:01 #76955
by dirk61
convert a .BIT to .XML was created by dirk61
Hello how can I convert a BIT file of Mesanet in an XML file ??
or how do I get the svst6_6_7i48.bit so down that it appears to me in PNCCONF? 5I20+7I48+2X7I37TA
PLEASE HELP
Best regards
PLEASE HELP
Best regards
Last edit: 04 Jul 2016 09:01 by dirk61.
- Thank you received: 5330
04 Jul 2016 16:12 #76971
Replied by PCW on topic convert a .BIT to .XML
mesaflash can do this but its output is not completely compatible with pncconf
What .xml files do you have?
You could build a config file set with any 7i48 compatible xml file and then patch the few
difference by hand editing the created hal file
- dirk61
10 Jul 2016 14:16 #77253
by dirk61
Replied by dirk61 on topic convert a .BIT to .XML
Hallo
Wenn ich meine 5I20 und 7I48 2X7I37 mit dieser firmware=hm2/5i20/SV12IM_2X7I48_72.BIT laufen lasse funktioniert alles ausser dieser Fehlermeldung
392.219643] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 392.249587] RTAI[math]: loaded.
[ 392.471775] hm2: loading Mesa HostMot2 driver version 0.15
[ 392.477610] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 392.477703] hm2_pci: discovered 5i20 at 0000:04:00.0
[ 392.630534] hm2/hm2_5i20.0: WARNING: this firmware has Muxed Encoder v2!
[ 392.630546] hm2/hm2_5i20.0: WARNING: velocity computation will be incorrect!
[ 392.630553] hm2/hm2_5i20.0: WARNING: upgrade your firmware!
[ 392.645155] hm2/hm2_5i20.0: 72 I/O Pins used:
Then I tried this config
firmware = hm2 / 5i20 / svst6_6_7i48.BIT num_encoders = 6 = 6 num_pwmgens num_stepgens = 0
Then I get this error message
"5745500
[ 35.433323] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 35.433456] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 35.433473] RTAI[sched]: hard timer type/freq = APIC/8312460(Hz); default timing: oneshot; linear timed lists.
[ 35.433484] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 35.433492] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 35.461714] RTAI[math]: loaded.
[ 35.725368] hm2: loading Mesa HostMot2 driver version 0.15
[ 35.732639] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 35.732787] hm2_pci: discovered 5i20 at 0000:04:00.0
[ 35.896606] hm2/hm2_5i20.0: WARNING: this firmware has Muxed Encoder v2!
[ 35.896618] hm2/hm2_5i20.0: WARNING: velocity computation will be incorrect!
[ 35.896626] hm2/hm2_5i20.0: WARNING: upgrade your firmware!
[ 35.911226] hm2/hm2_5i20.0: 72 I/O Pins used:
[ 35.911237] hm2/hm2_5i20.0: IO Pin 000 (P2-01): PWMGen #0, pin Not-Enable (Output)
[ 35.911246] hm2/hm2_5i20.0: IO Pin 001 (P2-03): Muxed Encoder #0, pin Muxed A (Input)
[ 35.911255] hm2/hm2_5i20.0: IO Pin 002 (P2-05): Muxed Encoder #0, pin Muxed B (Input)
[ 35.911264] hm2/hm2_5i20.0: IO Pin 003 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 35.911272] hm2/hm2_5i20.0: IO Pin 004 (P2-09): Muxed Encoder #1, pin Muxed A (Input)
[ 35.911281] hm2/hm2_5i20.0: IO Pin 005 (P2-11): Muxed Encoder #1, pin Muxed B (Input)
[ 35.911290] hm2/hm2_5i20.0: IO Pin 006 (P2-13): Muxed Encoder #1, pin Muxed Index (Input)
[ 35.911298] hm2/hm2_5i20.0: IO Pin 007 (P2-15): Muxed Encoder #2, pin Muxed A (Input)
[ 35.911307] hm2/hm2_5i20.0: IO Pin 008 (P2-17): Muxed Encoder #2, pin Muxed B (Input)
[ 35.911316] hm2/hm2_5i20.0: IO Pin 009 (P2-19): Muxed Encoder #2, pin Muxed Index (Input)
[ 35.911325] hm2/hm2_5i20.0: IO Pin 010 (P2-21): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 35.911334] hm2/hm2_5i20.0: IO Pin 011 (P2-23): PWMGen #0, pin Out0 (PWM or Up) (Output)
[ 35.911343] hm2/hm2_5i20.0: IO Pin 012 (P2-25): PWMGen #0, pin Out1 (Dir or Down) (Output)
[ 35.911352] hm2/hm2_5i20.0: IO Pin 013 (P2-27): PWMGen #1, pin Out0 (PWM or Up) (Output)
[ 35.911361] hm2/hm2_5i20.0: IO Pin 014 (P2-29): PWMGen #1, pin Out1 (Dir or Down) (Output)
[ 35.911369] hm2/hm2_5i20.0: IO Pin 015 (P2-31): PWMGen #2, pin Out0 (PWM or Up) (Output)
[ 35.911378] hm2/hm2_5i20.0: IO Pin 016 (P2-33): PWMGen #2, pin Out1 (Dir or Down) (Output)
[ 35.911387] hm2/hm2_5i20.0: IO Pin 017 (P2-35): PWMGen #3, pin Out0 (PWM or Up) (Output)
[ 35.911396] hm2/hm2_5i20.0: IO Pin 018 (P2-37): PWMGen #3, pin Out1 (Dir or Down) (Output)
[ 35.911405] hm2/hm2_5i20.0: IO Pin 019 (P2-39): PWMGen #4, pin Out0 (PWM or Up) (Output)
[ 35.911414] hm2/hm2_5i20.0: IO Pin 020 (P2-41): PWMGen #4, pin Out1 (Dir or Down) (Output)
[ 35.911423] hm2/hm2_5i20.0: IO Pin 021 (P2-43): PWMGen #5, pin Out0 (PWM or Up) (Output)
[ 35.911432] hm2/hm2_5i20.0: IO Pin 022 (P2-45): PWMGen #5, pin Out1 (Dir or Down) (Output)
[ 35.911440] hm2/hm2_5i20.0: IO Pin 023 (P2-47): PWMGen #0, pin Not-Enable (Output)
[ 35.911448] hm2/hm2_5i20.0: IO Pin 024 (P3-01): IOPort
[ 35.911455] hm2/hm2_5i20.0: IO Pin 025 (P3-03): IOPort
[ 35.911462] hm2/hm2_5i20.0: IO Pin 026 (P3-05): IOPort
[ 35.911469] hm2/hm2_5i20.0: IO Pin 027 (P3-07): IOPort
[ 35.911476] hm2/hm2_5i20.0: IO Pin 028 (P3-09): IOPort
[ 35.911483] hm2/hm2_5i20.0: IO Pin 029 (P3-11): IOPort
[ 35.911490] hm2/hm2_5i20.0: IO Pin 030 (P3-13): IOPort
[ 35.911497] hm2/hm2_5i20.0: IO Pin 031 (P3-15): IOPort
[ 35.911504] hm2/hm2_5i20.0: IO Pin 032 (P3-17): IOPort
[ 35.911511] hm2/hm2_5i20.0: IO Pin 033 (P3-19): IOPort
[ 35.911519] hm2/hm2_5i20.0: IO Pin 034 (P3-21): Muxed Encoder Select #3, pin Mux Select 0 (Output)
[ 35.911527] hm2/hm2_5i20.0: IO Pin 035 (P3-23): IOPort
[ 35.911534] hm2/hm2_5i20.0: IO Pin 036 (P3-25): IOPort
[ 35.911541] hm2/hm2_5i20.0: IO Pin 037 (P3-27): IOPort
[ 35.911548] hm2/hm2_5i20.0: IO Pin 038 (P3-29): IOPort
[ 35.911555] hm2/hm2_5i20.0: IO Pin 039 (P3-31): IOPort
[ 35.911562] hm2/hm2_5i20.0: IO Pin 040 (P3-33): IOPort
[ 35.911569] hm2/hm2_5i20.0: IO Pin 041 (P3-35): IOPort
[ 35.911576] hm2/hm2_5i20.0: IO Pin 042 (P3-37): IOPort
[ 35.911583] hm2/hm2_5i20.0: IO Pin 043 (P3-39): IOPort
[ 35.911590] hm2/hm2_5i20.0: IO Pin 044 (P3-41): IOPort
[ 35.911597] hm2/hm2_5i20.0: IO Pin 045 (P3-43): IOPort
[ 35.911604] hm2/hm2_5i20.0: IO Pin 046 (P3-45): IOPort
[ 35.911611] hm2/hm2_5i20.0: IO Pin 047 (P3-47): IOPort
[ 35.911619] hm2/hm2_5i20.0: IO Pin 048 (P4-01): Muxed Encoder #0, pin Muxed IndexMask (Input)
[ 35.911628] hm2/hm2_5i20.0: IO Pin 049 (P4-03): Muxed Encoder #1, pin Muxed IndexMask (Input)
[ 35.911637] hm2/hm2_5i20.0: IO Pin 050 (P4-05): Muxed Encoder #2, pin Muxed IndexMask (Input)
[ 35.911645] hm2/hm2_5i20.0: IO Pin 051 (P4-07): IOPort
[ 35.911652] hm2/hm2_5i20.0: IO Pin 052 (P4-09): IOPort
[ 35.911659] hm2/hm2_5i20.0: IO Pin 053 (P4-11): IOPort
[ 35.911666] hm2/hm2_5i20.0: IO Pin 054 (P4-13): IOPort
[ 35.911673] hm2/hm2_5i20.0: IO Pin 055 (P4-15): IOPort
[ 35.911680] hm2/hm2_5i20.0: IO Pin 056 (P4-17): IOPort
[ 35.911687] hm2/hm2_5i20.0: IO Pin 057 (P4-19): IOPort
[ 35.911694] hm2/hm2_5i20.0: IO Pin 058 (P4-21): IOPort
[ 35.911701] hm2/hm2_5i20.0: IO Pin 059 (P4-23): IOPort
[ 35.911708] hm2/hm2_5i20.0: IO Pin 060 (P4-25): IOPort
[ 35.911715] hm2/hm2_5i20.0: IO Pin 061 (P4-27): IOPort
[ 35.911722] hm2/hm2_5i20.0: IO Pin 062 (P4-29): IOPort
[ 35.911729] hm2/hm2_5i20.0: IO Pin 063 (P4-31): IOPort
[ 35.911736] hm2/hm2_5i20.0: IO Pin 064 (P4-33): IOPort
[ 35.911743] hm2/hm2_5i20.0: IO Pin 065 (P4-35): IOPort
[ 35.911750] hm2/hm2_5i20.0: IO Pin 066 (P4-37): IOPort
[ 35.911757] hm2/hm2_5i20.0: IO Pin 067 (P4-39): IOPort
[ 35.911764] hm2/hm2_5i20.0: IO Pin 068 (P4-41): IOPort
[ 35.911771] hm2/hm2_5i20.0: IO Pin 069 (P4-43): IOPort
[ 35.911778] hm2/hm2_5i20.0: IO Pin 070 (P4-45): IOPort
[ 35.911785] hm2/hm2_5i20.0: IO Pin 071 (P4-47): IOPort
[ 35.912251] hm2/hm2_5i20.0: registered
[ 35.912259] hm2_5i20.0: initialized AnyIO board at 0000:04:00.0
[ 35.920535] config string '0 out'
[ 43.730695] hm2_5i20.0: dropping AnyIO board at 0000:04:00.0
[ 43.730714] hm2/hm2_5i20.0: unregistered
[ 43.730870] hm2_pci: driver unloaded
[ 43.738793] hm2: unloading
[ 50.926758] RTAI[math]: unloaded.
[ 50.932714] SCHED releases registered named ALIEN PEDV$D
[ 50.942938] RTAI[malloc]: unloaded.
[ 51.040091] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 51.045752] I-pipe: head domain RTAI unregistered.
[ 51.046010] RTAI[hal]: unmounted.
[ 129.791192] I-pipe: head domain RTAI registered.
[ 129.791217] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 129.791432] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 129.791448] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 8312460, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 129.791461] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 129.791475] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8312460, 8312460, 8188500
[ 129.812326] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 129.812480] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 129.812500] RTAI[sched]: hard timer type/freq = APIC/8312460(Hz); default timing: oneshot; linear timed lists.
[ 129.812517] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 129.812530] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 129.834710] RTAI[math]: loaded.
[ 130.057845] hm2: loading Mesa HostMot2 driver version 0.15
[ 130.063740] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 130.063836] hm2_pci: discovered 5i20 at 0000:04:00.0
[ 130.216445] hm2/hm2_5i20.0: WARNING: this firmware has Muxed Encoder v2!
[ 130.216457] hm2/hm2_5i20.0: WARNING: velocity computation will be incorrect!
[ 130.216464] hm2/hm2_5i20.0: WARNING: upgrade your firmware!
[ 130.231011] hm2/hm2_5i20.0: 72 I/O Pins used:
[ 130.231022] hm2/hm2_5i20.0: IO Pin 000 (P2-01): PWMGen #0, pin Not-Enable (Output)
[ 130.231032] hm2/hm2_5i20.0: IO Pin 001 (P2-03): Muxed Encoder #0, pin Muxed A (Input)
[ 130.231040] hm2/hm2_5i20.0: IO Pin 002 (P2-05): Muxed Encoder #0, pin Muxed B (Input)
[ 130.231049] hm2/hm2_5i20.0: IO Pin 003 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 130.231058] hm2/hm2_5i20.0: IO Pin 004 (P2-09): Muxed Encoder #1, pin Muxed A (Input)
[ 130.231066] hm2/hm2_5i20.0: IO Pin 005 (P2-11): Muxed Encoder #1, pin Muxed B (Input)
[ 130.231075] hm2/hm2_5i20.0: IO Pin 006 (P2-13): Muxed Encoder #1, pin Muxed Index (Input)
[ 130.231084] hm2/hm2_5i20.0: IO Pin 007 (P2-15): Muxed Encoder #2, pin Muxed A (Input)
[ 130.231092] hm2/hm2_5i20.0: IO Pin 008 (P2-17): Muxed Encoder #2, pin Muxed B (Input)
[ 130.231101] hm2/hm2_5i20.0: IO Pin 009 (P2-19): Muxed Encoder #2, pin Muxed Index (Input)
[ 130.231110] hm2/hm2_5i20.0: IO Pin 010 (P2-21): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 130.231119] hm2/hm2_5i20.0: IO Pin 011 (P2-23): PWMGen #0, pin Out0 (PWM or Up) (Output)
[ 130.231128] hm2/hm2_5i20.0: IO Pin 012 (P2-25): PWMGen #0, pin Out1 (Dir or Down) (Output)
[ 130.231137] hm2/hm2_5i20.0: IO Pin 013 (P2-27): PWMGen #1, pin Out0 (PWM or Up) (Output)
[ 130.231146] hm2/hm2_5i20.0: IO Pin 014 (P2-29): PWMGen #1, pin Out1 (Dir or Down) (Output)
[ 130.231155] hm2/hm2_5i20.0: IO Pin 015 (P2-31): PWMGen #2, pin Out0 (PWM or Up) (Output)
[ 130.231163] hm2/hm2_5i20.0: IO Pin 016 (P2-33): PWMGen #2, pin Out1 (Dir or Down) (Output)
[ 130.231172] hm2/hm2_5i20.0: IO Pin 017 (P2-35): PWMGen #3, pin Out0 (PWM or Up) (Output)
[ 130.231181] hm2/hm2_5i20.0: IO Pin 018 (P2-37): PWMGen #3, pin Out1 (Dir or Down) (Output)
[ 130.231190] hm2/hm2_5i20.0: IO Pin 019 (P2-39): PWMGen #4, pin Out0 (PWM or Up) (Output)
[ 130.231199] hm2/hm2_5i20.0: IO Pin 020 (P2-41): PWMGen #4, pin Out1 (Dir or Down) (Output)
[ 130.231208] hm2/hm2_5i20.0: IO Pin 021 (P2-43): PWMGen #5, pin Out0 (PWM or Up) (Output)
[ 130.231217] hm2/hm2_5i20.0: IO Pin 022 (P2-45): PWMGen #5, pin Out1 (Dir or Down) (Output)
[ 130.231225] hm2/hm2_5i20.0: IO Pin 023 (P2-47): PWMGen #0, pin Not-Enable (Output)
[ 130.231233] hm2/hm2_5i20.0: IO Pin 024 (P3-01): IOPort
[ 130.231240] hm2/hm2_5i20.0: IO Pin 025 (P3-03): IOPort
[ 130.231247] hm2/hm2_5i20.0: IO Pin 026 (P3-05): IOPort
[ 130.231254] hm2/hm2_5i20.0: IO Pin 027 (P3-07): IOPort
[ 130.231261] hm2/hm2_5i20.0: IO Pin 028 (P3-09): IOPort
[ 130.231268] hm2/hm2_5i20.0: IO Pin 029 (P3-11): IOPort
[ 130.231277] hm2/hm2_5i20.0: IO Pin 030 (P3-13): IOPort
[ 130.231284] hm2/hm2_5i20.0: IO Pin 031 (P3-15): IOPort
[ 130.231292] hm2/hm2_5i20.0: IO Pin 032 (P3-17): IOPort
[ 130.231301] hm2/hm2_5i20.0: IO Pin 033 (P3-19): IOPort
[ 130.231310] hm2/hm2_5i20.0: IO Pin 034 (P3-21): Muxed Encoder Select #3, pin Mux Select 0 (Output)
[ 130.231318] hm2/hm2_5i20.0: IO Pin 035 (P3-23): IOPort
[ 130.231325] hm2/hm2_5i20.0: IO Pin 036 (P3-25): IOPort
[ 130.231332] hm2/hm2_5i20.0: IO Pin 037 (P3-27): IOPort
[ 130.231339] hm2/hm2_5i20.0: IO Pin 038 (P3-29): IOPort
[ 130.231346] hm2/hm2_5i20.0: IO Pin 039 (P3-31): IOPort
[ 130.231353] hm2/hm2_5i20.0: IO Pin 040 (P3-33): IOPort
[ 130.231360] hm2/hm2_5i20.0: IO Pin 041 (P3-35): IOPort
[ 130.231367] hm2/hm2_5i20.0: IO Pin 042 (P3-37): IOPort
[ 130.231374] hm2/hm2_5i20.0: IO Pin 043 (P3-39): IOPort
[ 130.231381] hm2/hm2_5i20.0: IO Pin 044 (P3-41): IOPort
[ 130.231388] hm2/hm2_5i20.0: IO Pin 045 (P3-43): IOPort
[ 130.231394] hm2/hm2_5i20.0: IO Pin 046 (P3-45): IOPort
[ 130.231401] hm2/hm2_5i20.0: IO Pin 047 (P3-47): IOPort
[ 130.231410] hm2/hm2_5i20.0: IO Pin 048 (P4-01): Muxed Encoder #0, pin Muxed IndexMask (Input)
[ 130.231419] hm2/hm2_5i20.0: IO Pin 049 (P4-03): Muxed Encoder #1, pin Muxed IndexMask (Input)
[ 130.231428] hm2/hm2_5i20.0: IO Pin 050 (P4-05): Muxed Encoder #2, pin Muxed IndexMask (Input)
[ 130.231435] hm2/hm2_5i20.0: IO Pin 051 (P4-07): IOPort
[ 130.231442] hm2/hm2_5i20.0: IO Pin 052 (P4-09): IOPort
[ 130.231449] hm2/hm2_5i20.0: IO Pin 053 (P4-11): IOPort
[ 130.231456] hm2/hm2_5i20.0: IO Pin 054 (P4-13): IOPort
[ 130.231463] hm2/hm2_5i20.0: IO Pin 055 (P4-15): IOPort
[ 130.231470] hm2/hm2_5i20.0: IO Pin 056 (P4-17): IOPort
[ 130.231477] hm2/hm2_5i20.0: IO Pin 057 (P4-19): IOPort
[ 130.231484] hm2/hm2_5i20.0: IO Pin 058 (P4-21): IOPort
[ 130.231491] hm2/hm2_5i20.0: IO Pin 059 (P4-23): IOPort
[ 130.231498] hm2/hm2_5i20.0: IO Pin 060 (P4-25): IOPort
[ 130.231505] hm2/hm2_5i20.0: IO Pin 061 (P4-27): IOPort
[ 130.231512] hm2/hm2_5i20.0: IO Pin 062 (P4-29): IOPort
[ 130.231519] hm2/hm2_5i20.0: IO Pin 063 (P4-31): IOPort
[ 130.231526] hm2/hm2_5i20.0: IO Pin 064 (P4-33): IOPort
[ 130.231533] hm2/hm2_5i20.0: IO Pin 065 (P4-35): IOPort
[ 130.231540] hm2/hm2_5i20.0: IO Pin 066 (P4-37): IOPort
[ 130.231547] hm2/hm2_5i20.0: IO Pin 067 (P4-39): IOPort
[ 130.231554] hm2/hm2_5i20.0: IO Pin 068 (P4-41): IOPort
[ 130.231561] hm2/hm2_5i20.0: IO Pin 069 (P4-43): IOPort
[ 130.231568] hm2/hm2_5i20.0: IO Pin 070 (P4-45): IOPort
[ 130.231575] hm2/hm2_5i20.0: IO Pin 071 (P4-47): IOPort
[ 130.232037] hm2/hm2_5i20.0: registered
[ 130.232044] hm2_5i20.0: initialized AnyIO board at 0000:04:00.0
[ 130.239617] config string '0 out'
[ 130.965986] hm2_5i20.0: dropping AnyIO board at 0000:04:00.0
[ 130.966003] hm2/hm2_5i20.0: unregistered
[ 130.966143] hm2_pci: driver unloaded
[ 130.971762] hm2: unloading
[ 133.241907] RTAI[math]: unloaded.
[ 133.247570] SCHED releases registered named ALIEN PEDV$D
[ 133.266317] RTAI[malloc]: unloaded.
[ 133.364054] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 133.369611] I-pipe: head domain RTAI unregistered.
[ 133.369837] RTAI[hal]: unmounted.
[ 173.341147] I-pipe: head domain RTAI registered.
[ 173.341170] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 173.341456] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 173.341470] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 8312460, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 173.341487] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 173.341501] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8312460, 8312460, 8197250
[ 173.361019] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 173.361177] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 173.361196] RTAI[sched]: hard timer type/freq = APIC/8312460(Hz); default timing: oneshot; linear timed lists.
[ 173.361209] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 173.361218] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 173.383242] RTAI[math]: loaded.
[ 173.607041] hm2: loading Mesa HostMot2 driver version 0.15
[ 173.612730] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 173.612841] hm2_pci: discovered 5i20 at 0000:04:00.0
[ 173.765603] hm2/hm2_5i20.0: WARNING: this firmware has Muxed Encoder v2!
[ 173.765616] hm2/hm2_5i20.0: WARNING: velocity computation will be incorrect!
[ 173.765623] hm2/hm2_5i20.0: WARNING: upgrade your firmware!
[ 173.780199] hm2/hm2_5i20.0: 72 I/O Pins used:
[ 173.780210] hm2/hm2_5i20.0: IO Pin 000 (P2-01): PWMGen #0, pin Not-Enable (Output)
[ 173.780219] hm2/hm2_5i20.0: IO Pin 001 (P2-03): Muxed Encoder #0, pin Muxed A (Input)
[ 173.780228] hm2/hm2_5i20.0: IO Pin 002 (P2-05): Muxed Encoder #0, pin Muxed B (Input)
[ 173.780236] hm2/hm2_5i20.0: IO Pin 003 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 173.780245] hm2/hm2_5i20.0: IO Pin 004 (P2-09): Muxed Encoder #1, pin Muxed A (Input)
[ 173.780254] hm2/hm2_5i20.0: IO Pin 005 (P2-11): Muxed Encoder #1, pin Muxed B (Input)
[ 173.780263] hm2/hm2_5i20.0: IO Pin 006 (P2-13): Muxed Encoder #1, pin Muxed Index (Input)
[ 173.780271] hm2/hm2_5i20.0: IO Pin 007 (P2-15): Muxed Encoder #2, pin Muxed A (Input)
[ 173.780280] hm2/hm2_5i20.0: IO Pin 008 (P2-17): Muxed Encoder #2, pin Muxed B (Input)
[ 173.780289] hm2/hm2_5i20.0: IO Pin 009 (P2-19): Muxed Encoder #2, pin Muxed Index (Input)
[ 173.780298] hm2/hm2_5i20.0: IO Pin 010 (P2-21): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 173.780307] hm2/hm2_5i20.0: IO Pin 011 (P2-23): PWMGen #0, pin Out0 (PWM or Up) (Output)
[ 173.780316] hm2/hm2_5i20.0: IO Pin 012 (P2-25): PWMGen #0, pin Out1 (Dir or Down) (Output)
[ 173.780324] hm2/hm2_5i20.0: IO Pin 013 (P2-27): PWMGen #1, pin Out0 (PWM or Up) (Output)
[ 173.780333] hm2/hm2_5i20.0: IO Pin 014 (P2-29): PWMGen #1, pin Out1 (Dir or Down) (Output)
[ 173.780342] hm2/hm2_5i20.0: IO Pin 015 (P2-31): PWMGen #2, pin Out0 (PWM or Up) (Output)
[ 173.780351] hm2/hm2_5i20.0: IO Pin 016 (P2-33): PWMGen #2, pin Out1 (Dir or Down) (Output)
[ 173.780360] hm2/hm2_5i20.0: IO Pin 017 (P2-35): PWMGen #3, pin Out0 (PWM or Up) (Output)
[ 173.780369] hm2/hm2_5i20.0: IO Pin 018 (P2-37): PWMGen #3, pin Out1 (Dir or Down) (Output)
[ 173.780377] hm2/hm2_5i20.0: IO Pin 019 (P2-39): PWMGen #4, pin Out0 (PWM or Up) (Output)
[ 173.780386] hm2/hm2_5i20.0: IO Pin 020 (P2-41): PWMGen #4, pin Out1 (Dir or Down) (Output)
[ 173.780395] hm2/hm2_5i20.0: IO Pin 021 (P2-43): PWMGen #5, pin Out0 (PWM or Up) (Output)
[ 173.780404] hm2/hm2_5i20.0: IO Pin 022 (P2-45): PWMGen #5, pin Out1 (Dir or Down) (Output)
[ 173.780413] hm2/hm2_5i20.0: IO Pin 023 (P2-47): PWMGen #0, pin Not-Enable (Output)
[ 173.780420] hm2/hm2_5i20.0: IO Pin 024 (P3-01): IOPort
[ 173.780427] hm2/hm2_5i20.0: IO Pin 025 (P3-03): IOPort
[ 173.780434] hm2/hm2_5i20.0: IO Pin 026 (P3-05): IOPort
[ 173.780441] hm2/hm2_5i20.0: IO Pin 027 (P3-07): IOPort
[ 173.780448] hm2/hm2_5i20.0: IO Pin 028 (P3-09): IOPort
[ 173.780455] hm2/hm2_5i20.0: IO Pin 029 (P3-11): IOPort
[ 173.780462] hm2/hm2_5i20.0: IO Pin 030 (P3-13): IOPort
[ 173.780469] hm2/hm2_5i20.0: IO Pin 031 (P3-15): IOPort
[ 173.780476] hm2/hm2_5i20.0: IO Pin 032 (P3-17): IOPort
[ 173.780483] hm2/hm2_5i20.0: IO Pin 033 (P3-19): IOPort
[ 173.780491] hm2/hm2_5i20.0: IO Pin 034 (P3-21): Muxed Encoder Select #3, pin Mux Select 0 (Output)
[ 173.780499] hm2/hm2_5i20.0: IO Pin 035 (P3-23): IOPort
[ 173.780506] hm2/hm2_5i20.0: IO Pin 036 (P3-25): IOPort
[ 173.780513] hm2/hm2_5i20.0: IO Pin 037 (P3-27): IOPort
[ 173.780520] hm2/hm2_5i20.0: IO Pin 038 (P3-29): IOPort
[ 173.780527] hm2/hm2_5i20.0: IO Pin 039 (P3-31): IOPort
[ 173.780534] hm2/hm2_5i20.0: IO Pin 040 (P3-33): IOPort
[ 173.780541] hm2/hm2_5i20.0: IO Pin 041 (P3-35): IOPort
[ 173.780548] hm2/hm2_5i20.0: IO Pin 042 (P3-37): IOPort
[ 173.780555] hm2/hm2_5i20.0: IO Pin 043 (P3-39): IOPort
[ 173.780562] hm2/hm2_5i20.0: IO Pin 044 (P3-41): IOPort
[ 173.780569] hm2/hm2_5i20.0: IO Pin 045 (P3-43): IOPort
[ 173.780576] hm2/hm2_5i20.0: IO Pin 046 (P3-45): IOPort
[ 173.780583] hm2/hm2_5i20.0: IO Pin 047 (P3-47): IOPort
[ 173.780591] hm2/hm2_5i20.0: IO Pin 048 (P4-01): Muxed Encoder #0, pin Muxed IndexMask (Input)
[ 173.780600] hm2/hm2_5i20.0: IO Pin 049 (P4-03): Muxed Encoder #1, pin Muxed IndexMask (Input)
[ 173.780609] hm2/hm2_5i20.0: IO Pin 050 (P4-05): Muxed Encoder #2, pin Muxed IndexMask (Input)
[ 173.780617] hm2/hm2_5i20.0: IO Pin 051 (P4-07): IOPort
[ 173.780624] hm2/hm2_5i20.0: IO Pin 052 (P4-09): IOPort
[ 173.780631] hm2/hm2_5i20.0: IO Pin 053 (P4-11): IOPort
[ 173.780638] hm2/hm2_5i20.0: IO Pin 054 (P4-13): IOPort
[ 173.780645] hm2/hm2_5i20.0: IO Pin 055 (P4-15): IOPort
[ 173.780694] hm2/hm2_5i20.0: IO Pin 056 (P4-17): IOPort
[ 173.780705] hm2/hm2_5i20.0: IO Pin 057 (P4-19): IOPort
[ 173.780714] hm2/hm2_5i20.0: IO Pin 058 (P4-21): IOPort
[ 173.780723] hm2/hm2_5i20.0: IO Pin 059 (P4-23): IOPort
[ 173.780732] hm2/hm2_5i20.0: IO Pin 060 (P4-25): IOPort
[ 173.780742] hm2/hm2_5i20.0: IO Pin 061 (P4-27): IOPort
[ 173.780751] hm2/hm2_5i20.0: IO Pin 062 (P4-29): IOPort
[ 173.780760] hm2/hm2_5i20.0: IO Pin 063 (P4-31): IOPort
[ 173.780769] hm2/hm2_5i20.0: IO Pin 064 (P4-33): IOPort
[ 173.780779] hm2/hm2_5i20.0: IO Pin 065 (P4-35): IOPort
[ 173.780788] hm2/hm2_5i20.0: IO Pin 066 (P4-37): IOPort
[ 173.780797] hm2/hm2_5i20.0: IO Pin 067 (P4-39): IOPort
[ 173.780806] hm2/hm2_5i20.0: IO Pin 068 (P4-41): IOPort
[ 173.780816] hm2/hm2_5i20.0: IO Pin 069 (P4-43): IOPort
[ 173.780825] hm2/hm2_5i20.0: IO Pin 070 (P4-45): IOPort
[ 173.780834] hm2/hm2_5i20.0: IO Pin 071 (P4-47): IOPort
[ 173.781444] hm2/hm2_5i20.0: registered
[ 173.781453] hm2_5i20.0: initialized AnyIO board at 0000:04:00.0
[ 173.788100] config string '0 out'
[ 184.332963] hm2_5i20.0: dropping AnyIO board at 0000:04:00.0
[ 184.332980] hm2/hm2_5i20.0: unregistered
[ 184.333132] hm2_pci: driver unloaded
[ 184.340450] hm2: unloading
[ 186.636541] RTAI[math]: unloaded.
[ 186.642023] SCHED releases registered named ALIEN PEDV$D
[ 186.651141] RTAI[malloc]: unloaded.
[ 186.748074] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 186.753590] I-pipe: head domain RTAI unregistered.
[ 186.753809] RTAI[hal]: unmounted.
[ 340.580622] I-pipe: head domain RTAI registered.
[ 340.580647] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 340.580867] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 340.580882] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 8312460, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 340.580895] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 340.580909] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8312460, 8312460, 8221500
[ 340.600309] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 340.600456] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 340.600472] RTAI[sched]: hard timer type/freq = APIC/8312460(Hz); default timing: oneshot; linear timed lists.
[ 340.600485] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 340.600494] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 340.630788] RTAI[math]: loaded.
[ 340.749782] hm2: loading Mesa HostMot2 driver version 0.15
[ 340.755497] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 340.755591] hm2_pci: discovered 5i20 at 0000:04:00.0
[ 340.908279] hm2/hm2_5i20.0: WARNING: this firmware has Muxed Encoder v2!
[ 340.908291] hm2/hm2_5i20.0: WARNING: velocity computation will be incorrect!
[ 340.908298] hm2/hm2_5i20.0: WARNING: upgrade your firmware!
[ 340.922943] hm2/hm2_5i20.0: 72 I/O Pins used:
[ 340.922955] hm2/hm2_5i20.0: IO Pin 000 (P2-01): PWMGen #0, pin Not-Enable (Output)
[ 340.922965] hm2/hm2_5i20.0: IO Pin 001 (P2-03): Muxed Encoder #0, pin Muxed A (Input)
[ 340.922973] hm2/hm2_5i20.0: IO Pin 002 (P2-05): Muxed Encoder #0, pin Muxed B (Input)
[ 340.922982] hm2/hm2_5i20.0: IO Pin 003 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 340.922991] hm2/hm2_5i20.0: IO Pin 004 (P2-09): Muxed Encoder #1, pin Muxed A (Input)
[ 340.923000] hm2/hm2_5i20.0: IO Pin 005 (P2-11): Muxed Encoder #1, pin Muxed B (Input)
[ 340.923008] hm2/hm2_5i20.0: IO Pin 006 (P2-13): Muxed Encoder #1, pin Muxed Index (Input)
[ 340.923017] hm2/hm2_5i20.0: IO Pin 007 (P2-15): Muxed Encoder #2, pin Muxed A (Input)
[ 340.923026] hm2/hm2_5i20.0: IO Pin 008 (P2-17): Muxed Encoder #2, pin Muxed B (Input)
[ 340.923034] hm2/hm2_5i20.0: IO Pin 009 (P2-19): Muxed Encoder #2, pin Muxed Index (Input)
[ 340.923043] hm2/hm2_5i20.0: IO Pin 010 (P2-21): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 340.923052] hm2/hm2_5i20.0: IO Pin 011 (P2-23): PWMGen #0, pin Out0 (PWM or Up) (Output)
[ 340.923061] hm2/hm2_5i20.0: IO Pin 012 (P2-25): PWMGen #0, pin Out1 (Dir or Down) (Output)
[ 340.923070] hm2/hm2_5i20.0: IO Pin 013 (P2-27): PWMGen #1, pin Out0 (PWM or Up) (Output)
[ 340.923083] hm2/hm2_5i20.0: IO Pin 014 (P2-29): PWMGen #1, pin Out1 (Dir or Down) (Output)
[ 340.923093] hm2/hm2_5i20.0: IO Pin 015 (P2-31): PWMGen #2, pin Out0 (PWM or Up) (Output)
[ 340.923104] hm2/hm2_5i20.0: IO Pin 016 (P2-33): PWMGen #2, pin Out1 (Dir or Down) (Output)
[ 340.923114] hm2/hm2_5i20.0: IO Pin 017 (P2-35): PWMGen #3, pin Out0 (PWM or Up) (Output)
[ 340.923122] hm2/hm2_5i20.0: IO Pin 018 (P2-37): PWMGen #3, pin Out1 (Dir or Down) (Output)
[ 340.923131] hm2/hm2_5i20.0: IO Pin 019 (P2-39): PWMGen #4, pin Out0 (PWM or Up) (Output)
[ 340.923140] hm2/hm2_5i20.0: IO Pin 020 (P2-41): PWMGen #4, pin Out1 (Dir or Down) (Output)
[ 340.923149] hm2/hm2_5i20.0: IO Pin 021 (P2-43): PWMGen #5, pin Out0 (PWM or Up) (Output)
[ 340.923158] hm2/hm2_5i20.0: IO Pin 022 (P2-45): PWMGen #5, pin Out1 (Dir or Down) (Output)
[ 340.923166] hm2/hm2_5i20.0: IO Pin 023 (P2-47): PWMGen #0, pin Not-Enable (Output)
[ 340.923174] hm2/hm2_5i20.0: IO Pin 024 (P3-01): IOPort
[ 340.923181] hm2/hm2_5i20.0: IO Pin 025 (P3-03): IOPort
[ 340.923188] hm2/hm2_5i20.0: IO Pin 026 (P3-05): IOPort
[ 340.923195] hm2/hm2_5i20.0: IO Pin 027 (P3-07): IOPort
[ 340.923202] hm2/hm2_5i20.0: IO Pin 028 (P3-09): IOPort
[ 340.923209] hm2/hm2_5i20.0: IO Pin 029 (P3-11): IOPort
[ 340.923216] hm2/hm2_5i20.0: IO Pin 030 (P3-13): IOPort
[ 340.923223] hm2/hm2_5i20.0: IO Pin 031 (P3-15): IOPort
[ 340.923230] hm2/hm2_5i20.0: IO Pin 032 (P3-17): IOPort
[ 340.923237] hm2/hm2_5i20.0: IO Pin 033 (P3-19): IOPort
[ 340.923245] hm2/hm2_5i20.0: IO Pin 034 (P3-21): Muxed Encoder Select #3, pin Mux Select 0 (Output)
[ 340.923253] hm2/hm2_5i20.0: IO Pin 035 (P3-23): IOPort
[ 340.923260] hm2/hm2_5i20.0: IO Pin 036 (P3-25): IOPort
[ 340.923267] hm2/hm2_5i20.0: IO Pin 037 (P3-27): IOPort
[ 340.923274] hm2/hm2_5i20.0: IO Pin 038 (P3-29): IOPort
[ 340.923281] hm2/hm2_5i20.0: IO Pin 039 (P3-31): IOPort
[ 340.923288] hm2/hm2_5i20.0: IO Pin 040 (P3-33): IOPort
[ 340.923295] hm2/hm2_5i20.0: IO Pin 041 (P3-35): IOPort
[ 340.923302] hm2/hm2_5i20.0: IO Pin 042 (P3-37): IOPort
[ 340.923309] hm2/hm2_5i20.0: IO Pin 043 (P3-39): IOPort
[ 340.923316] hm2/hm2_5i20.0: IO Pin 044 (P3-41): IOPort
[ 340.923323] hm2/hm2_5i20.0: IO Pin 045 (P3-43): IOPort
[ 340.923330] hm2/hm2_5i20.0: IO Pin 046 (P3-45): IOPort
[ 340.923337] hm2/hm2_5i20.0: IO Pin 047 (P3-47): IOPort
[ 340.923345] hm2/hm2_5i20.0: IO Pin 048 (P4-01): Muxed Encoder #0, pin Muxed IndexMask (Input)
[ 340.923354] hm2/hm2_5i20.0: IO Pin 049 (P4-03): Muxed Encoder #1, pin Muxed IndexMask (Input)
[ 340.923363] hm2/hm2_5i20.0: IO Pin 050 (P4-05): Muxed Encoder #2, pin Muxed IndexMask (Input)
[ 340.923371] hm2/hm2_5i20.0: IO Pin 051 (P4-07): IOPort
[ 340.923378] hm2/hm2_5i20.0: IO Pin 052 (P4-09): IOPort
[ 340.923385] hm2/hm2_5i20.0: IO Pin 053 (P4-11): IOPort
[ 340.923392] hm2/hm2_5i20.0: IO Pin 054 (P4-13): IOPort
[ 340.923399] hm2/hm2_5i20.0: IO Pin 055 (P4-15): IOPort
[ 340.923406] hm2/hm2_5i20.0: IO Pin 056 (P4-17): IOPort
[ 340.923413] hm2/hm2_5i20.0: IO Pin 057 (P4-19): IOPort
[ 340.923420] hm2/hm2_5i20.0: IO Pin 058 (P4-21): IOPort
[ 340.923427] hm2/hm2_5i20.0: IO Pin 059 (P4-23): IOPort
[ 340.923434] hm2/hm2_5i20.0: IO Pin 060 (P4-25): IOPort
[ 340.923441] hm2/hm2_5i20.0: IO Pin 061 (P4-27): IOPort
[ 340.923447] hm2/hm2_5i20.0: IO Pin 062 (P4-29): IOPort
[ 340.923454] hm2/hm2_5i20.0: IO Pin 063 (P4-31): IOPort
[ 340.923461] hm2/hm2_5i20.0: IO Pin 064 (P4-33): IOPort
[ 340.923468] hm2/hm2_5i20.0: IO Pin 065 (P4-35): IOPort
[ 340.923475] hm2/hm2_5i20.0: IO Pin 066 (P4-37): IOPort
[ 340.923482] hm2/hm2_5i20.0: IO Pin 067 (P4-39): IOPort
[ 340.923489] hm2/hm2_5i20.0: IO Pin 068 (P4-41): IOPort
[ 340.923496] hm2/hm2_5i20.0: IO Pin 069 (P4-43): IOPort
[ 340.923503] hm2/hm2_5i20.0: IO Pin 070 (P4-45): IOPort
[ 340.923510] hm2/hm2_5i20.0: IO Pin 071 (P4-47): IOPort
[ 340.923973] hm2/hm2_5i20.0: registered
[ 340.923981] hm2_5i20.0: initialized AnyIO board at 0000:04:00.0
[ 340.930668] config string '0 out'
[ 341.670104] hm2_5i20.0: dropping AnyIO board at 0000:04:00.0
[ 341.670121] hm2/hm2_5i20.0: unregistered
[ 341.670264] hm2_pci: driver unloaded
[ 341.675657] hm2: unloading
[ 343.954696] RTAI[math]: unloaded.
[ 343.960535] SCHED releases registered named ALIEN PEDV$D
[ 343.969862] RTAI[malloc]: unloaded.
[ 344.068067] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 344.073725] I-pipe: head domain RTAI unregistered.
[ 344.074007] RTAI[hal]: unmounted.
[ 354.564641] I-pipe: head domain RTAI registered.
[ 354.564659] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 354.564899] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 354.564909] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 8312460, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 354.564918] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 354.564929] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8312460, 8312460, 8208750
[ 354.588294] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 354.588440] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 354.588461] RTAI[sched]: hard timer type/freq = APIC/8312460(Hz); default timing: oneshot; linear timed lists.
[ 354.588477] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 354.588489] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 354.611176] RTAI[math]: loaded.
[ 354.831237] hm2: loading Mesa HostMot2 driver version 0.15
[ 354.836951] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 354.837059] hm2_pci: discovered 5i20 at 0000:04:00.0
[ 354.990424] hm2/hm2_5i20.0: WARNING: this firmware has Muxed Encoder v2!
[ 354.990437] hm2/hm2_5i20.0: WARNING: velocity computation will be incorrect!
[ 354.990444] hm2/hm2_5i20.0: WARNING: upgrade your firmware!
[ 355.005084] hm2/hm2_5i20.0: 72 I/O Pins used:
[ 355.005097] hm2/hm2_5i20.0: IO Pin 000 (P2-01): PWMGen #0, pin Not-Enable (Output)
[ 355.005107] hm2/hm2_5i20.0: IO Pin 001 (P2-03): Muxed Encoder #0, pin Muxed A (Input)
[ 355.005115] hm2/hm2_5i20.0: IO Pin 002 (P2-05): Muxed Encoder #0, pin Muxed B (Input)
[ 355.005124] hm2/hm2_5i20.0: IO Pin 003 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 355.005133] hm2/hm2_5i20.0: IO Pin 004 (P2-09): Muxed Encoder #1, pin Muxed A (Input)
[ 355.005141] hm2/hm2_5i20.0: IO Pin 005 (P2-11): Muxed Encoder #1, pin Muxed B (Input)
[ 355.005150] hm2/hm2_5i20.0: IO Pin 006 (P2-13): Muxed Encoder #1, pin Muxed Index (Input)
[ 355.005159] hm2/hm2_5i20.0: IO Pin 007 (P2-15): Muxed Encoder #2, pin Muxed A (Input)
[ 355.005168] hm2/hm2_5i20.0: IO Pin 008 (P2-17): Muxed Encoder #2, pin Muxed B (Input)
[ 355.005178] hm2/hm2_5i20.0: IO Pin 009 (P2-19): Muxed Encoder #2, pin Muxed Index (Input)
[ 355.005188] hm2/hm2_5i20.0: IO Pin 010 (P2-21): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 355.005198] hm2/hm2_5i20.0: IO Pin 011 (P2-23): PWMGen #0, pin Out0 (PWM or Up) (Output)
[ 355.005209] hm2/hm2_5i20.0: IO Pin 012 (P2-25): PWMGen #0, pin Out1 (Dir or Down) (Output)
[ 355.005219] hm2/hm2_5i20.0: IO Pin 013 (P2-27): PWMGen #1, pin Out0 (PWM or Up) (Output)
[ 355.005229] hm2/hm2_5i20.0: IO Pin 014 (P2-29): PWMGen #1, pin Out1 (Dir or Down) (Output)
[ 355.005240] hm2/hm2_5i20.0: IO Pin 015 (P2-31): PWMGen #2, pin Out0 (PWM or Up) (Output)
[ 355.005250] hm2/hm2_5i20.0: IO Pin 016 (P2-33): PWMGen #2, pin Out1 (Dir or Down) (Output)
[ 355.005261] hm2/hm2_5i20.0: IO Pin 017 (P2-35): PWMGen #3, pin Out0 (PWM or Up) (Output)
[ 355.005271] hm2/hm2_5i20.0: IO Pin 018 (P2-37): PWMGen #3, pin Out1 (Dir or Down) (Output)
[ 355.005282] hm2/hm2_5i20.0: IO Pin 019 (P2-39): PWMGen #4, pin Out0 (PWM or Up) (Output)
[ 355.005293] hm2/hm2_5i20.0: IO Pin 020 (P2-41): PWMGen #4, pin Out1 (Dir or Down) (Output)
[ 355.005303] hm2/hm2_5i20.0: IO Pin 021 (P2-43): PWMGen #5, pin Out0 (PWM or Up) (Output)
[ 355.005312] hm2/hm2_5i20.0: IO Pin 022 (P2-45): PWMGen #5, pin Out1 (Dir or Down) (Output)
[ 355.005321] hm2/hm2_5i20.0: IO Pin 023 (P2-47): PWMGen #0, pin Not-Enable (Output)
[ 355.005329] hm2/hm2_5i20.0: IO Pin 024 (P3-01): IOPort
[ 355.005337] hm2/hm2_5i20.0: IO Pin 025 (P3-03): IOPort
[ 355.005348] hm2/hm2_5i20.0: IO Pin 026 (P3-05): IOPort
[ 355.005355] hm2/hm2_5i20.0: IO Pin 027 (P3-07): IOPort
[ 355.005364] hm2/hm2_5i20.0: IO Pin 028 (P3-09): IOPort
[ 355.005371] hm2/hm2_5i20.0: IO Pin 029 (P3-11): IOPort
[ 355.005378] hm2/hm2_5i20.0: IO Pin 030 (P3-13): IOPort
[ 355.005387] hm2/hm2_5i20.0: IO Pin 031 (P3-15): IOPort
[ 355.005394] hm2/hm2_5i20.0: IO Pin 032 (P3-17): IOPort
[ 355.005401] hm2/hm2_5i20.0: IO Pin 033 (P3-19): IOPort
[ 355.005409] hm2/hm2_5i20.0: IO Pin 034 (P3-21): Muxed Encoder Select #3, pin Mux Select 0 (Output)
[ 355.005418] hm2/hm2_5i20.0: IO Pin 035 (P3-23): IOPort
[ 355.005425] hm2/hm2_5i20.0: IO Pin 036 (P3-25): IOPort
[ 355.005432] hm2/hm2_5i20.0: IO Pin 037 (P3-27): IOPort
[ 355.005439] hm2/hm2_5i20.0: IO Pin 038 (P3-29): IOPort
[ 355.005446] hm2/hm2_5i20.0: IO Pin 039 (P3-31): IOPort
[ 355.005453] hm2/hm2_5i20.0: IO Pin 040 (P3-33): IOPort
[ 355.005460] hm2/hm2_5i20.0: IO Pin 041 (P3-35): IOPort
[ 355.005468] hm2/hm2_5i20.0: IO Pin 042 (P3-37): IOPort
[ 355.005475] hm2/hm2_5i20.0: IO Pin 043 (P3-39): IOPort
[ 355.005482] hm2/hm2_5i20.0: IO Pin 044 (P3-41): IOPort
[ 355.005489] hm2/hm2_5i20.0: IO Pin 045 (P3-43): IOPort
[ 355.005496] hm2/hm2_5i20.0: IO Pin 046 (P3-45): IOPort
[ 355.005503] hm2/hm2_5i20.0: IO Pin 047 (P3-47): IOPort
[ 355.005511] hm2/hm2_5i20.0: IO Pin 048 (P4-01): Muxed Encoder #0, pin Muxed IndexMask (Input)
[ 355.005520] hm2/hm2_5i20.0: IO Pin 049 (P4-03): Muxed Encoder #1, pin Muxed IndexMask (Input)
[ 355.005529] hm2/hm2_5i20.0: IO Pin 050 (P4-05): Muxed Encoder #2, pin Muxed IndexMask (Input)
[ 355.005538] hm2/hm2_5i20.0: IO Pin 051 (P4-07): IOPort
[ 355.005545] hm2/hm2_5i20.0: IO Pin 052 (P4-09): IOPort
[ 355.005560] hm2/hm2_5i20.0: IO Pin 053 (P4-11): IOPort
[ 355.005568] hm2/hm2_5i20.0: IO Pin 054 (P4-13): IOPort
[ 355.005575] hm2/hm2_5i20.0: IO Pin 055 (P4-15): IOPort
[ 355.005585] hm2/hm2_5i20.0: IO Pin 056 (P4-17): IOPort
[ 355.005593] hm2/hm2_5i20.0: IO Pin 057 (P4-19): IOPort
[ 355.005603] hm2/hm2_5i20.0: IO Pin 058 (P4-21): IOPort
[ 355.005610] hm2/hm2_5i20.0: IO Pin 059 (P4-23): IOPort
[ 355.005620] hm2/hm2_5i20.0: IO Pin 060 (P4-25): IOPort
[ 355.005630] hm2/hm2_5i20.0: IO Pin 061 (P4-27): IOPort
[ 355.005639] hm2/hm2_5i20.0: IO Pin 062 (P4-29): IOPort
[ 355.005648] hm2/hm2_5i20.0: IO Pin 063 (P4-31): IOPort
[ 355.005656] hm2/hm2_5i20.0: IO Pin 064 (P4-33): IOPort
[ 355.005664] hm2/hm2_5i20.0: IO Pin 065 (P4-35): IOPort
[ 355.005672] hm2/hm2_5i20.0: IO Pin 066 (P4-37): IOPort
[ 355.005680] hm2/hm2_5i20.0: IO Pin 067 (P4-39): IOPort
[ 355.005687] hm2/hm2_5i20.0: IO Pin 068 (P4-41): IOPort
[ 355.005694] hm2/hm2_5i20.0: IO Pin 069 (P4-43): IOPort
[ 355.005701] hm2/hm2_5i20.0: IO Pin 070 (P4-45): IOPort
[ 355.005708] hm2/hm2_5i20.0: IO Pin 071 (P4-47): IOPort
[ 355.006171] hm2/hm2_5i20.0: registered
[ 355.006179] hm2_5i20.0: initialized AnyIO board at 0000:04:00.0
[ 355.012464] config string '0 out'
[ 355.756361] hm2_5i20.0: dropping AnyIO board at 0000:04:00.0
[ 355.756385] hm2/hm2_5i20.0: unregistered
[ 355.756619] hm2_pci: driver unloaded
[ 355.762111] hm2: unloading
[ 358.044480] RTAI[math]: unloaded.
[ 358.050007] SCHED releases registered named ALIEN PEDV$D
[ 358.061479] RTAI[malloc]: unloaded.
[ 358.160067] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 358.165744] I-pipe: head domain RTAI unregistered.
[ 358.165969] RTAI[hal]: unmounted.
[ 392.199575] I-pipe: head domain RTAI registered.
[ 392.199600] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 392.199818] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 392.199832] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 8312460, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 392.199843] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 392.199855] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8312460, 8312460, 8218000
[ 392.219466] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 392.219612] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 392.219626] RTAI[sched]: hard timer type/freq = APIC/8312460(Hz); default timing: oneshot; linear timed lists.
[ 392.219636] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 392.219643] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 392.645167] hm2/hm2_5i20.0: IO Pin 000 (P2-01): PWMGen #0, pin Not-Enable (Output)
[ 392.645176] hm2/hm2_5i20.0: IO Pin 001 (P2-03): Muxed Encoder #0, pin Muxed A (Input)
[ 392.645185] hm2/hm2_5i20.0: IO Pin 002 (P2-05): Muxed Encoder #0, pin Muxed B (Input)
[ 392.645194] hm2/hm2_5i20.0: IO Pin 003 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 392.645202] hm2/hm2_5i20.0: IO Pin 004 (P2-09): Muxed Encoder #1, pin Muxed A (Input)
[ 392.645211] hm2/hm2_5i20.0: IO Pin 005 (P2-11): Muxed Encoder #1, pin Muxed B (Input)
[ 392.645220] hm2/hm2_5i20.0: IO Pin 006 (P2-13): Muxed Encoder #1, pin Muxed Index (Input)
[ 392.645234] hm2/hm2_5i20.0: IO Pin 007 (P2-15): Muxed Encoder #2, pin Muxed A (Input)
[ 392.645242] hm2/hm2_5i20.0: IO Pin 008 (P2-17): Muxed Encoder #2, pin Muxed B (Input)
[ 392.645254] hm2/hm2_5i20.0: IO Pin 009 (P2-19): Muxed Encoder #2, pin Muxed Index (Input)
[ 392.645263] hm2/hm2_5i20.0: IO Pin 010 (P2-21): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 392.645272] hm2/hm2_5i20.0: IO Pin 011 (P2-23): PWMGen #0, pin Out0 (PWM or Up) (Output)
[ 392.645281] hm2/hm2_5i20.0: IO Pin 012 (P2-25): PWMGen #0, pin Out1 (Dir or Down) (Output)
[ 392.645290] hm2/hm2_5i20.0: IO Pin 013 (P2-27): PWMGen #1, pin Out0 (PWM or Up) (Output)
[ 392.645299] hm2/hm2_5i20.0: IO Pin 014 (P2-29): PWMGen #1, pin Out1 (Dir or Down) (Output)
[ 392.645308] hm2/hm2_5i20.0: IO Pin 015 (P2-31): PWMGen #2, pin Out0 (PWM or Up) (Output)
[ 392.645316] hm2/hm2_5i20.0: IO Pin 016 (P2-33): PWMGen #2, pin Out1 (Dir or Down) (Output)
[ 392.645325] hm2/hm2_5i20.0: IO Pin 017 (P2-35): PWMGen #3, pin Out0 (PWM or Up) (Output)
[ 392.645334] hm2/hm2_5i20.0: IO Pin 018 (P2-37): PWMGen #3, pin Out1 (Dir or Down) (Output)
[ 392.645343] hm2/hm2_5i20.0: IO Pin 019 (P2-39): PWMGen #4, pin Out0 (PWM or Up) (Output)
[ 392.645352] hm2/hm2_5i20.0: IO Pin 020 (P2-41): PWMGen #4, pin Out1 (Dir or Down) (Output)
[ 392.645361] hm2/hm2_5i20.0: IO Pin 021 (P2-43): PWMGen #5, pin Out0 (PWM or Up) (Output)
[ 392.645369] hm2/hm2_5i20.0: IO Pin 022 (P2-45): PWMGen #5, pin Out1 (Dir or Down) (Output)
[ 392.645378] hm2/hm2_5i20.0: IO Pin 023 (P2-47): PWMGen #0, pin Not-Enable (Output)
[ 392.645386] hm2/hm2_5i20.0: IO Pin 024 (P3-01): IOPort
[ 392.645393] hm2/hm2_5i20.0: IO Pin 025 (P3-03): IOPort
[ 392.645400] hm2/hm2_5i20.0: IO Pin 026 (P3-05): IOPort
[ 392.645407] hm2/hm2_5i20.0: IO Pin 027 (P3-07): IOPort
[ 392.645414] hm2/hm2_5i20.0: IO Pin 028 (P3-09): IOPort
[ 392.645421] hm2/hm2_5i20.0: IO Pin 029 (P3-11): IOPort
[ 392.645428] hm2/hm2_5i20.0: IO Pin 030 (P3-13): IOPort
[ 392.645435] hm2/hm2_5i20.0: IO Pin 031 (P3-15): IOPort
[ 392.645442] hm2/hm2_5i20.0: IO Pin 032 (P3-17): IOPort
[ 392.645449] hm2/hm2_5i20.0: IO Pin 033 (P3-19): IOPort
[ 392.645457] hm2/hm2_5i20.0: IO Pin 034 (P3-21): Muxed Encoder Select #3, pin Mux Select 0 (Output)
[ 392.645465] hm2/hm2_5i20.0: IO Pin 035 (P3-23): IOPort
[ 392.645472] hm2/hm2_5i20.0: IO Pin 036 (P3-25): IOPort
[ 392.645479] hm2/hm2_5i20.0: IO Pin 037 (P3-27): IOPort
[ 392.645486] hm2/hm2_5i20.0: IO Pin 038 (P3-29): IOPort
[ 392.645493] hm2/hm2_5i20.0: IO Pin 039 (P3-31): IOPort
[ 392.645500] hm2/hm2_5i20.0: IO Pin 040 (P3-33): IOPort
[ 392.645507] hm2/hm2_5i20.0: IO Pin 041 (P3-35): IOPort
[ 392.645513] hm2/hm2_5i20.0: IO Pin 042 (P3-37): IOPort
[ 392.645520] hm2/hm2_5i20.0: IO Pin 043 (P3-39): IOPort
[ 392.645527] hm2/hm2_5i20.0: IO Pin 044 (P3-41): IOPort
[ 392.645534] hm2/hm2_5i20.0: IO Pin 045 (P3-43): IOPort
[ 392.645541] hm2/hm2_5i20.0: IO Pin 046 (P3-45): IOPort
[ 392.645548] hm2/hm2_5i20.0: IO Pin 047 (P3-47): IOPort
[ 392.645556] hm2/hm2_5i20.0: IO Pin 048 (P4-01): Muxed Encoder #0, pin Muxed IndexMask (Input)
[ 392.645565] hm2/hm2_5i20.0: IO Pin 049 (P4-03): Muxed Encoder #1, pin Muxed IndexMask (Input)
[ 392.645574] hm2/hm2_5i20.0: IO Pin 050 (P4-05): Muxed Encoder #2, pin Muxed IndexMask (Input)
[ 392.645582] hm2/hm2_5i20.0: IO Pin 051 (P4-07): IOPort
[ 392.645589] hm2/hm2_5i20.0: IO Pin 052 (P4-09): IOPort
[ 392.645596] hm2/hm2_5i20.0: IO Pin 053 (P4-11): IOPort
[ 392.645603] hm2/hm2_5i20.0: IO Pin 054 (P4-13): IOPort
[ 392.645610] hm2/hm2_5i20.0: IO Pin 055 (P4-15): IOPort
[ 392.645617] hm2/hm2_5i20.0: IO Pin 056 (P4-17): IOPort
[ 392.645624] hm2/hm2_5i20.0: IO Pin 057 (P4-19): IOPort
[ 392.645631] hm2/hm2_5i20.0: IO Pin 058 (P4-21): IOPort
[ 392.645638] hm2/hm2_5i20.0: IO Pin 059 (P4-23): IOPort
[ 392.645645] hm2/hm2_5i20.0: IO Pin 060 (P4-25): IOPort
[ 392.645652] hm2/hm2_5i20.0: IO Pin 061 (P4-27): IOPort
[ 392.645659] hm2/hm2_5i20.0: IO Pin 062 (P4-29): IOPort
[ 392.645666] hm2/hm2_5i20.0: IO Pin 063 (P4-31): IOPort
[ 392.645673] hm2/hm2_5i20.0: IO Pin 064 (P4-33): IOPort
[ 392.645680] hm2/hm2_5i20.0: IO Pin 065 (P4-35): IOPort
[ 392.645687] hm2/hm2_5i20.0: IO Pin 066 (P4-37): IOPort
[ 392.645694] hm2/hm2_5i20.0: IO Pin 067 (P4-39): IOPort
[ 392.645701] hm2/hm2_5i20.0: IO Pin 068 (P4-41): IOPort
[ 392.645708] hm2/hm2_5i20.0: IO Pin 069 (P4-43): IOPort
[ 392.645714] hm2/hm2_5i20.0: IO Pin 070 (P4-45): IOPort
[ 392.645721] hm2/hm2_5i20.0: IO Pin 071 (P4-47): IOPort
[ 392.646184] hm2/hm2_5i20.0: registered
[ 392.646191] hm2_5i20.0: initialized AnyIO board at 0000:04:00.0
[ 392.652816] config string '0 out'
[ 410.599550] hm2_5i20.0: dropping AnyIO board at 0000:04:00.0
[ 410.599568] hm2/hm2_5i20.0: unregistered
[ 410.599710] hm2_pci: driver unloaded
[ 410.605524] hm2: unloading
[ 412.907075] RTAI[math]: unloaded.
[ 412.913363] SCHED releases registered named ALIEN PEDV$D
[ 412.927206] RTAI[malloc]: unloaded.
[ 413.024057] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 413.029548] I-pipe: head domain RTAI unregistered.
[ 413.029766] RTAI[hal]: unmounted.
[ 488.460873] I-pipe: head domain RTAI registered.
[ 488.460891] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 488.461080] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 488.461092] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 8312460, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 488.461104] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 488.461113] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8312460, 8312460, 8194250
[ 488.480598] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 488.480740] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 488.480756] RTAI[sched]: hard timer type/freq = APIC/8312460(Hz); default timing: oneshot; linear timed lists.
[ 488.480768] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 488.480777] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 488.504177] RTAI[math]: loaded.
[ 488.723773] hm2: loading Mesa HostMot2 driver version 0.15
[ 488.729571] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 488.729667] hm2_pci: discovered 5i20 at 0000:04:00.0
[ 488.882056] hm2/hm2_5i20.0: WARNING: this firmware has Muxed Encoder v2!
[ 488.882068] hm2/hm2_5i20.0: WARNING: velocity computation will be incorrect!
[ 488.882078] hm2/hm2_5i20.0: WARNING: upgrade your firmware!
[ 488.896683] hm2/hm2_5i20.0: 72 I/O Pins used:
[ 488.896695] hm2/hm2_5i20.0: IO Pin 000 (P2-01): PWMGen #0, pin Not-Enable (Output)
[ 488.896704] hm2/hm2_5i20.0: IO Pin 001 (P2-03): Muxed Encoder #0, pin Muxed A (Input)
[ 488.896713] hm2/hm2_5i20.0: IO Pin 002 (P2-05): Muxed Encoder #0, pin Muxed B (Input)
[ 488.896721] hm2/hm2_5i20.0: IO Pin 003 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 488.896730] hm2/hm2_5i20.0: IO Pin 004 (P2-09): Muxed Encoder #1, pin Muxed A (Input)
[ 488.896739] hm2/hm2_5i20.0: IO Pin 005 (P2-11): Muxed Encoder #1, pin Muxed B (Input)
[ 488.896748] hm2/hm2_5i20.0: IO Pin 006 (P2-13): Muxed Encoder #1, pin Muxed Index (Input)
[ 488.896756] hm2/hm2_5i20.0: IO Pin 007 (P2-15): Muxed Encoder #2, pin Muxed A (Input)
[ 488.896765] hm2/hm2_5i20.0: IO Pin 008 (P2-17): Muxed Encoder #2, pin Muxed B (Input)
[ 488.896774] hm2/hm2_5i20.0: IO Pin 009 (P2-19): Muxed Encoder #2, pin Muxed Index (Input)
[ 488.896783] hm2/hm2_5i20.0: IO Pin 010 (P2-21): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 488.896792] hm2/hm2_5i20.0: IO Pin 011 (P2-23): PWMGen #0, pin Out0 (PWM or Up) (Output)
[ 488.896801] hm2/hm2_5i20.0: IO Pin 012 (P2-25): PWMGen #0, pin Out1 (Dir or Down) (Output)
[ 488.896809] hm2/hm2_5i20.0: IO Pin 013 (P2-27): PWMGen #1, pin Out0 (PWM or Up) (Output)
[ 488.896818] hm2/hm2_5i20.0: IO Pin 014 (P2-29): PWMGen #1, pin Out1 (Dir or Down) (Output)
[ 488.896827] hm2/hm2_5i20.0: IO Pin 015 (P2-31): PWMGen #2, pin Out0 (PWM or Up) (Output)
[ 488.896836] hm2/hm2_5i20.0: IO Pin 016 (P2-33): PWMGen #2, pin Out1 (Dir or Down) (Output)
[ 488.896845] hm2/hm2_5i20.0: IO Pin 017 (P2-35): PWMGen #3, pin Out0 (PWM or Up) (Output)
[ 488.896854] hm2/hm2_5i20.0: IO Pin 018 (P2-37): PWMGen #3, pin Out1 (Dir or Down) (Output)
[ 488.896863] hm2/hm2_5i20.0: IO Pin 019 (P2-39): PWMGen #4, pin Out0 (PWM or Up) (Output)
[ 488.896871] hm2/hm2_5i20.0: IO Pin 020 (P2-41): PWMGen #4, pin Out1 (Dir or Down) (Output)
[ 488.896880] hm2/hm2_5i20.0: IO Pin 021 (P2-43): PWMGen #5, pin Out0 (PWM or Up) (Output)
[ 488.896889] hm2/hm2_5i20.0: IO Pin 022 (P2-45): PWMGen #5, pin Out1 (Dir or Down) (Output)
[ 488.896898] hm2/hm2_5i20.0: IO Pin 023 (P2-47): PWMGen #0, pin Not-Enable (Output)
[ 488.896906] hm2/hm2_5i20.0: IO Pin 024 (P3-01): IOPort
[ 488.896913] hm2/hm2_5i20.0: IO Pin 025 (P3-03): IOPort
[ 488.896920] hm2/hm2_5i20.0: IO Pin 026 (P3-05): IOPort
[ 488.896927] hm2/hm2_5i20.0: IO Pin 027 (P3-07): IOPort
[ 488.896934] hm2/hm2_5i20.0: IO Pin 028 (P3-09): IOPort
[ 488.896941] hm2/hm2_5i20.0: IO Pin 029 (P3-11): IOPort
[ 488.896948] hm2/hm2_5i20.0: IO Pin 030 (P3-13): IOPort
[ 488.896955] hm2/hm2_5i20.0: IO Pin 031 (P3-15): IOPort
[ 488.896962] hm2/hm2_5i20.0: IO Pin 032 (P3-17): IOPort
[ 488.896968] hm2/hm2_5i20.0: IO Pin 033 (P3-19): IOPort
[ 488.896977] hm2/hm2_5i20.0: IO Pin 034 (P3-21): Muxed Encoder Select #3, pin Mux Select 0 (Output)
[ 488.896985] hm2/hm2_5i20.0: IO Pin 035 (P3-23): IOPort
[ 488.896992] hm2/hm2_5i20.0: IO Pin 036 (P3-25): IOPort
[ 488.896999] hm2/hm2_5i20.0: IO Pin 037 (P3-27): IOPort
[ 488.897006] hm2/hm2_5i20.0: IO Pin 038 (P3-29): IOPort
[ 488.897013] hm2/hm2_5i20.0: IO Pin 039 (P3-31): IOPort
[ 488.897020] hm2/hm2_5i20.0: IO Pin 040 (P3-33): IOPort
[ 488.897027] hm2/hm2_5i20.0: IO Pin 041 (P3-35): IOPort
[ 488.897034] hm2/hm2_5i20.0: IO Pin 042 (P3-37): IOPort
[ 488.897040] hm2/hm2_5i20.0: IO Pin 043 (P3-39): IOPort
[ 488.897047] hm2/hm2_5i20.0: IO Pin 044 (P3-41): IOPort
[ 488.897057] hm2/hm2_5i20.0: IO Pin 045 (P3-43): IOPort
[ 488.897064] hm2/hm2_5i20.0: IO Pin 046 (P3-45): IOPort
[ 488.897071] hm2/hm2_5i20.0: IO Pin 047 (P3-47): IOPort
[ 488.897082] hm2/hm2_5i20.0: IO Pin 048 (P4-01): Muxed Encoder #0, pin Muxed IndexMask (Input)
[ 488.897091] hm2/hm2_5i20.0: IO Pin 049 (P4-03): Muxed Encoder #1, pin Muxed IndexMask (Input)
[ 488.897100] hm2/hm2_5i20.0: IO Pin 050 (P4-05): Muxed Encoder #2, pin Muxed IndexMask (Input)
[ 488.897108] hm2/hm2_5i20.0: IO Pin 051 (P4-07): IOPort
[ 488.897115] hm2/hm2_5i20.0: IO Pin 052 (P4-09): IOPort
[ 488.897122] hm2/hm2_5i20.0: IO Pin 053 (P4-11): IOPort
[ 488.897129] hm2/hm2_5i20.0: IO Pin 054 (P4-13): IOPort
[ 488.897136] hm2/hm2_5i20.0: IO Pin 055 (P4-15): IOPort
[ 488.897143] hm2/hm2_5i20.0: IO Pin 056 (P4-17): IOPort
[ 488.897150] hm2/hm2_5i20.0: IO Pin 057 (P4-19): IOPort
[ 488.897157] hm2/hm2_5i20.0: IO Pin 058 (P4-21): IOPort
[ 488.897164] hm2/hm2_5i20.0: IO Pin 059 (P4-23): IOPort
[ 488.897171] hm2/hm2_5i20.0: IO Pin 060 (P4-25): IOPort
[ 488.897178] hm2/hm2_5i20.0: IO Pin 061 (P4-27): IOPort
[ 488.897185] hm2/hm2_5i20.0: IO Pin 062 (P4-29): IOPort
[ 488.897192] hm2/hm2_5i20.0: IO Pin 063 (P4-31): IOPort
[ 488.897199] hm2/hm2_5i20.0: IO Pin 064 (P4-33): IOPort
[ 488.897206] hm2/hm2_5i20.0: IO Pin 065 (P4-35): IOPort
[ 488.897213] hm2/hm2_5i20.0: IO Pin 066 (P4-37): IOPort
[ 488.897219] hm2/hm2_5i20.0: IO Pin 067 (P4-39): IOPort
[ 488.897226] hm2/hm2_5i20.0: IO Pin 068 (P4-41): IOPort
[ 488.897233] hm2/hm2_5i20.0: IO Pin 069 (P4-43): IOPort
[ 488.897240] hm2/hm2_5i20.0: IO Pin 070 (P4-45): IOPort
[ 488.897247] hm2/hm2_5i20.0: IO Pin 071 (P4-47): IOPort
[ 488.897709] hm2/hm2_5i20.0: registered
[ 488.897716] hm2_5i20.0: initialized AnyIO board at 0000:04:00.0
[ 488.904621] config string '0 out'
[ 542.518996] FAT-fs (sdb1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 675.675541] hm2_5i20.0: dropping AnyIO board at 0000:04:00.0
[ 675.675559] hm2/hm2_5i20.0: unregistered
[ 675.675698] hm2_pci: driver unloaded
[ 675.683458] hm2: unloading
[ 677.970299] RTAI[math]: unloaded.
[ 677.976249] SCHED releases registered named ALIEN PEDV$D
[ 677.983883] RTAI[malloc]: unloaded.
[ 678.080055] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 678.085634] I-pipe: head domain RTAI unregistered.
[ 678.085856] RTAI[hal]: unmounted.
[ 680.295813] I-pipe: head domain RTAI registered.
[ 680.295831] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 680.296189] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 680.296228] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 8312460, CLK_FREQ 1596019000, CPU_FREQ 1596019000
[ 680.296266] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 680.296306] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8312460, 8312460, 8172500
[ 680.316259] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 680.316399] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 680.316420] RTAI[sched]: hard timer type/freq = APIC/8312460(Hz); default timing: oneshot; linear timed lists.
[ 680.316437] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1596019000 hz.
[ 680.316447] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 680.340808] RTAI[math]: loaded.
[ 680.567748] hm2: loading Mesa HostMot2 driver version 0.15
[ 680.573578] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 680.573670] hm2_pci: discovered 5i20 at 0000:04:00.0
[ 680.580566] hm2/hm2_5i20.0: firmware hm2/5i20/svst6_6_7i48.BIT not found
[ 680.580584] hm2/hm2_5i20.0: install the package containing the firmware.
[ 680.580601] hm2_5i20.0: board fails HM2 registration
[ 680.580718] hm2_pci: probe of 0000:04:00.0 failed with error -2
[ 681.314628] hm2: unloading
[ 683.599215] RTAI[math]: unloaded.
[ 683.604997] SCHED releases registered named ALIEN PEDV$D
[ 683.617330] RTAI[malloc]: unloaded.
[ 683.716055] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 683.721651] I-pipe: head domain RTAI unregistered.
[ 683.721887] RTAI[hal]: unmounted.
dirk@dirk:~$
How can I update this firmware ??
"5745500
dirk@dirk:~$
10 Jul 2016 15:31 #77254
What version of LinuxCNC is this?
I would expect that LinuxCNCs firmware packages had this fixed
(it was fixed about 7 years ago)
In any case, here is a proper 5I20+7I48 bitfile:
freeby.mesanet.com/svst6_6_7i48.bit
which has the updated encoder logic
- dirk61
11 Jul 2016 11:13 - 11 Jul 2016 12:31 #77283
by dirk61
OK
Have now the Bit file loaded on my USB stick
what I have to do exactly that.
Because
this BIT file I copied already in the folder 5i20 only as XML file. I have found from this forum on one of your page.
It is me in PNCCONF I angezeigt.Wenn a config do and then Linuxcnc Create comes the second (long) error message.
thank you
Linux CNC 2.7.4 i think on Debian
Because
thank you
Last edit: 11 Jul 2016 12:31 by dirk61.
11 Jul 2016 13:55 #77293
Replied by andypugh on topic convert a .BIT to .XML
The .bit file needs to go in /lib/firmware/hm2/5i20
The xml file is only used by PnCConf.
Time to create page: 0.168 seconds
