double pid loop ?
- Thank you received: 1471
28 Jul 2016 03:46 #78090
Replied by Todd Zuercher on topic double pid loop ?
You might be able to improve the following error spikes at the acceleration changes by adding a very small amount of FF2.
- vre
- Thank you received: 17
28 Jul 2016 06:20 - 28 Jul 2016 06:37 #78091
by vre
Replied by vre on topic double pid loop ?
No help from FF2 i have tried.
But i get better ferror (less spikes) if i reduce the acceleration.
I will try and another servo from the same manufacturer 600w with has lower inertia.
Why STEPGEN_MAXVEL / STEPGEN_MAXACCEL must be 25% larger than MAX_VELOCITY / MAX_ACCELERATION ?
If apply this rule i can have rough max 2500rpm in servo not 3000rpm witch is named.
MAX_VELOCITY
MAX_ACCELERATION
STEPGEN_MAXVEL
STEPGEN_MAXACCEL
Last edit: 28 Jul 2016 06:37 by vre.
28 Jul 2016 12:55 #78097
Just curious, what numbers did you try for FF2? And what were the results? FF2 is very sensitive and it usually need to be less than 0.001 (and that is on an inch machine, might be a lot less for metric).
Actually your following error is a little better than I have on my wood router, but you have about 15x higher encoder scale. So you should be able to do about that much better.
If the drive has any kind of Jerk limiting features, you may need to reduce or turn them off.
- Thank you received: 5316
28 Jul 2016 15:54 - 28 Jul 2016 15:55 #78098
Replied by PCW on topic double pid loop ?
The hardware acceleration and velocity limits must be greater than the trajectory planners limits
for this reason:
Assume the trajectory planner is doing a full speed or full acceleration move, if the hardware limits
matched the trajectory planner limits there is no way the control loop could catch up if it gets behind for
any reason (dir setup or hold delay times, mismatched clocks between software and hardware,
finite time after reading position that velocity is written etc etc)
This is the same for any servo system: the control loop always needs some overhead room to work in.
As soon as you hit the limits you no longer have a linear feedback system and control falls apart
for this reason:
Last edit: 28 Jul 2016 15:55 by PCW.
- vre
01 Aug 2016 19:04 #78248
by vre
I got a 7i33 and tried speed mode with similar results.
In speed mode how can i set MAX_VELOCITY ? Must be 75% of motor max velocity or can be 100% ?
Time to create page: 0.155 seconds
